Snorkel Delete - Page 29 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-08-2013, 09:10 AM   #281
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
Lightbulb
Looking at a ST air box after we remove the snorkel, the resonator box under the air box where the newmission hose would go and just seal the hole we have an 2013 ST air box only piece missing is its snorkel which is just a one inch flair. It doesn't go though the rubber flap. Might go to home depot and check out a few things connect two hoses from the snorkel tubes down to the grill cover that the newmission cuts and use something like conduct threaded ends and barbs plastic of course to attach the hoses. If it works I'll try to post pictures.
Seminoles is offline
Old 06-08-2013, 09:42 AM   #282
sekazi
sekazi's Avatar
Fan#: 114026
What I Drive: 2013 Ford Focus Ti Tux. Sedan
Points 249, Level 4
Points: 249, Level: 4 Points: 249, Level: 4 Points: 249, Level: 4
Level Up 98% Completed
FF Reputation: 1 sekazi Good Standing Member
Originally Posted by nkasco View Post
yes and yes, the first image is the snorkel itself, the second image restricts airflow which unless removed or cut you will not notice appreciable gains.
i just removed mine yesterday, didnt remove the flaps or cut them and i can definitely notice the car being much smoother. it seems to be much more forgiving when downshifting as well. idle is much smoother.
i wasnt sure if it was all in my head so i had my dad (who has a Ti version aswell) take it for a spin and he said he was definitely able to notice the difference.
it looks like ill be removing my flaps once i get the chance, just a heads up: the pins you remove are two pieces, take the top part out first as it restricts the outer pin from contracting when you lift up, rather than just yanking the whole pin out at once and breaking it (as i did with 2 of them before i realized what i was doing lol)
Thanks for the help. I will get to removing both sometime soon.
Originally Posted by dyn085 View Post
I don't think that cutting or removing the flap overly benefits or hinders anything. In theory it will help the air transition into that area due to the removed restriction, but I don't think that anything is overly affected by it. I initially had secured my flap down in the same manner as MetalMuffins as I do believe that that is beneficial. But outside of that or the Ford Racing Snorkel, I don't believe that there is enough to warrant the cut/removal in either direction.
So outside of making something that forces air in the rubber flap really makes no difference. I guess I will try going without the snorkel for awhile and see how that goes.
EDIT:
I removed just the snorkel. It was easy just like everyone said. I looked at the rubber flap a little more and I was wondering if I used something to raise the flap it should allow air into the area where the air intake is. I am thinkg that would be better than having to put a piece of plastic to hold it down.
sekazi is offline
Old 06-08-2013, 06:48 PM   #283
Samurai_Chris
Samurai_Chris's Avatar
Fan#: 96997
Location: Brisbane AUS, F.ukuoka JP, Atlanta GA, Australia
What I Drive: 2011 Ford Focus Sport
Points 445, Level 8
Points: 445, Level: 8 Points: 445, Level: 8 Points: 445, Level: 8
Level Up 90% Completed
Forum Activity 4%
FF Reputation: 1 Samurai_Chris Good Standing Member
sekazi, did you notice a difference in the note of the car when you accelerated? I found that mine has a more of a growl. But no real change while idling...
Never approach a Bull from the the front. A horse from the back. Or an Idiot from any direction!
2011 (German Built) MkIII Ford Focus LW MkI Sport Sedan
2011 (German Built) MkIII Ford Focus LW MkI Trend Hatch
Samurai_Chris is offline
Old 06-08-2013, 07:29 PM   #284
sekazi
sekazi's Avatar
Fan#: 114026
Points 249, Level 4
It seems a little beefier on startup and on acceleration. It does sound different though.
sekazi is offline
Old 06-09-2013, 09:09 AM   #285
focussel12
Fan#: 113865
What I Drive: 2012 Ford Focus SEL sedan silver
FF Reputation: 1 focussel12 Good Standing Member
Cool Noticeble
I remove my snorkel absout two weeks and try eather lid on and lid off with lid on feels restrictive like air is not getting there fast enough now lid off air is comsing from all placesyes theres hot air in there but ones is out from a red light or just getting out from parking its breathing way better plus im gettin a univer al heat shield I will let you guy know how that works take care drive fast but safe
focussel12 is offline
Old 06-09-2013, 01:52 PM   #286
Seminoles
Seminoles's Avatar
Fan#: 98405
Forum Activity 2%
This is what I did after removing bumper to re-install rubber air dam with the snorkel delete remember old school ram air. Putting the bumper back on I looked though the headlight opening the snorkel area gets its air from around the headlights so there was this dimple right in front of the snorkel opening so why not but learn from my mistake it is a little off the the left so if you do this start from right a little and grow from there, and before someone says something about cutting the straight rubber seal that runs along top it is about a 1/4 inch from sealing against hood anyway also removed the resonator box from bottom of air box and sealed it. This leaves the air dams for the radiator alone. I did notice that the area in front of the tire where tube CAI kits go is sealed up tight seams like the ones that seal the engine compartment off and leave filter in same area will get a lot of air around headlights lots of openings around there i can put my arms though... LOL
Cut
Old 06-10-2013, 04:41 PM   #287
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Forum Activity 2%
FF Reputation: 3 Juicedz Good Standing Member
^ This. Also keep in mind that our cars have adaptive learning, so any time there is a change that affects AFR it will start trying to re-learn parameters and optimize itself for the environment.
Pretty much what he said. If it makes you feel better After I installed my steeda cai and did the snorkel delete my car ran rough for the first few minutes, even the first few miles down the road and not just at idle. Eventually it smoothed out but it was bad enough that I was concerned. Very few have experienced this but I'm just giving my account of post modification to the intake tract.
'13 Oxford White Hatch 5-speed
injected 93 tune, steeda intake, e-focus rmm
Hatch Nation#24 172whp 157wtq
Juicedz is offline
Old 06-11-2013, 12:37 AM   #288
Seminoles
Seminoles's Avatar
Fan#: 98405
Forum Activity 2%
That's why I take off the negative cable before every mod not sure if these new ones will go into learning mode this way now but it dose help to not let the smoke out if you cut a wire your not suppose too last thing I check before butting things up and a quick touch with the cable will let you know if there is short.
Old 06-13-2013, 02:06 AM   #289
Seminoles
Seminoles's Avatar
Fan#: 98405
Forum Activity 2%
Got the K&N drop in filter the other day put it in with a little bit of a problem getting the disk part the seat in the grove and the dealer striping the two screws next to it didn't help since they are the only ones that checked the stock one. Did the long drive to work today got 48.9 MPG @ 70 MPH that is what I use to get @ 60 MPH temp was 95 too so I would say it went up 5 MPG with the snorkel delete drop in K&N and opening up under the hood like in the old days.
Old 06-14-2013, 11:04 AM   #290
Adam The Gnome
Adam The Gnome's Avatar
Fan#: 115670
What I Drive: 2013 Ingot Silver S
FF Reputation: 1 Adam The Gnome Good Standing Member
I too seem to have found a little mpg gain after the snorkel delete. Cannot find a k&n filter at any box stores. It is e-2993 you guys are using?
Adam The Gnome is offline
