Head work - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-20-2012, 10:12 PM   #11
RedRiderr13
RedRiderr13's Avatar
Fan#: 98089
What I Drive: 2005 maroon zx5
FF Reputation: 1 RedRiderr13 Good Standing Member
ok, and any imput on what brand head gaskets to run? car was a dd, so im trying to get this all figured out this weekend if possible. and atleast get all the things i need to make it go smoothly. is felpro recomended?
RedRiderr13 is offline
Old 09-20-2012, 10:17 PM   #12
RedRiderr13
Fan#: 98089
vegas, thanks for your help, but i cant afford that right now, atleast not the new intake and tune on top of the head price, so im proboly just gonna end up running a ported 2.0 head. and put the intake money towards maintenance parts like water pump, fuel filter, timing chain guides thermostat, and a belt...< atleast thats the list soo far. if you guys wanna add anything, let me know.
Old 09-20-2012, 10:21 PM   #13
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,717, Level 76
Points: 13,717, Level: 76 Points: 13,717, Level: 76 Points: 13,717, Level: 76
Level Up 17% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
I'd be figuring out the c/r of the two. What is the difference in the 2 head gasket's? I'm sure the head bolts are the same, but check. Ask Vega's what he used & did. Also since your there I add a set of mild cams= stage 1's. I installed a set of crane's= made a difference.
felixthecat is offline
Old 09-21-2012, 04:43 AM   #14
VEGAS
VEGAS's Avatar
Fan#: 75680
What I Drive: 2007 Focus
FF Reputation: 4 VEGAS Good Standing Member
i put a whole 2.3L engine in car, However the head is same.. Intake bolts right up. To be honest I cannot see porting heads on a 2.0L doing much of anything. reason to port a head is for making more power with more air flow but so much is restrictive, mainly with turbo or something like that where the benefits of smooth is needed for air speed, your not going to do anything in way of making more power if you are just porting your heads.
here is a good tech post on it..
http://www.popularhotrodding.com/eng...g/viewall.html
with our engines and no tune or other advances your looking at what, 2 or 3 hp? you might gain more out of swapping your plugs our for AR-103s or something more simple.
if you just wanna kill time or have more planned by all means head down the yellow brick road.
I think your better off saving your $ and just getting something more. Even if you have a guy to do the work free, a port and polish needs a new valves to be done right , the Valves and other items will still cost $200+ when done or more.
VEGAS is offline
Old 09-21-2012, 07:36 AM   #15
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Installing the 23 is the best way to go. Add a 23 head is the 2nd best way. The 23 head flows better than a 20.
Old 09-21-2012, 11:09 AM   #16
VEGAS
VEGAS's Avatar
Fan#: 75680
yea, without the larger pistons and longer stroke that a 2.3L provides doing a 2.3L head is a far cry from a entire 2.3L engine as far as power.. I would do all the upgrades that would make a trip to a 2.3L engine more enhanced.
VEGAS is offline
Old 09-24-2012, 11:06 PM   #17
RedRiderr13
Fan#: 98089
ok, i may just run a stock 2.0 to get me running again. then start saving for the 2.3 setup. and one day i will get the tune, proboly before the head setup. random question though, how bad will the 2.3 intake kill gas milage??
Old 09-26-2012, 05:55 PM   #18
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
23 gets you the grunt your missing.
It'd be great if you add a 23 manifold w/ a 23 head & get the imtv to work on a 20 car. You'd need the pcm from a 23 car & if your there, I'd install the 23 motor too. I'd be figuring out the costs involved= the head, I/M & the pcm vs the whole 23 motor. The grunt vs the cost. Do a BSD plug & that gets you more & holds more oil too. Say if the head/manifold & pcm is say 800. & for a little more say 500. gets you a 23= Thats what I be doing then. Add a set of mild cams, add a bsd plug, header & tune to start w/ & then your wondering= I come I didn't do this before?
Old 09-26-2012, 09:41 PM   #19
VEGAS
VEGAS's Avatar
Fan#: 75680
is the gasket on the oil pan of the 2.3L reusable when you do the BSD or is it silicone/cork? or need a new rubber? I have not done mine yet, but found a dirt cheap BSD on ebay... Just $27.50
VEGAS is offline
