Fumoto Engine Oil Drain Valve - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-12-2012, 11:04 PM   #1
fofo60
Fan#: 95976
What I Drive: 2012 Ingot Silver Metallic Hatchbac
FF Reputation: 1 fofo60 Good Standing Member
Just installed a Fumoto engine oil drain valve on the Focus. If you are interested in doing this here is the info. I bought my parts online. You will need:
Fumoto F-107N engine oil drain valve
Fumoto ADP-107 male/female adapter
The drain valve has a little extension that allows you to attach a drain hose and drain the oil into your collection pan, no mess. You will need the adapter because there is a metal protrusion above the oil drain hole that prevents the oil drain valve from screwing in all the way.
The system works well and if you change your own oil and plan to keep the car for a long time it will make the job a lot easier.
September 13, 2012. Tiger Heli just posted that there is a new drain valve that does not require the adapter. Look for the
Fumoto F-107SW. Looks like it would be easier to install.
fofo60 is offline
Old 09-12-2012, 11:06 PM   #2
Chaos09
Sonic Crew #09
Chaos09's Avatar
Fan#: 95090
What I Drive: Slammed S-10
Points 8,062, Level 60
Points: 8,062, Level: 60 Points: 8,062, Level: 60 Points: 8,062, Level: 60
Level Up 56% Completed
FF Reputation: 7 Chaos09 Good Standing Member
Pics or it didnt happen! LOL!
Sonic's MK3 Crew #9 Chaos!
Chaos09 is offline
Old 09-12-2012, 11:09 PM   #3
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2014 SGM Fusion Ti
Points 9,389, Level 65
Points: 9,389, Level: 65 Points: 9,389, Level: 65 Points: 9,389, Level: 65
Level Up 13% Completed
FF Reputation: 37 jdubhack Great Standing Member
Buy-Sell-Trade Rating: (12)
Good lookin out. Total price?
jdubhack is offline
Old 09-12-2012, 11:35 PM   #4
fofo60
Fan#: 95976
On Amazon, Drain valve is $26.50 and adapter is $7.50. You might be able to find an auto parts store that has a better price.
fofo60 is offline
Old 09-13-2012, 08:45 AM   #5
Rememo
Rememo's Avatar
Fan#: 95534
What I Drive: Was 2012 Focus. Now 2013 Impreza.
FF Reputation: 3 Rememo Good Standing Member
I've installed one of these on every car I've owned since they became available. They save time and protect the threads of your oil pan (no removing and installing the drain plug over and over), but they don't flow very well. You'll have to double the time it takes to drain your oil.
I recommend them, just make sure you have some patience and extra time.
Rememo is offline
Old 09-13-2012, 09:15 AM   #6
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Thanks for posting this. I used the application guide on their website a few months ago, and Fumoto didn't show that the extension adapter was needed. I wasn't very happy when I tried to install it during an oil change a couple of days ago. I've added the ADP-107 adapter to my Amazon wishlist.
Hatch Nation #90
TboneZX3 is offline
Old 09-13-2012, 09:22 AM   #7
revhigh
Fan#: 98516
What I Drive: 2012 Mazda 3 SkyActiv 6A Touring
FF Reputation: 1 revhigh Good Standing Member
When I change the oil I want as full, fast and complete a flow as possible to flush out as much debris and/or contaminants as possible. I also don't want to leave 4 ounces or so of the dirtiest oil in my engine caused by the threads of that thing protruding into the oil pan and failing to allow a complete drain.
I never had an issue with a wrench and the regular drainplug.
With 10k OCI's ... is using a wrench that hard to do, especially considering what a pain in the butt that cover is with the 8 torx head screws.
To each his own. If ya like it ... use it.
REV
revhigh is offline
Old 09-13-2012, 09:28 AM   #8
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: '14 Ruby Ti w/ Handling Pkg
Points 7,615, Level 58
Points: 7,615, Level: 58 Points: 7,615, Level: 58 Points: 7,615, Level: 58
Level Up 33% Completed
Forum Activity 3%
FF Reputation: 13 kam327 Great Standing Member
Thanks for the info. I would jump on this except the price makes it even harder for me to justify changing the oil myself. I'm already only saving a few bucks compared to finding a $25 oil change deal somewhere. And I have revhigh's concern as well; any debris on sitting on the oil pan will have a better chance getting flushed out with a higher drain flow rate.
But I do see the convenience of the valve. At the very least it'll be much cleaner. I always forget to put on rubber gloves and end up with hot used oil on my hands.
kam327 is offline
Old 09-13-2012, 10:39 AM   #9
fofo60
Fan#: 95976
Oil drain valves are like liver and onions.... you either love them or hate them. I am not trying to talk anyone into using a drain valve, just wanted to let you know what parts to buy. I have used these valves for years because they make the oil change so easy. I would think that to get most of the dirty oil out of your car the most important factor would be to make sure that the engine is warmed up and the oil is hot before draining. The drain valve keeps you from having to remove the hot drain plug while the hot oil is splashing around. You just open the valve.
However you do it... keep that oil clean!
fofo60 is offline
Old 09-13-2012, 10:44 AM   #10
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Forum Activity 3%
Totally, and I do appreciate the info. It's still very tempting. I hate hot oil on my hands.
Hope you fared well in Gulfport there during Isaac.
kam327 is offline
