Go Back   Focus Fanatics > Model Specific Discussions > MK2 Focus
View Poll Results: After this how-to would you consider upgrading your horns?
Yes, it was very helpful and you are my hero! 8 61.54%
Meh, it doesn't look as easy as your mom but I may give er a shot ;) 4 30.77%
Your thread is bad and you should feel bad! 1 7.69%
Voters: 13. You may not vote on this poll
Old 09-22-2012, 05:51 PM   #1
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
FF Reputation: 5 DarderSauce Good Standing Member
Cool How to: Sickspeed Horn Installation
Hello everyone,
As promised (even if late) I am doing my write up on my Sick Speed Horn installation. So without further delay, here we go!
Here is what you are going to be using:
Untitled by DarderSauce, on Flickr
- Sick Speed horns (durp)
- A multimeter is helpful but not a must
- Solder Gun (with solder)
- 12 Gauge wire
- Relay Switch
- Fuse for 30 Amp fuse
- 30 amp fuses (ATC)
- Female Spades
Not Pictured
- Heat Shrink
- Ring Terminals
First you are going to want to pop your hood and UNPLUG YOUR NEGATIVE BATTERY TERMINAL. Next remove your grille, here are the four clips that hold the grille on. Once they are off just pull out (wink).
Grille by DarderSauce, on Flickr
Once that is off you can get started. Cut into the wiring harness up near the battery, you are looking for the purple and green wire, this is your power.
Cut this wire up by the battery. Try leaving yourself enough slack so you can mount your relay in a spot that is going to stay out of harm’s way. Here is where I ended up mounting mine.
Now you are going to want to put a female spade end on your purple and green power wire and plug it into pin #86 on the relay.
*PRO TIP* SickSpeeds wiring diagram is WRONG, they have the power wire from the stock horn going into pin 87. If you follow their instructions you won’t get da beep!
Wiring Diagram by DarderSauce, on Flickr
So again, stick the power wire from your stock horn in pin #86.
Next you are going to hook your fuse up to the positive end on your battery terminal. Put a ring terminal on one end of the fuse, and a female spade on the other.
You may need to solder in another piece of wire to the fuse wiring in order to get the spade end to reach the relay. This is what I did, don’t forget the heat shrink!
Plug the female spade into pin #30 on the relay.
Use your 12 gauge wire and add a ring terminal to one end, and a female spade to the other. This is going to be your ground wire so make it long enough to reach from your ground to your relay. Here is where I mounted my ground wire (not the best pic).
Ground by DarderSauce, on Flickr
Plug your ground wire into pin 85 on your relay.
Now you are going to be running your long length of wire that is going from pin 87 to the horns you are going to mount. This is where you are going to solder in the split to go to horn number 2. Again, HEAT SHRINK!!! Each end should have a female end on it, this is going to be plugged into the horn pins.
When you are plugging the power wire into the horn spades, just put it in either one it doesn’t matter. Here is what it’s going to look like.
Dicks by DarderSauce, on Flickr
The other wire you see is your ground wire. Each one of has a ring terminal and female spade end. Plug the female spade into the other pin on your horn and put the ring terminal behind your mounting bolt.
After you do this for both sides you are done!!!!
Final product with grille in:
Here is what she sounds like:
Clicky!
Sorry if the write up sucks but let me know if you have any questions
Thanks for looking!
If you can't wear it out, burn it off
DarderSauce is offline
Old 09-22-2012, 07:48 PM   #2
GN Prime
GN Prime's Avatar
Fan#: 92475
What I Drive: 2011 sterling gray ses
FF Reputation: 1 GN Prime Good Standing Member
good write up:) it sounds weird though and thank you scaring the shit outta me and my dog lol, i was like hmm must be a quiet video, so i turned it up and bam:)
2011 Sterling Gray SES
SES #025/ Sedan Revolution #221
GN Prime is offline
Old 09-22-2012, 08:16 PM   #3
DarderSauce
Fan#: 95564
Ya I thought the sound was a bit weird but it is MUCH louder than stock which is what I wanted so I'm jacked (off)!
YouTube Video
Old 09-23-2012, 01:45 PM   #4
PowerFocer
PowerFocer's Avatar
Fan#: 61706
What I Drive: 2010 Sedan SE
FF Reputation: 2 PowerFocer Good Standing Member
How much did all this cost you? and can I have a link? :)
Originally Posted by WeeAsp View Post
Rule of thumb:
NEVER trust anyone with your car or your girl.
Either way, you could get a rod thrown in both.........
Fast cars make smart people do dumb things
PowerFocer is offline
Old 09-23-2012, 02:10 PM   #5
elsolo
elsolo's Avatar
Fan#: 96835
FF Reputation: 9 elsolo Good Standing Member
Hard to tell in pic, but make sure these wires aren't chafing across the fins.
Radiators, AC condensors, and fluid coolers make very effective low speed files.
elsolo is offline
Old 09-23-2012, 02:31 PM   #6
st12131
Focal Distortion
st12131's Avatar
Fan#: 74797
What I Drive: 2007, Huyndai, Santa Fe, GLS
FF Reputation: 8 st12131 Good Standing Member
I Like it, sounds good to boot.
-Bob-
2012 F-150 EcoBoost 4X4 (work truck)
Focus S #1, Sedan Revolution #192, Rally Revolution #8, March 2012 SOTM
Focal Distortion, a Ford licensed club and FSC member.
Sgt, USMC (1999-2003)
st12131 is online now
Old 09-23-2012, 02:58 PM   #7
DarderSauce
Fan#: 95564
http://www.ebay.com/itm/2X-SUPER-LOU...sories&vxp=mtr
I got mine off eBay when they were ~$40(?)
so all together for everything maybe like $60
Old 09-23-2012, 03:02 PM   #8
DarderSauce
Fan#: 95564
Ya I zip tied them up nice and tight, good lookin out tho.
Old 09-25-2012, 05:03 PM   #9
King Hoonigan
King Hoonigan's Avatar
Fan#: 100769
What I Drive: 2011 Sterling Grey SES
FF Reputation: 1 King Hoonigan Good Standing Member
hmm, wonder if i should do it this way or use the harness that you can buy separately for it
Fswerks Race exhaust-Fswerks CAI-Eibach Pro's-Eagle Eye Projectors-Fswerks stage 2 turbo coming this summer
King Hoonigan is offline
Old 09-25-2012, 05:10 PM   #10
DarderSauce
Fan#: 95564
Ya, they didn't have the harness when I bought mine, I just saw that they have one now.
