Floor the engine but car doesn't go! - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-15-2012, 12:13 PM   #11
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,746, Level 73
Points: 12,746, Level: 73 Points: 12,746, Level: 73 Points: 12,746, Level: 73
Level Up 74% Completed
Forum Activity 99%
With a "stick", if the engine speeds up but the car doesn't, the clutch is slipping.
Having the clutch disengage at the top of the pedal travel (instead of part way down as normal) as mentioned is another sign of a worn clutch.
Oil dripping from the "weep hole" at the bottom of the bell housing would imply a leaking main seal of the engine which should be inspected when the clutch is replaced in any case. (the odd drip isn't tragic, but noticeable leakage would need to be fixed)
The city driving mentioned certainly COULD shorten the "normal" life of a clutch, depending on driving style & how much "stop & go" driving was involved....
Luck!
sailor is online now
Old 09-15-2012, 12:16 PM   #12
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
By the way, we recommend NEVER to replace a clutch without also replacing the slave cylinder, since on these cars it can't be replaced without pulling the transmission again....
And it's cheap to do while you're in there, to the point that most clutch kits include one....
Old 09-15-2012, 12:22 PM   #13
GangGreen3
Fan#: 101652
What I Drive: 2001 Focus LX
Points 363, Level 7
Points: 363, Level: 7 Points: 363, Level: 7 Points: 363, Level: 7
Level Up 26% Completed
FF Reputation: 1 GangGreen3 Good Standing Member
Thank you very much for all the help!
GangGreen3 is online now
