2008 focus sel - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-17-2012, 06:20 PM   #1
Bigg Flaco
Bigg Flaco's Avatar
Fan#: 96257
What I Drive: 2014 Focus SE 5SP
Points 260, Level 5
Points: 260, Level: 5 Points: 260, Level: 5 Points: 260, Level: 5
Level Up 20% Completed
FF Reputation: 1 Bigg Flaco Good Standing Member
2008 focus sel
what tools do i need to remove the front caliper and pads?
5 speeds 4 windows down, thats how i roll
Bigg Flaco is offline
Old 09-19-2012, 01:26 PM   #2
bugman
bugman's Avatar
Fan#: 98366
What I Drive: 2010 Sangria Red SES
FF Reputation: 1 bugman Good Standing Member
There are two caliper bolts that are the caliper slides, they are 14mm. Use a socket and ratchet to un-screw them. The caliper then comes off and the pads slide off. Keep in mind you don't want to have the caliper hanging by the rubber brake line, so if you have some rope or even string to hang from the spring thats what I have used in the past.
Don't qoute me but I think the torque specs on the caliper bolts are 35 ft. lbs. If they are over tightened they can break off during driving because of the heat of the caliper when braking. If you are worried about them coming loose buy some blue thread locker for them. It will keep them from coming loose but allow you to take them out when needed.
Here is a Tousley ford diagram of the front brakes. #7 is the caliper bolts, which are actually on the back of the caliper.
2010 Sangria Red SES #051 Sedan
Autolite AR 103 Sparkplugs, Ram-Air AIRAID CAI, LED Tails
bugman is offline
Old 09-19-2012, 07:09 PM   #3
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
No "special" tools are needed. Metric wrenches and /or sockets are needed. A screw driver to remove brake springs, a pair of pliers and a C-clamp to compress the caliper piston (although I have also used some big channel locks and a small block of wood to do so).You'll need a small open end wrench (7 or 8mm if I remember correctly) and some clear vinyl or rubber hose (that will fit on the brake bleeder fitting) to bleed the system (bleed all four corners not just the fronts).
Geezer is offline
