'04 svt abs, trac control ande brake light come on - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 09-17-2012, 04:19 AM   #1
airrikk17
airrikk17's Avatar
Fan#: 9448
What I Drive: 2004 euro svt pitch black
Points 86, Level 1
Points: 86, Level: 1 Points: 86, Level: 1 Points: 86, Level: 1
Level Up 72% Completed
FF Reputation: 1 airrikk17 Good Standing Member
on colder mornings when i start up my 04 svt the abs , traction control and e brake light come on and stay on. a couple of times i was able to turn off car and re start and they would go out. but recently it took driving the car a bit and then restarting to get the lights to go out.
i checked the fluid level, and it looks to be at correct level. the wiring connector at the lid seems to be connected.
over the last year i have replaced the front and rear brake pads and rotors , new clutch kit , and lower control arm bushing. but none of this has been recently.
anyone have the same issue and figure out what the problem was ?
thanks for the responses.
'04 focus svt eap zx3 black
airrikk17 is offline
Old 09-17-2012, 05:58 AM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 17,859, Level 85
Points: 17,859, Level: 85 Points: 17,859, Level: 85 Points: 17,859, Level: 85
Level Up 2% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
FF Reputation: 48 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
Any pending trouble codes?
Would sound like a Wheel Speed Sensor is on the fritz ...
Don't "think outside the box".
There is no box.
Do it correct, or do it twice.
iminhell is offline
Old 09-17-2012, 07:36 AM   #3
Mile30
Mile30's Avatar
Fan#: 74686
What I Drive: '03 ZX3
Points 7,658, Level 58
Points: 7,658, Level: 58 Points: 7,658, Level: 58 Points: 7,658, Level: 58
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
Forum Activity 6%
FF Reputation: 7 Mile30 Good Standing Member
Buy-Sell-Trade Rating: (10)
I redid my rear brakes less than six months ago... and found out I forgot to replace the tone ring for the rear wheel speed sensors. Perhaps that could be something you overlooked.
You could check the rear speed sensors with a voltmeter to see if they are creating that small bit of voltage as the wheel turns; or visually, if they're seated differently or too far back.
Mile30 is offline
Old 09-17-2012, 10:28 AM   #4
sailor
"Elder"
sailor's Avatar
Fan#: 57268
Points 8,922, Level 63
Points: 8,922, Level: 63 Points: 8,922, Level: 63 Points: 8,922, Level: 63
Level Up 58% Completed
Forum Activity 99%
FF Reputation: 69 sailor Excellent Standing Member
Or you MIGHT have an issue like I did with my cluster, had random brake warning light that DIDN'T correlate with any of the switches that turn it on!
Didn't "solve" it until I replaced the cluster to get one with a tach., also had a random failure of the trip odometer with an "eee5ee" code showing on the readout...
Both would SOMETIMES reset after turning it off & re-starting the car...
Just an FYI in case you don't find another cause, you could check it if you have a "bud" with a similar car to temporarily switch out the clusters (it's quick & easy).
luck!
sailor is online now
Old 09-17-2012, 10:40 AM   #5
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 449, Level 8
Points: 449, Level: 8 Points: 449, Level: 8 Points: 449, Level: 8
Level Up 98% Completed
FF Reputation: 17 nilskje Great Standing Member
If you are able to "fix" the issue by , turning the ignition, of and on , and this mostly happends when cold, the ABS unit is most likely on the way of saying goodbye, only way to get any further with the faultfinding, is having a scan done on the ABS unit, and body computer, (sounds just like mine until I replaced it with a unit from the junkyard).
nilskje is offline
