Low Level Brake Fluid - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-20-2012, 09:12 AM   #1
chum567
Fan#: 86507
What I Drive: 2012 Sterling Gray Focus SEL
FF Reputation: 1 chum567 Good Standing Member
My low level brake fluid light is coming on and off this morning on my way to work. Car has about 12,000 miles on it does that sound strange?
chum567 is offline
Old 09-20-2012, 09:15 AM   #2
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 7%
FF Reputation: 13 BetaDnB Great Standing Member
Have you actually stopped to check your fluid level or are you just continuing to drive with a low brake fluid warning while posting threads on FF? More so, has your brake pedal feel turned spongy?
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is offline
Old 09-20-2012, 09:22 AM   #3
chum567
Fan#: 86507
Man such a smart ass so early in the morning.....this just happened this morning for the first time and every time I came to a stop it came on then went away as soon as I started going again. I have not checked because I went straight into work and haven't had time and the brake pedal feels fine.
chum567 is offline
Old 09-20-2012, 09:29 AM   #4
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,082, Level 34
Points: 3,082, Level: 34 Points: 3,082, Level: 34 Points: 3,082, Level: 34
Level Up 22% Completed
Forum Activity 4%
FF Reputation: 12 dan50 Great Standing Member
It is strange. It could be just a bad sensor or truly low fluid. Take a look under the hood: if the level is OK it's probably a sensor issue that can be dealt with when you have time. If the fluid is actually low it means a trip to the dealer ASAP.
The fluid in reservoir is also used for the clutch, so be alert for odd behavior on that front, too. The cap on my reservoir was slightly loose when I took delivery, so that'd be another thing to check, even if the level is OK.
dan50 is offline
Old 09-20-2012, 09:31 AM   #5
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Forum Activity 7%
Sorry. You kind of left yourself wide open for it. Check the fluid level when you get a chance before you go anywhere. You only have to open the hood and look. Also check for leaks on the ground. It could be an actual problem or just a faulty sensor.
edit: I guess dan beat me to it.
BetaDnB is offline
Old 09-20-2012, 09:47 AM   #6
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,249, Level 67
Points: 10,249, Level: 67 Points: 10,249, Level: 67 Points: 10,249, Level: 67
Level Up 50% Completed
Forum Activity 37%
Activity: 37% Activity: 37% Activity: 37%
FF Reputation: 26 suss6052 Great Standing Member
The fluid on the DCT equipped cars is only used for the brakes. You have an SEL, the same as the OP, and considering that they are in AL. chances of them having a canadian spec manual is slim to none in the SEL. But otherwise this makes sense.
suss6052 is offline
Old 09-20-2012, 09:48 AM   #7
jdetzel
Fan#: 102548
What I Drive: 2012 White Titanium Hatchback
Points 177, Level 3
Points: 177, Level: 3 Points: 177, Level: 3 Points: 177, Level: 3
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 1 jdetzel Good Standing Member
In addition to what Dan and Beta said, DONT drive it!
You are still under warranty. Call the dealer, tell them it is unsafe to drive and make them tow it.
jdetzel is offline
Old 09-20-2012, 10:37 AM   #8
oritpro
oritpro's Avatar
Fan#: 96148
What I Drive: 2012 Subaru Impreza Sport Limited
Points 749, Level 14
Points: 749, Level: 14 Points: 749, Level: 14 Points: 749, Level: 14
Level Up 49% Completed
FF Reputation: 2 oritpro Good Standing Member
I get a low brake fluid warning when my car is parked facing down a slight (20-25 degree) incline, usually when backed into my driveway. It happened this morning again before I left for work.
I've checked the fluid level and it's fine but I am going to have the shop take a look at it anyway.
oritpro is offline
Old 09-20-2012, 10:46 AM   #9
chum567
Fan#: 86507
ok well I called the dealer because I'm waiting on another part (been waiting over 3 months to be exact :/) and he told me my part had finally been shipped and will be in next week and then I told him about what happened this morning and he said something along the lines of it not actually being low it has more to do with the actual brake pedal being thinner. He said to just wait till next week when I bring it in for other work for them to look at it. Thoughts?
chum567 is offline
Old 09-20-2012, 10:53 AM   #10
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
What I Drive: 2012 Focus Titanium Hatch
Points 4,361, Level 42
Points: 4,361, Level: 42 Points: 4,361, Level: 42 Points: 4,361, Level: 42
Level Up 6% Completed
Forum Activity 6%
FF Reputation: 9 darkangelism Good Standing Member
check the level first, if it is low you can't wait
darkangelism is offline
