Ford Racing Focus Handling Kit for 2012 Focus - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-18-2012, 11:28 PM   #11
Joey D
Joey D's Avatar
Fan#: 86391
What I Drive: 2012 Tuxedo Black Titanium 5-Dr
FF Reputation: 2 Joey D Good Standing Member
Originally Posted by Ausv7 View Post
If you actually go and read the description on the eibach website it will show you what all the kit i posted comes with.
Per the Eibach website the Sport Plus kit doesn't come with struts/shocks:
Originally Posted by Eibach
Step Up to the Performance of SPORT-PLUS and Save 10%
All Eibach Systems and Suspension Packages Include a 10% discount over buying individual kits.
SPORTLINE + ANTI-ROLL-KIT = SPORT-PLUS
Performance Springs and Sway Bars = Superior Handling for the Serious Enthusiast
Stop Quicker, Corner Faster and Better MPG!*
Simple Bolt-On, No Modifications: Install, Set the Alignment and Carve
Million-Mile Warranty
If you crave the corners - the Eibach SPORT-PLUS delivers. The Eibach SPORT-PLUS handling packages include our legendary Eibach SPORTLINE springs along with the matching ANTI-ROLL-KIT Sway Bars. The Eibach SPORTLINE spring kit lowers your car's center of gravity, reducing squat during acceleration, body roll in corners and excessive nose-dive under braking. Add the Eibach ANTI-ROLL-KIT Sway Bars - with increased design stiffness over stock Sway Bars - and you get pure, balanced-handling perfection.
With the Eibach SPORT-PLUS installed you will immediately experience precise turn-in response, improved handling and cornering grip - in any performance-driving situation. The Eibach SPORT-PLUS works well with both factory or aftermarket performance dampers and shock absorbers.
* Your results may vary. As we have learned from racing and independent testing has proved - lowering your car or truck's ride height also improves your aerodynamic efficiency by forcing more air over the car and less underneath (where most of the drag is found on any vehicle), resulting in higher top speeds on the track and better MPG on the highway.
And here's the member who called Eibach about how useless TireRack is.
Originally Posted by nerdrage View Post
I called eibach about this because its not on their website. They are not making dampers for the Focus. Tirerack was supposed to fix this 2 months ago when I saw this kit and tried to pre-order it.
Here is the actual kit on Eibachs website
SPORT-PLUS (SPORTLINE Springs & ANTI-ROLL-KIT Sway Bars
Joey D is offline
Old 09-19-2012, 02:29 PM   #12
Ausv7
Ausv7's Avatar
Fan#: 84217
What I Drive: 2012 Black Focus, 1994 black F150
Points 2,641, Level 31
Points: 2,641, Level: 31 Points: 2,641, Level: 31 Points: 2,641, Level: 31
Level Up 28% Completed
FF Reputation: 3 Ausv7 Good Standing Member
Cool cool. Thank you for posting the info on the kit. :] That will defiantly clear up all the confusion with the kit. even though that kit does not come with shocks and struts i would recommend it over the Ford racing. The ford racing kit only drops you a little under an inch if your not looking for low but from hearing from one of my friends ride quality is not so great. The eibach sportline kit will take away almost all of the wheel gap from what i have seen and have heard it is much better ride quality even though it doesn't come with shocks.
Team Focalize
rebeldevil.com
Texas Focus Round Up Best Stance
Ausv7 is offline
Old 09-19-2012, 02:43 PM   #13
Murder22
Fan#: 103990
What I Drive: 2012 Tuxedo Black S
FF Reputation: 1 Murder22 Good Standing Member
Ford racing suspension kit
I work for Ford and i hvae just ordered this kit. I spoke with a Ford racing rep and he told me that this full kit is the Euro ST suspension. It is the all the parts from the Euro spec 2013 Focus ST. I am new to the Forum hello everyone.
Murder22 is offline
Old 09-19-2012, 02:54 PM   #14
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,180, Level 56
Points: 7,180, Level: 56 Points: 7,180, Level: 56 Points: 7,180, Level: 56
Level Up 15% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
^sssiiiiikkkkkk!!!!!!!!!
FSWerks stg2 w/ water/meth; Cossie intake.
PSUrivie is offline
Old 09-19-2012, 05:44 PM   #15
DEREKC
Fan#: 82958
What I Drive: 2012 Kona Blue Ford Focus Titanium
FF Reputation: 2 DEREKC Good Standing Member
I also called Ford Racing and was given more details on the kit. He did state that some of the parts had Euro part numbers. The springs are the M-5300-S that are already available on the Ford Racing Parts website. The kit also comes with both front and back Shocks/Struts, and both front and back stability bars. The bushings and all of the misc hardware is also included so that every piece is replace during the installation.
I will be giving Steve a call at Tousley Ford tomorrow to order the kit. The new ETA is 12 October 2012. http://tousleyfordparts.com
DEREKC is offline
Old 09-19-2012, 06:53 PM   #16
gsrcrxsi
Fan#: 103577
What I Drive: not a Focus
FF Reputation: 1 gsrcrxsi Good Standing Member
Sounds like a great kit if the dampers are up to snuff. Good value at 800.
Good quality dampers alone can exceed 800
gsrcrxsi is offline
Old 10-11-2012, 01:57 PM   #17
focusstu
Fan#: 103157
What I Drive: 2012 Oxford White Focus S 5MT
Points 533, Level 10
Points: 533, Level: 10 Points: 533, Level: 10 Points: 533, Level: 10
Level Up 66% Completed
FF Reputation: 2 focusstu Good Standing Member
I just checked the price at Levittown Ford, which sells mail order. The price for the handling pack, part number M-FR3-FS, is $621.50 ($985.00 list). It sounds like a deal.
focusstu is offline
