Go Back   Focus Fanatics > Ford Focus Tech Discussions > SVT Performance (2002-2004)
Old 09-28-2012, 11:00 PM   #11
Dark 007
Dark 007's Avatar
Fan#: 80502
What I Drive: 2001 marshall red LX
FF Reputation: 1 Dark 007 Good Standing Member
This is probably a dumb-o' question, but, are lowering springs (in general) good for a daily driving Foci in a mayor City
Posted via iPhone using FF Mobile
Dark 007 is offline
Old 10-01-2012, 07:38 AM   #12
GBPackFan
GBPackFan's Avatar
Fan#: 84314
What I Drive: 2002 Sonic Blue SVT
FF Reputation: 1 GBPackFan Good Standing Member
Originally Posted by ProSilverVT02 View Post
There won't be any rubbing with either Eibach Pro-Kit or the Sportlines.
They only way you could possibly rub would be running a tire that is too big.
I have some Sparco Assetto Gara's with 215/45-17's on them. The only thing I failed to understand before I bought them was that they have an offset of 45, if I recall correctly. Ever since then, I have had a terribly rub when I go around a hairpin turn or if I hit a driveway lip or bump. It's also important to note that I have like 138K miles on original springs. Only recently I have learned how bad these stockers get after "X" number of miles, but I am wondering if my rub if more associated with bad springs or that mistake I made in those Assetto Gara's? I have tried running a 205 tire on the wheels and it only seems to help somewhat.
Any help would be great help!!
Also, don't know if it helps, but I replaced the shocks, thinking it was those that were bad. So I have the KYB AGX adjustables on there. I had them put on at 86K miles.
The WIP: 2002 SVTF #2358
Lots 'o' Mods
This car is making my hair go gray...
GBPackFan is offline
Old 10-01-2012, 01:05 PM   #13
ProSilverVT02
ProSilverVT02's Avatar
Fan#: 33656
What I Drive: 2002 SVT
FF Reputation: 7 ProSilverVT02 Good Standing Member
Buy-Sell-Trade Rating: (8)
I totally forgot about running a different offset.
I've edited my original post about rubbing.
Are you planning on upgrading your springs?
ProSilverVT02 is offline
Old 10-02-2012, 12:45 AM   #14
GBPackFan
GBPackFan's Avatar
Fan#: 84314
So, with out replacing my wheels, what can I do help my rub? I would guess that replacing my springs and shocks will help, but will it cure the rub?
Lots 'o' Mods
Old 10-02-2012, 05:02 PM   #15
ProSilverVT02
Fan#: 33656
You can definitely keep the wheels, but consider running a smaller sized tire.
If you get down into the 205/40/17 tire size range you will decrease your width and height which should reduce, or most likely get rid of the rubbing altogether.
The ride, obviously will be a little rougher because of the smaller sidewall, but you shouldn't have any rubbing issues.
With that said, it doesn't hurt to replace your worn out suspension, but you probably won't see that drastic of a change by replacing your springs and shocks compared to running a smaller tire.
Old 10-03-2012, 07:43 PM   #16
SVTFocusOnMe
SVTFocusOnMe's Avatar
Fan#: 89087
What I Drive: 2003 SVT EAP Screamin' Yellow ZX3
FF Reputation: 4 SVTFocusOnMe Good Standing Member
Are the wheels 17x7 or 17x7.5. If it's a 17x7 I can't imagine your rubbing being bad at all. 215 45 17 is stock tire size and the 45 offset is only 3 away from the stock 48 so that's pretty damn close. I'd look into replacing shocks and springs.
03 Ford SVT Focus - Toms tune, Steeda mounts & stress bar, ORP, 66MM BBK TB, CFM UDP, Rota Grids
The Bad Cat (97 Merc Cougar XR7) - Flowmasters, MSD ignition, K&N intake, 19" Stern ST-4 Warps
SVTFocusOnMe is offline
Old 10-04-2012, 12:26 AM   #17
GBPackFan
GBPackFan's Avatar
Fan#: 84314
Sticker on the box from Tire Rack says 17x7.. I am getting nasty terrible rub. If I take a hairpin turn at say 7mph, I rub. If I have a friend in my lack of a back seat, I rub. If I hit a driveway lip faster than 2mph, I rub.. I just don't know to do about it... I have tossed around the idea of having my fenders rolled, but I don't even know how to go about that.
Lots 'o' Mods
Old 10-04-2012, 08:49 AM   #18
SVTFocusOnMe
Fan#: 89087
That blows my mind. I would replace the old worn out suspension first. Your describing worse rubbing that my car I'm running 17x8 with a 40 offset and a 225/45.
Old 10-04-2012, 06:54 PM   #19
GBPackFan
GBPackFan's Avatar
Fan#: 84314
I'm a little on the heavy side, and so is my wife, but we never experience this much rub before. It started to be noticeable before I got the rims. I went to a mechanic for a clunking noise in my suspension area. He said that the driver side end link was toast. He reccomended that they be replaced in pairs. So he changed out the end links. This was around Nov of 2010. I first noticed the rub when I went over a speed bump and the drivers front tire rub mad nasty, first time ever. I have had 205/45/17's on the drivers side front (popped a flat at work, and that was the only tire the mexican place that would fit..), but since have gone back to 215/45/17's. The rub did seem somewhat diminished with the smaller tire up there, but it never went away comletely..
Lots 'o' Mods
Old 10-04-2012, 07:54 PM   #20
SVTFocusOnMe
Fan#: 89087
Hmm yeah I'd prob chalk that one up to a worn out suspension.
