Go Back   Focus Fanatics > Ford Focus Tech Discussions > DURATEC Ti-VCT Performance (2012-2013)
DURATEC Ti-VCT Performance (2012-2013) The place to chat about any Duratec 2.0L Ti-VCT engine performance, tuning and exhaust related upgrades.
Closed Thread
Old 02-25-2013, 02:17 PM   #191
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2012 SGM Ti HB w/Handling Package
FF Reputation: 20 dyn085 Great Standing Member
Originally Posted by Juicedz View Post
This mod did effect my gas mileage. In fact, the first 5 minutes the car ran very rough. It was hesitant and not smooth at all. This could be the PCM tryin to recaliberate for the air/fuel ratio. It seems to have smoothed out over the last 24 hours but I may put the snorkel back on to see if I can reclaim the loss in mpg's. I will add that I installed a steeda cai a few days ago prior to this but nothing abnormal occured with the cars behavior. I didnt notice as much of a decrease in fuel mileage with the cai but the snorkel/air dam delete did have an impact on my fuel mileage in town. Fwiw
There is no need for the PCM to recalibrate for this mod considering that you have the Steeda intake. It is an open box design, so any additional air that it needs it will pull from under the hood.
I can understand why you would feel that this is what has had the impact on your mileage, but most people with intakes have reported lower mileage. This is mainly because the additional air requires additional fuel. The snorkel delete is only going to be truly effective for those with a closed box system.
HN Member #161 *155 hp / 143 lb ft (DCT)*
Moderating-
DURATEC Ti-VCT Performance (2012-2013) / ST Performance (2013)
MK3 Focus / ST Focus
Sonic's MK3 Crew
Group Buy & Hot Deals
dyn085 is online now
Old 02-25-2013, 10:04 PM   #192
Juicedz
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
FF Reputation: 1 Juicedz Good Standing Member
The steeda intake still utilizes one of the two stock inlet tubes though doesn't it? The other is plugged with the supplied rubber puck.
Juicedz is offline
Old 02-26-2013, 10:24 AM   #193
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Yes it does, but because the intake is an open configuration it will not put the same negative pressure on the tract in order to suck air in. In essence, you could block the radiator support opening completely and the intake will continue to perform. I can't vouch for fuel economy in that configuration, but my assumption would be an increase over the Steeda kit with the radiator support open because warmer air burns more readily. Purely speculation.
In a closed box design, the only air that enters the engine must come through the radiator support. By shortening the intake tract, the engine has a shorter 'straw' to suck through. I even found *with my commute and driving style* that when I Newmissioned my intake I actually saw CAI intake mileage (worse mileage).
The reason this thread exists is because of the dyno testing I did on my car through various intake changes. I found no power increase by replacing the OEM filter with K&N drop-in filter but with further dyno-testing I found that removing the snorkel in-conjunction with the K&N that there was indeed a power increase. Transversely, there is no power increase by removing the snorkel and keeping the OEM filter as they are designed to work together quite well. Some members didn't understand what I was speaking of or how to remove it so I created the thread to illustrate.
Moderating-
Sonic's MK3 Crew
Old 03-05-2013, 11:21 PM   #194
Jkrumm
Fan#: 94565
What I Drive: 2012, Charcoal Gray Focus SE-Manual
FF Reputation: 1 Jkrumm Good Standing Member
How beneficial is deleting the snorkel?
Jkrumm is offline
Old 03-06-2013, 04:56 AM   #195
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
If you are on the stock filter, it isn't in terms of power. Idk in regards to mileage.
If you have an aftermarket filter then the combo should be good for approximately 10hp, 10 ft lb. My best dyno showed 12/11.
If you are running an aftermarket filter with the snorkel you will have better throttle response but a negligible power increase.
Moderating-
Sonic's MK3 Crew
Old 03-06-2013, 08:39 AM   #196
Jkrumm
Fan#: 94565
Oh ok I am running a K&N drop in filter
Jkrumm is offline
Old 03-06-2013, 03:37 PM   #197
Striker_VII
Fan#: 109509
What I Drive: 2013 Ruby Red SE
FF Reputation: 1 Striker_VII Good Standing Member
Sry newbie here but you don't believe that a snokel delete with a Steeda CAI would be benifital. Is that correct?
Striker_VII is offline
Old 03-06-2013, 04:11 PM   #198
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2013 Performance Blue Ti Hatch
FF Reputation: 15 jdubhack Great Standing Member
He's saying the gains would be negligible compared to the cheaper K&N drop-in and snorkel delete. Cost v. gain.
Sonic's Crew #015 "Werehog" --- HN005
April 2013 HOTM
jdubhack is offline
Old 03-06-2013, 04:15 PM   #199
Striker_VII
Fan#: 109509
Ok I understand. But as I have already installed my Steeda I could still benifit from some gain should I go through with the delete.
Old 03-06-2013, 04:22 PM   #200
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
Ehhh. I don't know about gain but you might experience more throttle response. But in the HP dept. I don't know that I'd use the word "gain."
April 2013 HOTM
jdubhack is offline
Closed Thread
