Known issues with first gens? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-18-2012, 08:40 AM   #11
mainest
mainest's Avatar
Fan#: 60163
What I Drive: '04 Red Euro SVT
Points 1,866, Level 25
Points: 1,866, Level: 25 Points: 1,866, Level: 25 Points: 1,866, Level: 25
Level Up 66% Completed
Forum Activity 2%
FF Reputation: 8 mainest Good Standing Member
Buy-Sell-Trade Rating: (12)
I replaced the brake master cylinder and the alternator on my d-tec at less than 50k. Also replaced the entire motor at 95k, although that is VERY unusual. Other than that, and the required maintenance, I've been very pleased with the Focus, my first American car. But, watch out for the modding bug! Good luck.
mainest is offline
Old 09-18-2012, 09:50 AM   #12
D34TH_v69
D34TH_v69's Avatar
Fan#: 86526
What I Drive: 2003 white SE
FF Reputation: 1 D34TH_v69 Good Standing Member
Originally Posted by PRSman25 View Post
Whats this bit about the ignition cylinders? And how would one know if it needs to be replaced?
The cylinder that you put your key into to start the car. The cylinder with the hole that's offset is probly gonna fail, the ones with the hole in da middle is fine. And actually, I have to replace my alternator as I just found out the other day that the diode is bad :/ but I've never had to replace an O2 sensor on mine... Yet
D34TH_v69 is offline
Old 09-18-2012, 12:47 PM   #13
PRSman25
Fan#: 103893
What I Drive: 2001 Black ZX3
FF Reputation: 1 PRSman25 Good Standing Member
D34TH_v69:
Are you running a Zetech, D-tech, or the SPI?
So basically I should ensure that the ignition cylinder has been repaired?
Does anyone have a photo of a "bad" cylinder vs. a "good" cylinder they could share or refer me to?
PRSman25 is offline
Old 09-18-2012, 01:13 PM   #14
SD_Rider
SD_Rider's Avatar
Fan#: 103846
What I Drive: 2002 Blue SVT
FF Reputation: 1 SD_Rider Good Standing Member
If I had a pic of mine, I would show you a bad one. hahah!
(it's broken)
SD_Rider is offline
Old 09-19-2012, 02:26 PM   #15
D34TH_v69
D34TH_v69's Avatar
Fan#: 86526
I've got the 2.0 zetech. I dont think you can really tell just by looking at it If its broken, mine looked normal when it broke. When mine broke the key got stuck in the ignition and I couldn't get it out or turn it at all. Idk what my step dad did to get it out but now it works fine. If you know how to do it just take the tumblers out of the cylinder, I haven't had a problem since we did that and didn't cost me anything. If you have the cylinder with the hole in the middle u don't have to worry.
Old 09-19-2012, 02:53 PM   #16
evanmdzx3
evanmdzx3's Avatar
Fan#: 94289
What I Drive: 2007 Silver ZX3 SE
FF Reputation: 1 evanmdzx3 Good Standing Member
i have an 07 and my alternator went at 55k
"If I'm not driving than I'm not living" - ME
Hatch Nation #166
evanmdzx3 is offline
Old 09-19-2012, 05:45 PM   #17
PRSman25
Fan#: 103893
Alternators are so expensive on these things ><
Taking the tumblers out seems like the easiest and quickest fix, am I right?
I might go with the upgraded Explorer cylinder from a locksmith though...
PRSman25 is offline
Old 09-20-2012, 08:17 PM   #18
02Zetechse
02Zetechse's Avatar
Fan#: 65832
What I Drive: 2002 Satin Black SE
FF Reputation: 6 02Zetechse Good Standing Member
just a bit of info , its Zetec , no H on it ... I have had to replace several rear wheel bearings in mine, go OEM right off
Current : 2 15s 149.5@56hz 2k rms Previous Trunk box 1 18 ,146.4@43hz 3500rms,Sony 12s 145.6@63hz
02Zetechse is offline
Old 09-20-2012, 08:49 PM   #19
PRSman25
Fan#: 103893
See you live in Ohio Mr. 02Zetechse (with an H I might add!) whereas I live in Florida, and I've read up on the wheel bearing issue, and it seems that the vast majority of them are coming from Northern states that see quite a bit of snow and thus see a lot of salty roads. Am I right?
But I shall definitely go OEM if they appear to be an issue. Thanks for the heads up!
I'm actually going to check out a couple ZX3s tomorrow. Super stoked about it.
PRSman25 is offline
Old 09-21-2012, 01:22 AM   #20
touchy
Fan#: 104076
What I Drive: 2000 Silver ZX3
FF Reputation: 1 touchy Good Standing Member
For my 2000 ZX3 with 165,xxx, I've had to replace the following:
  • Front Struts/Springs (one of the springs snapped)
  • Coolant reservoir (blisterd and started leaking on the underside)
  • Lower Radiator Hose To Water Pump Connector (Part #8290)
  • Various Coolant Hoses
  • Thermostat Housing (once at 60,xxx, and again at 160,000)
  • Timing Belt / Serpentine Belt
  • Motor Mounts (twice)
  • Corroded Battery Cable
  • Ignition Cylinder
Mostly general maintenance stuff, but overall it's been a reliable vehicle. Also a note on the ignition cylinder, when mine locked up, it was from the wafer retainer. I just removed the wafers (probably insecure but still requires PATS to start), replaced the retainer, and I haven't had a lock up sense. It still requires a ford style key to be inserted, and I can remove the key whilst the vehicle is 'on' but it works good enough.
touchy is offline
