Oil pressure question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-19-2012, 02:32 PM   #1
burke_024
burke_024's Avatar
Fan#: 94039
What I Drive: 2000 focus zx3, almost boosted : )
Points 1,562, Level 22
Points: 1,562, Level: 22 Points: 1,562, Level: 22 Points: 1,562, Level: 22
Level Up 62% Completed
FF Reputation: 1 burke_024 Good Standing Member
So i need to know how to test oil psi ,i have a guage ,but it takes awhile to register,the ferrule coming from the head by the thermostat housing is bottlenecking the oil line but its still sending pressure i just wanna make sure my oil pump is in working order ,how do i testit,thnx
burke_024 is offline
Old 09-19-2012, 03:45 PM   #2
burke_024
burke_024's Avatar
Fan#: 94039
It started at 85 psi this morning and went 60after warm and has benn slowly droppin all day,it also hold pressure after shut off ,i dont think thats normal .......
Old 09-19-2012, 03:48 PM   #3
burke_024
burke_024's Avatar
Fan#: 94039
And theeeen the very tip of my dip stick to the first hole broke off i dont know when ,.......what are the chances its still in my engine and not damaged anything,what do i use to seal the oil pan backup?,sorry formultiple posts
Old 09-19-2012, 06:36 PM   #4
bespurcell
bespurcell's Avatar
Fan#: 60917
What I Drive: 2003 black svt
FF Reputation: 2 bespurcell Good Standing Member
The tip of your dipstick is probably just chillin' in the bottom of your oil pan. If it's like the svt you just use rtv for the gasket. That's what the factory uses.
Dominant Eng. orp, ITG Maxogen panel filter, Focus-Power tune, Team Dynamic Pro Race 2 16x7 wheels in black(36 lb weight reduction from stock tire/wheel combo)
bespurcell is offline
Old 09-19-2012, 09:39 PM   #5
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,259, Level 100
Points: 51,259, Level: 100 Points: 51,259, Level: 100 Points: 51,259, Level: 100
Level Up 0% Completed
Forum Activity 22%
Activity: 22% Activity: 22% Activity: 22%
Buy-Sell-Trade Rating: (28)
Sounds like you may have an issue with your oil line / gauge , when you shut the engine off the oil psi should drop to 0 with in 2-4 sec , when you start the engine you should see full oil psi in 2-3 sec and colder at about 85 +/- psi is about right and 50 +/- is about right for hot 180+ deg and 8-10 min driving
Rule of thumb on a DOHC engine is about 10-12 psi for every 1000 rpm is all thats needed so at 3000 and you have 30 - 60 your good , 6000-7000 and you have 60-70 your good , this will change some with oil temps , type and weight of oils , age / miles on engine
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 09-19-2012, 11:43 PM   #6
inis
Fan#: 32050
What I Drive: 00 Zx2 s/r (yellow)
Points 2,816, Level 32
Points: 2,816, Level: 32 Points: 2,816, Level: 32 Points: 2,816, Level: 32
Level Up 44% Completed
FF Reputation: 1 inis Good Standing Member
Because I have a dry sump, I have studied oil pressure extensively on the zetec. At idle spec is 28psi (min 18 max 40 constant), and about 7.5 additional per 1000 rpm.
I got numbers directly from ford, and some from ford UK too. I also have docs that should performance of the stock pump as well as some with aftermarket pumps.
inis is online now
Old 09-21-2012, 01:06 AM   #7
burke_024
burke_024's Avatar
Fan#: 94039
Bad ferule on,the head connection everything is back to normal thnx guys
