Scheduled 30K DCT maintenance? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-17-2012, 08:16 PM   #21
Kabigon
Fan#: 88299
Points 4,575, Level 43
Points: 4,575, Level: 43 Points: 4,575, Level: 43 Points: 4,575, Level: 43
Level Up 13% Completed
Forum Activity 13%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by dan50 View Post
I think there is a drain plug on the Focus trans so no need to replace a gasket, the DCT fluid capacity is quite small (< 2 quarts) and there's no filter, so $ 200 seems pretty outrageous to me. As a matter of fact, this should be well within the capabilities of most DIYers. Just make sure you buy the fluid from a Ford dealer.
Yes, $200 is outrageous.
Since there is a drain plug and a fill plug, it is not a difficult DIY job and a piece of cake for someone with a lift (such as your local Ford dealer).
Kabigon is offline
Old 09-17-2012, 08:35 PM   #22
blank102
blank102's Avatar
Fan#: 96549
What I Drive: 2012 Sterling Grey SE HB
Points 2,746, Level 31
Points: 2,746, Level: 31 Points: 2,746, Level: 31 Points: 2,746, Level: 31
Level Up 98% Completed
Forum Activity 2%
FF Reputation: 1 blank102 Good Standing Member
$200 is pure rip off.
I had the transmission oil changed in my GMC (Allison built) and it was no where near that costly.
blank102 is offline
Old 09-23-2012, 12:41 PM   #23
focusstu
Fan#: 103157
What I Drive: 2012 Oxford White Focus S 5MT
Points 533, Level 10
Points: 533, Level: 10 Points: 533, Level: 10 Points: 533, Level: 10
Level Up 66% Completed
FF Reputation: 2 focusstu Good Standing Member
My wife's car is a 2005 Honda Odyssey, purchased new. The manual calls for a trans fluid change at 30,000 miles under severe operating conditions but otherwise not until 90,000. However, my dealer (whom I trust) and several Honda forums tell me that Odyssey transmissions are notoriously weak, and that a fluid change will extend the tranny's life.
If you plan to keep the car past the mileage or time limit on your ESP plan, it might be worth thinking about changing the fluid. This is especially true since the Powershift trans is new and has had a lot of teething problems.
focusstu is offline
Old 09-23-2012, 12:49 PM   #24
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,243, Level 67
Points: 10,243, Level: 67 Points: 10,243, Level: 67 Points: 10,243, Level: 67
Level Up 49% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 26 suss6052 Great Standing Member
The Odyssey uses a traditional torque converter and planetary gear set based automatic transmission and depends on the fluid to operate properly as it is a hydraulic transmission. The DCT is essentially two manual transmissions in a single gear case. Ergo there is only a small volume of fluid used to cool the gears and allow for proper meshing. I don't know of any manual transmissions that call for a fluid change at 30k intervals. Just because it is shifted by servos/ electric motors that also apply and release the clutches doesn't mean it has the same fluid change requirement as a planetary automatic transmission.
Planetary automatic transmissions with torque converters use up to 16 quarts of fluid and the fluid is especially sensitive to heat and breaking down, that is why they need their fluid changed much more regularly. If you wait too long the metal fragments in the fluid might be the only thing that allow the brake bands and wet clutches between planetary gears to actually work.
suss6052 is online now
Old 09-23-2012, 01:16 PM   #25
focusstu
Fan#: 103157
I understand that the DCT is entirely different from a traditional auto. The DCT still has bearings, synchros, seals, and meshing gears. This design appears to be Ford's first try, so erring on the side of caution might be worth thinking about, especially as info becomes available on forums, etc.
focusstu is offline
Old 09-23-2012, 03:51 PM   #26
jamnesta
Fan#: 93256
What I Drive: 2012 Titanium
FF Reputation: 2 jamnesta Good Standing Member
To me this is the most sensible post. With all the concerns about this transmission, not the least of which includes "grinding noises" (usually resulting in metal shavings ) there would seem to be little room for debate...?
jamnesta is offline
Old 09-23-2012, 04:29 PM   #27
Kabigon
Fan#: 88299
Forum Activity 13%
Problem with the actual transmission (i.e. problems that are not related to the clutches) are rare with the DCT.
The only exception is a problem with leaking seals.
Kabigon is offline
Old 09-23-2012, 05:08 PM   #28
Timbo64
Fan#: 92890
What I Drive: 2012 Silver Focus SE Sport 5 Door
Points 253, Level 5
Points: 253, Level: 5 Points: 253, Level: 5 Points: 253, Level: 5
Level Up 6% Completed
FF Reputation: 1 Timbo64 Good Standing Member
http://www.youtube.com/watch?v=2wMyXSCnqKI
It talks about this subject at 3.00 in this Ford Retailer Education & Training video on the Ford DCT transmission.
From the video: "It's also maintenance free. Transmission fluid never needs to be changed for the life of the vehicle which is defined as 10 years or 150K miles."
The 2012 Focus owners guide says that a transmission fluid change is not required until 150K miles.
I always change my engine oil sooner than is required by the owners manual, but I don't want the service department messing around with my DCT unless there is a problem with it.
Timbo64 is offline
Old 09-23-2012, 05:31 PM   #29
jbird1955
jbird1955's Avatar
Fan#: 48235
What I Drive: 2014 Tuxedo Black Ti Hatch
Points 788, Level 14
Points: 788, Level: 14 Points: 788, Level: 14 Points: 788, Level: 14
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 jbird1955 Good Standing Member
Great points all.
I'm going to seek out the dealer from whom I purchased the car from. I walked away from them as I found the service manager to be a bit of a DH.
What I wish would happen is for one of the Ford folks here to PM me and let me know what gives. I'm not opposed to the $200.00 fluid change, I'm questioning the "maintenance free" aspect of the DCT - as I understood it to be presented as.
Joe
Ford Focus 2014 Hatchback 300A Titanium w/ Moonroof
Tuxedo Black Metallic
jbird1955 is offline
Old 09-23-2012, 05:52 PM   #30
Timbo64
Fan#: 92890
Points 253, Level 5
http://blogs.automotive.com/ford-dee...ion-42051.html
"One benefit, Ford says, is that the dual-clutch transmission is maintenance-free for 150,000 miles. The dual-clutch transmission is currently only offered in the Fiesta and Focus but the technology is expected to catch on with other models in Fordís lineup."
Timbo64 is offline
