How to: Tail light tint - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-15-2012, 04:56 AM   #1
Chickenmuffn
Fan#: 103458
What I Drive: 2011 Focus Zetec 1.6
FF Reputation: 9 Chickenmuffn Good Standing Member
NOTE: Following was done on a Euro 2011 Ford Focus Hatch MK3
**If you find that you tinted too much, you can reduce the tint by rubbing away with rubbing compound. This will slowly take off tint until you are happy!**
I used the following products:
Basic tools
1500 grit wet/dry sand paper
Paint thinner
Wax and grease remover
VHT Nite shades
Acrylic lacquer clear coat
Meguiar's ultimate compound
1a.) Remove tail lights, there are 2 wing nuts and a clip that have to be undone. The wing nuts are located here:
And they look like this:
Once the wingnuts are removed, pull the tail light sideways off the car, and the clip should come out. Look at the following picture and take note at where the clip is. Circles are the wingnut bolts, and the square is the clip.
1b.) Remove hatch light
Just unscrew the two screws indicated, and disconnect the wires at the back.
1c.) Remove the 2 lower rear reflectors. They are held in by clips which go though the rear bumper. Just stick your head under the car and use pliers to undo the clips.
2.) Wet sand the tail light with 1500 grit
3.) Wash off the debris with paint thinner and a cloth. Rub down the tail light firmly after, as it can leave a film.
4.) Apply wax and grease remover as the final prep, careful not to touch or move the tail light after this step.
5.) Apply VHT Nite shades and clear coat. I used quick fanning motions with the VHT nite shades and the clear coat. I used 3 coats of nite shades and 4 coats of clear.
6.) After spray let cure for at least 12 hours, 24 is best. Buff with rubbing compound until smooth and shiny.
Before rubbing compound:
After rubbing compound: (had to use the car, so cut the buffing process short, i'll finish it up later)
7.) Reattach lights. (Looks darker than it is, car was in a shadow.)
8.) Rubbing compound more once attached, you can really put your back into it when the lights are on the car. I also used a synthetic polish to give it a bit more shiny. This is the end product. I'm quite happy with it.
Chickenmuffn is offline
Old 09-15-2012, 07:23 AM   #2
unida767
Sonic Mk3 Crew #08
unida767's Avatar
Fan#: 95574
What I Drive: 2012 Black Titanium Powershift SEP
Points 4,244, Level 41
Points: 4,244, Level: 41 Points: 4,244, Level: 41 Points: 4,244, Level: 41
Level Up 47% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 11 unida767 Great Standing Member
Excellent write up and pics man
12 Ti HB DCT Adaptive Cruise BiXenon/DRL Sunroof
Magnaflow 15072 Steeda 555-3166 ISC Coilovers F016C
Whiteline BMR78XZ Injected Tune 19" RS Wheels RS Wing
SC#8 HN168
uɐıןɐɹʇs,
unida767 is online now
Old 09-15-2012, 08:23 AM   #3
NickCornell
NickCornell's Avatar
Fan#: 97233
What I Drive: 2012 Race red Focus SEL
Points 13,814, Level 76
Points: 13,814, Level: 76 Points: 13,814, Level: 76 Points: 13,814, Level: 76
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 3%
FF Reputation: 12 NickCornell Great Standing Member
Fantastic looking, thumbs up!
#SonicsMK3Crew
Follow #projectstreetdevil on IG @BBNickC
BUILD THREAD: http://www.focusfanatics.com/forum/showthread.php?t=323533
NickCornell is offline
Old 09-15-2012, 09:30 AM   #4
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,282, Level 95
Points: 25,282, Level: 95 Points: 25,282, Level: 95 Points: 25,282, Level: 95
Level Up 94% Completed
Forum Activity 4%
Good write-up and the tails look great
I would also recommend, for those concerned with reversibility, that the sanding step can be skipped pre-spray. Then, should the need arise, the spray can be removed with gasoline (or the like) with no scratching visible on the lenses.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 09-15-2012, 09:57 AM   #5
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2014 SGM Fusion Ti
Points 9,322, Level 64
Points: 9,322, Level: 64 Points: 9,322, Level: 64 Points: 9,322, Level: 64
Level Up 91% Completed
FF Reputation: 37 jdubhack Great Standing Member
Buy-Sell-Trade Rating: (12)
Excellent write up, this was in my plans for this weekend, and I appreciate the help.
________
Real heads up Duane, thanks man! Was wondering about the viability of reversing it.
jdubhack is offline
Old 09-15-2012, 10:34 AM   #6
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 4%
Not a problem[thunb]
I actually shaded my tails when I did my headlights. After they cured up I went to wet-sand them smooth and accidentally burned through the shade on my D/S (I only wanted a light tint) in two spots. It took me about 30 mins with a rag, elbow grease and some gasoline, but you can't tell anywhere on my lights that they ever had been sprayed.
September '13 ROTM
2014 FiST-
Old 09-15-2012, 11:42 AM   #7
Chickenmuffn
Fan#: 103458
A cheaper (and safer!) equivlent would be paint thinner or acetone. It removes the tint real good, you barley have to rub!
Also if you are concerned about reversibility as well as durability. VHT does a RED nite shades, which can be used to reverse everything back to stock. Even if you sand.
** Also added how to remove the hatch light and 2 rear reflectors **
Old 09-15-2012, 12:00 PM   #8
Twenty
Sonic's Mk3 Crew #17
Twenty's Avatar
Fan#: 90312
What I Drive: 2012 YB SE sedan w/ ST exterior
Points 22,086, Level 92
Points: 22,086, Level: 92 Points: 22,086, Level: 92 Points: 22,086, Level: 92
Level Up 74% Completed
Forum Activity 12%
FF Reputation: 10 Twenty Great Standing Member
I wish tail lights were cheaper so that I could play around and experiment.
When I changed the lights on my GP I bought the best I could find (condition) for $37.
officialTHREETWENTY
2012 YB Focus SE Sedan [featured in Performance Ford, Sept '14]
1992 BW Grand Prix SE Sedan [restomod project]
SR#74/SMk3C#17/YBOC#03
Bill M.
Twenty is offline
Old 09-15-2012, 01:35 PM   #9
Deehugh
Deehugh's Avatar
Fan#: 99502
What I Drive: 2012 Tuxedo Black SE Hatchback
FF Reputation: 1 Deehugh Good Standing Member
Looks Great dude, awesome instructions and pictures! Very informative
All Day and Tomorrow
2012 SE Hatch Tux Black - Electric Blue Blox Knob - Debadge
Deehugh is offline
Old 09-15-2012, 03:31 PM   #10
misfire
Moderator
misfire's Avatar
Fan#: 31379
What I Drive: 2012 SEL Hatch, 2014 Mazda CX-5
Points 17,014, Level 83
Points: 17,014, Level: 83 Points: 17,014, Level: 83 Points: 17,014, Level: 83
Level Up 33% Completed
FF Reputation: 31 misfire Great Standing Member
Buy-Sell-Trade Rating: (13)
nice write up!
Will aka Misfire
2003 LX "traded in"/2010 SES "traded in"/2012 SEL Hatch "current"
misfire is offline
