2013 Ford Focus SE - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-15-2013, 08:38 AM   #51
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 904, Level 16
Points: 904, Level: 16 Points: 904, Level: 16 Points: 904, Level: 16
Level Up 4% Completed
Forum Activity 9%
FF Reputation: 4 Tiger-Heli Good Standing Member
Originally Posted by jimbaldwin1137 View Post
I thought I saw a thread somewhere that said the feature could be programmed without using the VIN number. Is that possible?
Not sure, but I don't think so.
It might have been possible on a 2012 SE, since the Sport Appearance package came with it, and it wasn't (I don't think) a numbered (201A, 202A) option package. I could be wrong, though. It wasn't possible on the S b/c the BCM didn't have the required circuitry and it wouldn't be required on a titanium b/c they have fogs standard, I think.
Also - OPsdad's dealer TRIED to program it and gave up, but I don't think they were willing to use a different VIN code.
Tiger-Heli is online now
Old 04-15-2013, 08:52 AM   #52
jimbaldwin1137
Fan#: 113389
What I Drive: 2013 Ford Focus SE Hatchback Silver
FF Reputation: 1 jimbaldwin1137 Good Standing Member
This has to be possible. I can't believe they would leave provisions for fog lights and not let you add them as an option. There is a huge market for aftermarket fog light kits. I would think that the first impulse of tons of other 2013 200a owners would be to add them using OEM parts since the provisions are there for the lights.
jimbaldwin1137 is offline
Old 04-15-2013, 09:13 AM   #53
Tiger-Heli
Fan#: 12379
Forum Activity 9%
Nothing HAS to be possible. I can almost guarantee they would prefer to make it as difficult as possible so that you spend the extra $2500 on the 201A or the Titanium.
Not sure what you mean "the provisions are there for the lights." The provisions are there for the Sony MFT as well, but that doesn't mean it's an easy install.
Old 04-15-2013, 09:22 AM   #54
OPsDad
OPsDad's Avatar
Fan#: 108661
What I Drive: 2014 Fusion Titanium AWD Moonroof
FF Reputation: 2 OPsDad Good Standing Member
I did try. The dealer refused to enter the program without the VIN. Wouldn't even discuss it. From someone else who WAS able to convince their do it (with a 2013, IIRC) you have to go in without the VIN. Then it can be done. If, at any point in the future, you have anything done in there (like a firmware update / TSB, etc) it has to be done again, because doing anything via the VIN will set it back to what the factory's records say.
The hardware is there in the BCM. The fuse is even there, although not used. ALL it takes is for someone to program the BCM.
Good luck. I really really mean that. I got my solution, eventually, I hope you get one, too!
SR #265 | "Quia currus certatus, inferius"
13 Focus Ti Sedan w/Handling Pkg, MFT Sony 10 NAV, Leather
13 Focus SE HB Sterling Grey, 201A, Leather
06 F350 6.0L DRW King Ranch, Sunroof, Rhino Bed Liner, 4" MBRP Turbo Back, AirRaid, Edge Chip w/Pyro
OPsDad is offline
Old 04-15-2013, 09:25 AM   #55
Tiger-Heli
Fan#: 12379
Forum Activity 9%
In case you didn't follow the entire thread, OPsDad's solution was a trade-back to a Titanium, though - NTTIAWWT.
Old 04-15-2013, 09:27 AM   #56
jimbaldwin1137
Fan#: 113389
There are 2 black holes on each side of the car where the fog lights exist on the 201A and the Titanium. Those would be considered "provisions" on a 200a since they are plugged with 2 pieces of plastic. Also, I thought it was possible when you said,
"If you want to wire them up:
The wire harness from the bumper to the fogs should be CV6Z15K867B and lists for $14.32
The headlight switch with fogs and trunk release for a 2013 is CM5Z11654A and lists for $49.31.
NOTE: The wiring from the BCM to the bumper and the headlight switch to the BCM should already be in the car and there is only one BCM for all trim level 2013 SE's PN BV6Z14A068LC $222.23 list - so I think the parts above would be all you need."
Old 04-15-2013, 09:32 AM   #57
Tiger-Heli
Fan#: 12379
Forum Activity 9%
We are getting into semantics a bit.
The plastic plugs indicate Ford used the same bumper for all models, not necessarily provisions.
Some of the other info is a bit outdated.
The 2012 "S" had fog light wiring from the BCM to the bumper - even though the BCM did not support fog lights.
The 2013 SE did NOT have wiring from the BCM to the bumper, even though the BCM (I think) does support fog lights.
Old 04-15-2013, 10:12 AM   #58
flyboyike
Fan#: 98206
What I Drive: 2012 Race Red SE sedan
Points 335, Level 6
Points: 335, Level: 6 Points: 335, Level: 6 Points: 335, Level: 6
Level Up 70% Completed
Forum Activity 7%
FF Reputation: 3 flyboyike Good Standing Member
Very true.
flyboyike is offline
Old 04-15-2013, 10:15 AM   #59
jimbaldwin1137
Fan#: 113389
All things are possible ...
Old 04-15-2013, 11:26 AM   #60
F35-JSF
F35-JSF's Avatar
Fan#: 102775
What I Drive: 13' Tuxedo Black ST3, 08' ZZR-600
Points 567, Level 11
Points: 567, Level: 11 Points: 567, Level: 11 Points: 567, Level: 11
Level Up 34% Completed
Forum Activity 7%
FF Reputation: 2 F35-JSF Good Standing Member
Could always connect stand alone foglights and and route them through the stock holes.
TB is not a color, it's a part time job.
Originally Posted by MoncefA33 View Post
:lol:Modding is whatever you define it as. Some people wanna boost, some people need 10 TVs, and some of these homos feel compelled to LED their cars front to back.
F35-JSF is offline
