How to: Tail light tint - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-13-2012, 03:17 AM   #21
glocker
glocker's Avatar
Fan#: 102954
What I Drive: '12 Sonic Blue SE
FF Reputation: 1 glocker Good Standing Member
Nice write up!
2012 Focus SE | Sonic Blue | ╠╬╝ | SR# 070
2002 Focus ZTS | Silver Metallic | SOLD!
glocker is offline
Old 11-13-2012, 09:57 AM   #22
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2014 SGM Fusion Ti
Points 9,389, Level 65
Points: 9,389, Level: 65 Points: 9,389, Level: 65 Points: 9,389, Level: 65
Level Up 13% Completed
FF Reputation: 37 jdubhack Great Standing Member
Buy-Sell-Trade Rating: (12)
Originally Posted by sk8parker94 View Post
all those pictures look great! has anybody thought about using film as an alternative?
Because of the lines on the taillights the film is difficult, even the pre-cut. Seems I remember a thread on here somewhere about that...
Now, if you're only tinting a section of the light, say the reverse light portion, then, yes, feasible.
<>< Gal. 6:14
April 2013 HOTM
2013 Ford Fun Weekend: Show Class Winner
jdubhack is offline
Old 11-20-2012, 05:42 PM   #23
glocker
glocker's Avatar
Fan#: 102954
I can't seem to get my rear reflectors out. Do the screws just pull out? I feel if I pull too hard they'll break.
glocker is offline
Old 11-20-2012, 05:48 PM   #24
Chickenmuffn
Fan#: 103458
What I Drive: 2011 Focus Zetec 1.6
FF Reputation: 9 Chickenmuffn Good Standing Member
The two lower rear reflectors?
You have to go underneath the rear bumper. and squeeze the two clips that hold the reflectors in place. You do not need to lift the car, there is enough clearance to just stick your head underneath. There is a picture above showing what they look like (their red)
Chickenmuffn is offline
Old 11-20-2012, 11:22 PM   #25
Bogey
Bogey's Avatar
Fan#: 104241
What I Drive: 2012, Ingot Silver SE
Points 1,696, Level 23
Points: 1,696, Level: 23 Points: 1,696, Level: 23 Points: 1,696, Level: 23
Level Up 96% Completed
FF Reputation: 1 Bogey Good Standing Member
Very nice! I will do this...
Bogey is offline
Old 11-21-2012, 07:58 AM   #26
glocker
glocker's Avatar
Fan#: 102954
Do you just squeeze the clips and pull straight out? Mine are being very stubborn.
glocker is offline
Old 12-30-2012, 11:49 PM   #27
mousethis
mousethis's Avatar
Fan#: 107296
What I Drive: 2012 Tuxedo Black SEL Sedan
FF Reputation: 1 mousethis Good Standing Member
I just tinted my tails and the experience of taking them off the sedan was a pain. My brother and I being in for the holidays at my parents got bored. Figured I would share some pics. Please excuse the mess of my parents barn.
Have to first remove the little plastic door inside the trunk. Has 3 hook tabs...you can feel one with your finger to unhook it and then give a firm pull.(Ignore my patch storage closet...trunk)
Once you remove the little door there are 2 plastic wingnuts and a clip that holds the light in place. Don't drop those =)
Once those are removed pull firmly on the light.
We took the lights out of the housing...not sure this was the best idea but if not I am sure someone will chime in.
Pulled the lid down to take a pic and was like "doh I forgot these".
This meant we had to remove the trunk liner which had 9 plastic screws.
But once you remove the screws you have to remove the clips that the screws were in. These guys.
Then had to thread the trunk release through.
Then removed the liner.
The light was secured to the trunk lid with 1 plastic wingnut and 2 clips. The plastic wingnut can be seen near the bottom left of the pic...it is black and near the end of the wire.
Pull firmly out, you will hear the clips pop out but they should be fine.
If you take the light out of the housing instead of simply unplugging it then make sure you don't lose the little blue o-ring...same goes for the larger light sections except the o-rings are black.
Then I tapped them off in order to paint them.
Overall I learned a lot but I did a really poor job painting the tails. Since I didn't do the job right the first time now I have to do it all over again. I think we had ambient temp probs since the outside temp was like 38 degrees Fahrenheit. We used VHT Nite-Shades and it went on pretty bad. Next time I will do it when it is warmer or use my garage while running the heat in there.I wanted them to be similar to Misfire's but I did a poor job and to top it off I went too dark.
Before:
After:
MOUSETHIS
2012 Tuxedo Black Focus SEL Sedan
Equipment: 303A (no Nav Option)
mousethis is offline
Old 12-31-2012, 02:52 AM   #28
Ox-y-GenIII
Ox-y-GenIII's Avatar
Fan#: 90008
What I Drive: 2012 Oxford White SEL Hatch
Points 5,318, Level 46
Points: 5,318, Level: 46 Points: 5,318, Level: 46 Points: 5,318, Level: 46
Level Up 84% Completed
Forum Activity 2%
FF Reputation: 4 Ox-y-GenIII Good Standing Member
Very nice write up. Looks good.
Ox-y-GenIII
2012 Oxford White Focus Hatchback
Dyno #'s 164.35 HP 147.12 TQ
Ox-y-GenIII is offline
Old 12-31-2012, 05:16 AM   #29
RAF_S197
RAF_S197's Avatar
Fan#: 91991
What I Drive: 2014 Oxford white Sport Black Pack
Points 7,708, Level 58
Points: 7,708, Level: 58 Points: 7,708, Level: 58 Points: 7,708, Level: 58
Level Up 79% Completed
FF Reputation: 21 RAF_S197 Great Standing Member
Buy-Sell-Trade Rating: (4)
Great write up. Thanks!
2014 Oxford white Focus SE Sport Black pack
Instagram: 5_POINTOH
RAF_S197 is offline
Old 12-31-2012, 09:16 AM   #30
84Camaro_L69
Fan#: 105844
What I Drive: 2012 Diamond Tri Coat White SEL HB
FF Reputation: 1 84Camaro_L69 Good Standing Member
Thanks for all the lessons learned, write-ups and pics. No need to look for the "euro lights" when the factory ones can be darkened and look custom. Save the money for performance parts.
Stock with factory Sony 10-speaker HD stereo and 4-wheel disc brakes.
84Camaro_L69 is offline
