Tranny Question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-20-2012, 06:09 PM   #1
Seriously Focused
Seriously Focused's Avatar
Fan#: 101141
What I Drive: 2012 SGM SE Sport 5 Dr
Points 532, Level 10
Points: 532, Level: 10 Points: 532, Level: 10 Points: 532, Level: 10
Level Up 64% Completed
FF Reputation: 1 Seriously Focused Good Standing Member
Tranny Question
At work today, someone had a reasonably new Ford Focus rental car in the parking lot. It was an SE model with an automatic without the Sport Shift. Instead of "S" on the shifter, is just had "L" for low.
Is that the same DCT that is in my SE Sport minus the shifting feature (+/-) ?
Just curious, thanks.
Seriously Focused is offline
Old 09-20-2012, 06:12 PM   #2
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,231, Level 67
Points: 10,231, Level: 67 Points: 10,231, Level: 67 Points: 10,231, Level: 67
Level Up 46% Completed
Forum Activity 30%
FF Reputation: 26 suss6052 Great Standing Member
Yes, its the same transmission without the select shift feature.
So L essentially behaves the same way that S auto does, but there is no manual mode. Only an overdrive off/ grade assist on/off switch instead of the self shifting switch.
suss6052 is online now
Old 09-20-2012, 06:15 PM   #3
Seriously Focused
Fan#: 101141
Hey, thanks for the info and the quick response !!
Old 09-20-2012, 06:38 PM   #4
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 30%
You're welcome. It would be odd if it was a different transmision, but Dodge is doing that with the fatter (4/3rds scale) Alfa Guiletta. The 2.0 L i4 uses a 6 speed torque converter automatic same as the Hyundai Elantra (and might actually be the Hyundai gearbox), but the Fiat 1.4 L engine uses a dry dual clutch dct like our Focus, but the shifter is exactly the same right down to the slap stick manumatic mode in the Chryslers. That is confusing unless you know what to look for.
Old 09-20-2012, 09:16 PM   #5
dbenney
Fan#: 1195
What I Drive: 2012 Tuxedo Black SEL
Points 968, Level 16
Points: 968, Level: 16 Points: 968, Level: 16 Points: 968, Level: 16
Level Up 68% Completed
FF Reputation: 5 dbenney Good Standing Member
Suss you are correct. If you remember I work at Michigan Assembly on the Engine line and infact i secure the transmission to the engine. For the Focus S, SE, SEL, TI there is only 1 auto trans. The only difference is the shifter button option and programming.
dbenney is offline
Old 09-20-2012, 10:08 PM   #6
Visioned
Fan#: 93729
What I Drive: 2012, Red Candy, Focus SE
FF Reputation: -1 Visioned Poor Behavior Needs Improvement
Edited: Wrong topic
Visioned is offline
Old 09-22-2012, 03:46 AM   #7
Focusneek
Fan#: 95824
What I Drive: 2011 Focus SES
FF Reputation: 1 Focusneek Good Standing Member
do all sel models have +/- shifting feature?
Focusneek is offline
Old 09-22-2012, 03:47 AM   #8
Focusneek
Fan#: 95824
Old 09-22-2012, 07:20 AM   #9
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 30%
Technically it was considered a no cost option on the SEL so there might have been one or two built without it, but none that I've seen in person. Most if not all SEL or Ti models should have had the select shift feature with the DCT.
Old 09-22-2012, 09:54 AM   #10
2012silversel
2012silversel's Avatar
Fan#: 83969
What I Drive: 2014 C-Max Energi, Sterling Gray
Points 1,963, Level 26
Points: 1,963, Level: 26 Points: 1,963, Level: 26 Points: 1,963, Level: 26
Level Up 63% Completed
FF Reputation: 1 2012silversel Good Standing Member
Damn, after reading the topic title I was a little disappointed when I got into the thread.
2012silversel is offline
