Go Back   Focus Fanatics > Ford Focus Tech Discussions > DURATEC Ti-VCT Performance (2012-2013)
DURATEC Ti-VCT Performance (2012-2013) The place to chat about any Duratec 2.0L Ti-VCT engine performance, tuning and exhaust related upgrades.
Closed Thread
Old 09-16-2012, 05:56 PM   #1
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2012 SGM Ti HB w/Handling Package
FF Reputation: 17 dyn085 Great Standing Member
Snorkel Delete
A few people have asked for a quick how-to for this, so I'll try to post up something visual. I don't have my snorkel anymore to show you, but when you pull back the black plastic you will see the difference between my pics and stock.
First you must pull the four push-pins out of the plastic where it attaches to the radiator support (just forward of the two intake runners) Also, I would slide the hood release out of it's holder where it makes the 90° bend. This will help you pull back the shroud.
After you pull back the shroud, you will see the snorkel on your car that is not in this pic. There are two push-pins on the drivers side and another push-pin on the passenger side. They are a little difficult if it's just you, fyi.
After you remove the snorkel you will see the plastic piece that keeps air directed to the radiator from under the whiskers. I only cut my drivers side (evidenced by the fingers), though others have cut both sides and some have even cut the whole top section. The only way I know to remove this (so far) without cutting is to remove the entire bumper cover.
Hopefully this helps. I would've set my snorkel in to show, but it went the way of the circular file. This is a mod that would never need to be reversed because incoming water would have to travel vertically 1-2" to get in the plenum, and dealerships won't be popping the top cover to verify it is installed.
At a minimum, the snorkel must be removed for the additional hp/tq of an aftermarket drop-in air filter.
Edit: All of these pics are with the front of the car on the bottom. Sorry, that's just how it came out.
Sent from my stupid phone.
HN Member #161 *155 hp / 143 lb ft (DCT)*
Moderator for-
ST Performance (2013)
MK3 Focus
ST Focus
Sonic's MK3 Crew
dyn085 is online now
Fan#: 1
Old 09-16-2012, 07:12 PM   #2
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
FF Reputation: 7 BetaDnB Good Standing Member
Now I get it! Thank dyn085!
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete
www.soundcloud.com/betadnb
www.facebook.com/betadnb
BetaDnB is offline
Old 09-16-2012, 07:18 PM   #3
ChrisRyan
Fan#: 97815
What I Drive: '12 SE Sterling Grey(5door) 5M 203A
FF Reputation: 2 ChrisRyan Good Standing Member
I just removed this tonight. The car is smoother at idle and off idle for sure. Havent had a chance to test it in real world conditions yet as we have gotten ~8inches of rain in 3 days. Thank you Jesus for the rain tho. Not sure if fabricating any sort of apparatus to redirect the air to the inlet left behind would yield any appreciable gains vs the hassle of fabing up and install.
ChrisRyan is offline
Old 09-16-2012, 07:35 PM   #4
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2013 Performance Blue Ti Hatch
FF Reputation: 15 jdubhack Great Standing Member
Good write up bro. This is definitely on the list of things to do as in...next weekend. Rep added.
jdubhack is offline
Old 09-16-2012, 07:43 PM   #5
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
No prob, glad it helps I've been meaning to do it for a while and just been slacking.
I've had the intent of fabbing up a fiberglass scoop to collect the width of the whisker and give it a better path to the radiator support, but I've also been slacking with that too. I don't think there would be an appreciable gain in anything other than possibly getting better mpg's, but don't quote me on it. In hindsight, I would have much rather done a scoop there than Newmissioned my airbox...
Moderator for-
MK3 Focus
ST Focus
Sonic's MK3 Crew
Old 09-16-2012, 10:01 PM   #6
Trav-E2.0
Thread Killer
Trav-E2.0's Avatar
Fan#: 8331
What I Drive: 2012 White SE Sedan
FF Reputation: 6 Trav-E2.0 Good Standing Member
Buy-Sell-Trade Rating: (12)
Whats funny is that when I read snorkel delete, I thought yall ment to take this out:
LOL! Makes alot more sense ...good job as always dyn085
12' Ox White SE Sedan 5spd 1/4 mile-15.8735@90mph
Mods: K&N Drop In, MS3 CP-E RMM, Eibach Sportlines, Steeda Rear Sway Bar, Anarchy Motive GM Shiftknob, 20% tint and Teh Debadge
Trav-E2.0 is offline
Old 09-16-2012, 10:09 PM   #7
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
That would have been a tragic mistake to make!!
jdubhack is offline
Old 09-17-2012, 02:15 PM   #8
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
So I got as far as getting it all apart. I only lost one clip! How necessary do we suppose it is to cut that flap for any kind of gain?
BetaDnB is offline
Old 09-17-2012, 02:31 PM   #9
vluc
Fan#: 10803
What I Drive: 2012 Focus Titanium, Ebony
FF Reputation: 1 vluc Good Standing Member
I cut both the drivers side and passenger side. If you want some gains, cut. If not, don't - but you went through enough effort to get that far you may as well cut. In for a penny, in for a pound.
vluc is offline
Old 09-17-2012, 04:34 PM   #10
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Cutting the flap allows air to accumulate behind the grill and be readily available for the intake.
Moderator for-
MK3 Focus
ST Focus
Sonic's MK3 Crew
Closed Thread
