How to: Tail light tint - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-25-2013, 09:58 AM   #51
Vince
Vince's Avatar
Fan#: 115058
What I Drive: 2012, Black Tit X
FF Reputation: 1 Vince Good Standing Member
Originally Posted by Chickenmuffn View Post
NOTE: Following was done on a Euro 2011 Ford Focus Hatch MK3
**If you find that you tinted too much, you can reduce the tint by rubbing away with rubbing compound. This will slowly take off tint until you are happy!**
I used the following products:
Basic tools
1500 grit wet/dry sand paper
Paint thinner
Wax and grease remover
VHT Nite shades
Acrylic lacquer clear coat
Meguiar's ultimate compound
1a.) Remove tail lights, there are 2 wing nuts and a clip that have to be undone. The wing nuts are located here:
And they look like this:
Once the wingnuts are removed, pull the tail light sideways off the car, and the clip should come out. Look at the following picture and take note at where the clip is. Circles are the wingnut bolts, and the square is the clip.
1b.) Remove hatch light
Just unscrew the two screws indicated, and disconnect the wires at the back.
1c.) Remove the 2 lower rear reflectors. They are held in by clips which go though the rear bumper. Just stick your head under the car and use pliers to undo the clips.
2.) Wet sand the tail light with 1500 grit
3.) Wash off the debris with paint thinner and a cloth. Rub down the tail light firmly after, as it can leave a film.
4.) Apply wax and grease remover as the final prep, careful not to touch or move the tail light after this step.
5.) Apply VHT Nite shades and clear coat. I used quick fanning motions with the VHT nite shades and the clear coat. I used 3 coats of nite shades and 4 coats of clear.
6.) After spray let cure for at least 12 hours, 24 is best. Buff with rubbing compound until smooth and shiny.
Before rubbing compound:
After rubbing compound: (had to use the car, so cut the buffing process short, i'll finish it up later)
7.) Reattach lights. (Looks darker than it is, car was in a shadow.)
8.) Rubbing compound more once attached, you can really put your back into it when the lights are on the car. I also used a synthetic polish to give it a bit more shiny. This is the end product. I'm quite happy with it.
Love your work =)
I've got 2 quick questions,
Can I just mask the lights off or is removeal needed?
And have much of Nite shade did you use for the tail lights? 1-2canns? =)
I wanna do my tail lights, reflectors and wing mirrors =)
Cheers
Vince
Vince is offline
Old 05-29-2013, 03:03 AM   #52
mousethis
mousethis's Avatar
Fan#: 107296
What I Drive: 2012 Tuxedo Black SEL Sedan
FF Reputation: 1 mousethis Good Standing Member
Originally Posted by SilverPony2001 View Post
How many coats did you use?
That was three
MOUSETHIS
2012 Tuxedo Black Focus SEL Sedan
Equipment: 303A (no Nav Option)
mousethis is offline
Old 06-10-2013, 03:24 PM   #53
rcjames1
rcjames1's Avatar
Fan#: 90887
What I Drive: 2011 Midnight Black SE
Points 1,632, Level 23
Points: 1,632, Level: 23 Points: 1,632, Level: 23 Points: 1,632, Level: 23
Level Up 32% Completed
FF Reputation: 5 rcjames1 Good Standing Member
Originally Posted by mousethis View Post
That was three
Wow, 3? I just did mine two days ago and I used two coats and they are darker than his. Anyway, tails looking good man!
BTW, people, please don't quote the OP. It makes the pages long and it's something we've already had to scroll through.
Thanks! :D
Rob's the name!
Sedan Revolution #212
rcjames1 is offline
Old 06-10-2013, 03:34 PM   #54
mousethis
mousethis's Avatar
Fan#: 107296
Thanks! :D
Thanks for the complement. Yea the coats seem to produce pretty variable results. I guess people do different things, really lay it on before letting it dry or standing farther away. Then there is the camera and lighting issues too i guess. Either way though, thanks.
MOUSETHIS
Old 09-01-2013, 09:07 AM   #55
kensa36
Fan#: 118469
What I Drive: 2010 sterling grey se hatchback
FF Reputation: 1 kensa36 Good Standing Member
Basic tools
Paint thinner
VHT Nite shades
looks great........not too dark...
kensa36 is offline
Old 11-23-2013, 09:01 PM   #56
kakarote
kakarote's Avatar
Fan#: 124441
What I Drive: 2013 race red focus se hatchback
FF Reputation: 1 kakarote Good Standing Member
very nice!
kakarote is offline
Old 01-19-2014, 01:00 AM   #57
DarkChariot
DarkChariot's Avatar
Fan#: 132225
What I Drive: 2013 Ford Focus Titanium
Points 297, Level 5
Points: 297, Level: 5 Points: 297, Level: 5 Points: 297, Level: 5
Level Up 94% Completed
FF Reputation: 1 DarkChariot Good Standing Member
So I took the plunge today ... I did everything by the book but I have some spotting on mine. Any recommendations? Solutions? Should I just acetone/gasoline this and give it another try? Thanks!
DarkChariot is offline
Old 01-19-2014, 01:18 AM   #58
DarkChariot
Fan#: 132225
Points 297, Level 5
Nvm. I just learned that my tail lights are a perfect example of this gone bad lol looks like I'll be taking it off and going for attempt #2 tomorrow
Old 01-19-2014, 01:42 AM   #59
moralesj55
Fan#: 135849
What I Drive: 2012 Ingot Silver SEL 5 Door
Points 79, Level 1
Points: 79, Level: 1 Points: 79, Level: 1 Points: 79, Level: 1
Level Up 58% Completed
FF Reputation: 1 moralesj55 Good Standing Member
let us know how it turns out. what did you think you did wrong? is it easy to remove?
moralesj55 is offline
Old 01-19-2014, 02:01 AM   #60
DarkChariot
Fan#: 132225
Points 297, Level 5
A few things actually...
1. I don't think I was thorough enough on the sanding part. I noticed that the spotting only happened on areas that I was afraid to be aggressive on. (This was mainly along the many contour lines)
2. Too many coats.
3. Inexperience (spray painting). I admit it. So what? Trial + error baby.
It's going to be a bitch to take it off from what I've read ... Going to use some gasoline and goof off. It's only been 1 day so I'm hoping that make it easier.
The new plan is to strip - resand - and take it one even coat at a time.
