Calling all 2012 focus members with a five speed manual transmission - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-20-2012, 12:45 PM   #31
Kabigon
Fan#: 88299
Points 4,568, Level 43
Points: 4,568, Level: 43 Points: 4,568, Level: 43 Points: 4,568, Level: 43
Level Up 9% Completed
Forum Activity 14%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by TiStick View Post
The active grill shutter one shows up(12B41), they sent me a letter. Was it an actual recall? Like I said, I'll talk to my service department next week.
12B41 is a FSA (Field Service Action) rather than a TSB.
Kabigon is offline
Old 09-20-2012, 12:46 PM   #32
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
What I Drive: LesVagon
Points 3,706, Level 38
Points: 3,706, Level: 38 Points: 3,706, Level: 38 Points: 3,706, Level: 38
Level Up 38% Completed
FF Reputation: 16 TiStick Great Standing Member
Originally Posted by Pretherius View Post
I concur. Bring it into the dealership and anticipate them performing 12-5-5. I don't believe this it's a 100% fix but I think you'll see an improvement.
I'm semi-concerned that you experience this even after the car is warmed up. I sort of doubt it's anything but it if this worsens you may have something else going on. Mine only does it with a cold drivetrain, and it's definitely worse in cold ambient temps.
This. I do 26 miles each way to work. Really not that much to warm up before I shut off for 12 hours.
Sonic's Mk3 Crew #11
Hatch Nation#163
Originally Posted by suss6052 View Post
Watch out for the D
TiStick is offline
Old 09-20-2012, 09:00 PM   #33
DAC17
Fan#: 85128
What I Drive: 2012 Tricoat Yellow Blaze SE
FF Reputation: 1 DAC17 Good Standing Member
I have a 10/11 build 5-speed, and no similar problem here. I do regularly use 91 octane E10. Maybe that helps, maybe not.
2013 Tangerine Scream ST
DAC17 is offline
Old 09-20-2012, 09:51 PM   #34
hel112570
Fan#: 104067
What I Drive: 2012 Black Focus S
FF Reputation: 1 hel112570 Good Standing Member
Mine does the same thing it's definitely noticeable on a cold start and takeoff. It does it about the exact same spot every morning.
Other issues:
I've also noticed the absurd amount of rev hang it has in between shifts. The rpms will stay high for about 2-3 seconds, this is especially bad when I have the throttle opened up.
Another thing I have noticed is a knocking coming from the left side of the car near the bottom of engine. When I engage the clutch it goes away and when I let it out it comes right back. It's easily reproduced.
Last thing, if tapping the throttle in between 2-3k rpm i.e. give it enough gas at idle to make reach 3k and then let off and when it hits 2k give a quick burst, it sounds like a diesel tractor. Funny enough my motorcycle also did the same thing before the engine went. If I watch the tachometer I can see it jitter when the idles drop back down after giving it the burst of throttle. It doesn't jitter more than 2 or 3 hundred rpms, but it most definitely there. I've only got 11K on the car.
Any thoughts?
hel112570 is offline
Old 09-21-2012, 10:47 AM   #35
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,469, Level 36
Points: 3,469, Level: 36 Points: 3,469, Level: 36 Points: 3,469, Level: 36
Level Up 80% Completed
Forum Activity 18%
Hey folks,
Just a reminder: If you are experiencing any of these symptoms and you haven't already done so, please PM me your VIN, mileage estimate, preferred servicing dealer, and a daytime phone number. I'll get each of you escalated to your regional Customer Service Manager; they'll get in touch with your dealers and work on a solution.
Have a great weekend!
-Crystal
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 09-21-2012, 11:20 AM   #36
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
Originally Posted by BetaDnB View Post
I hadn't noticed any build dates attached to TSB 12-5-5. I can tell you from experience it's a definite fix.
Well, mine was built after the TSB was released. Logic would tend to dictate that they applied the TSB calibration to the assembly line. Probably not, though. Either way, it is not listed in my ETIS.
2.0L GDI AND MANUAL TRANSMISSION - CALIBRATION UPDATE - VARIOUS DRIVABILITY IMPROVEMENTS - BUILT ON OR BEFORE 2/29/2012
Publication Date: May 8, 2012
FORD: 2012 Focus
This article supersedes TSB 12-1-4 to update the Title, Issue Statement and Service Procedure.
ISSUE:
Some 2012 Focus vehicles equipped with a 2.0L gasoline direct injection (GDI) engine, manual transmission and built on or before 2/29/2012 may exhibit diagnostic trouble codes (DTC) U0422, P00D2, P068A, P0850, P2610, P2832, P286F, P2877, P00C6, P0607, P0457 and/or P06B8 and may be accompanied by engine drivability concerns. Refer to the calibration content for additional calibration details.
Just found where
Pm'ing Crystal
Hatch Nation#163
Watch out for the D
TiStick is offline
Old 01-23-2015, 03:54 PM   #37
SR71Blackbird
SR71Blackbird's Avatar
Fan#: 180081
What I Drive: 2013 Tuxedo Black Focus SE Hatch
Points 113, Level 2
Points: 113, Level: 2 Points: 113, Level: 2 Points: 113, Level: 2
Level Up 26% Completed
FF Reputation: 1 SR71Blackbird Good Standing Member
I have a 2013 SE 5spd, my car also shows signs of these problems, have been for the last 10k and i just rolled over 35...
SR71Blackbird is offline
Old 01-23-2015, 04:12 PM   #38
ELCouz
Fan#: 157898
What I Drive: 2012 focus SE hatchback candy blue
Points 1,841, Level 25
Points: 1,841, Level: 25 Points: 1,841, Level: 25 Points: 1,841, Level: 25
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 6%
FF Reputation: 1 ELCouz Good Standing Member
Originally Posted by 2012TI View Post
My issue is missing and hesitation in first and second gear mostly, does anybody else have this issue when taking off in first gear sometimes the car will miss and hesitate?? You do not notice this on the tack as if the engine was actually missing. I decided to drive the car down a long alleyway with buildings on each side to see if I could hear any spark knock in the engine. When the car does hesitate it does spark knock a few times right before hesitate? Almost like the spark plug is firing before the mixture is ready which results in that whole power stroke being missed. I have no check engine lights or codes present. Any help will be great thanks a lot.
Was the car cold during this?
Cold GDI engine = bad bad bad throttle response or hesitation on take off...
Mine hesitate all the time when RPM drop below IDLE threshold!
Also Throttle by wire introduce some noticeable delays
ELCouz is offline
Old 01-24-2015, 02:41 AM   #39
Armenian22
Armenian22's Avatar
Fan#: 117282
What I Drive: 2012 Tuxedo Black Ford Focus SE
Points 1,884, Level 25
Points: 1,884, Level: 25 Points: 1,884, Level: 25 Points: 1,884, Level: 25
Level Up 84% Completed
FF Reputation: 1 Armenian22 Good Standing Member
Other issues:
Any thoughts?
This. My focus has both of this present as well. The knocking noise however is not consistent. Some days it's there, some it's not.
Armenian22 is offline
Old 01-24-2015, 08:21 AM   #40
ELCouz
Fan#: 157898
Forum Activity 6%
Other issues:
Any thoughts?
MTX75 have gear rollover... it's normal
Gears will vibrate when In neutral..
RPM hang is for emission control... new manual car are like that these days.
All your question have been answered many times
Please do a little search on this forum
ELCouz is offline
