Old 09-17-2012, 08:38 PM   #1
shadownman
Fan#: 95629
What I Drive: 2004, Red Focus ZX5 & 2000 ZX3
FF Reputation: 1 shadownman Good Standing Member
Can Rack & Pinion Be R&R Without Dropping subframe?
Question for the group. I have a 2000 Ford Focus ZX3 (need to update my car status) that has an internal leak and fluid is running along tierod and collecting on inside tire rim. My book states to drop the sub-frame, but after 12 years of CT winters, the sub-frame mount bolts are pretty much fuse-rusted on and will not budge with ½ break bar. Question, can the R&P be replaced by pulling it out the side, maybe undo the passenger motor mount and lift up the engine a bit on the oil pan? Any feedback would be most appreciated.
shadownman is offline
Fan#: 1
Old 09-18-2012, 01:20 AM   #2
elsolo
elsolo's Avatar
Fan#: 96835
FF Reputation: 9 elsolo Good Standing Member
When I did the rack in my 03, I didn't completely drop the subframe but I did lower it down in the back about 3" for access. Once unbolted, I did slide it out the side through a wheelwell.
I think you will need to at least get the subframe lowered down some to do the job.
elsolo is offline
Old 09-18-2012, 01:30 AM   #3
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
FF Reputation: 42 sleepyboy Great Standing Member
Buy-Sell-Trade Rating: (10)
^ Yup, the bolts holding the sub frame in are super long. You can loosen the bolts and drop the rear of the sub frame. This should give you just enough room to unbolt it and replace it like said in the post above mine. This is also how you can replace the front sway bar or front sway bar bushings.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 09-18-2012, 01:56 AM   #4
elsolo
elsolo's Avatar
Fan#: 96835
I think his problem are the bolts are seized up with rust, so he was hoping to do it without removing the subframe bolts. I don't think that will be possible, but it very well may be possible and nobody tries it.
elsolo is offline
Old 09-18-2012, 02:03 AM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Doubtful he'll be able to do it with out dropping the sub frame. If they are rusted get a bigger bar. Also soak them in PBblaster for a few hours before trying again. It will help penetrate the rust.
Moderator for
Technical Chat
Old 09-18-2012, 04:44 AM   #6
shadownman
Fan#: 95629
I was hoping to not mess with the bolts, they are rusted up and look almost like they are fused to the subframe. I can try with a cheater bar, but don't want to snap the bolt heads. What a PITA, will know more this weekend after I go junkyarding for replacement R&P
Old 09-18-2012, 04:52 AM   #7
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Spray them down every day with PB blaster before you work on them. Also they are the biggest bolts on the whole car. If you snap one off I will be very surprised.
Moderator for
Technical Chat
Old 09-18-2012, 05:56 AM   #8
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 2002 Land Yacht (Windstar)
FF Reputation: 263 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
Wire brush and PB Blaster. You might also want to try some SAE sockets to see if you can find one that fits tightly if metric sizes are loose fitting.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 09-18-2012, 06:11 AM   #9
shadownman
Fan#: 95629
I will make sure to report back this weekend on how this goes. I'll try to only loosen up the rear large bolts and get that gearbox out. First thing is finding a decent R&P/Gearbox at a junkyard. Those are much easier, most of the time engine is gone!
Old 09-18-2012, 12:22 PM   #10
elsolo
elsolo's Avatar
Fan#: 96835
I bought a remanufactured unit for $125, no core charge, and came with new inner and outer tie rods.
elsolo is offline
