Shuts off while driving, restarts after cooldown - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-12-2012, 01:27 PM   #1
krank
Fan#: 103747
What I Drive: 2000 Green Focus SE
FF Reputation: 1 krank Good Standing Member
It's now twice my Focus 2000 has shut down while driving on local streets, and I've been fortunate that no accidents happened and the car wasn't blocking traffic after. When it works it's fine (low mileage, under 50K) and it will work just fine after a cooldown. Right after a stop the starter turns, but the engine won't catch. The car was warmed up when it happened, but not hot, and there were no advance warnings. It must be electrical, maybe some safeguard like the fuel line cutoff, but would that reset when the engine cools? Is there a solenoid or sensor which is supposed to prevent the engine from starting, but is now shutting it down? I'd appreciate any suggestions, as I'm afraid to drive locally, let alone risk a stall on a parkway.
krank is offline
Old 09-12-2012, 01:57 PM   #2
krank
Fan#: 103747
I'm replying to my own post but I came across another post on your site about resetting the ECU by removing the negative battery terminal. I didn't mention originally that the first sign of trouble was a week previous after I may have put a few gallons of bad gas and the dash lights all went on suddenly when driving locally. I pushed the accelerator and the car kept on going. The only light that stayed on was the yellow engine light. Might a reset of the ECU fix the problem?
krank is offline
Old 09-12-2012, 02:11 PM   #3
grayzx35speed
grayzx35speed's Avatar
Fan#: 94839
What I Drive: 2006 Gray ZX3
FF Reputation: 0 grayzx35speed Newbie
The negative.cable has to be off for 15-20 minutes for a reset The yellow light you see is a check engine light. This can be caused by anything from a vacuum leak to your gas cap being too loose. Do you have a code reader?
North East Honda Killer
OBX Header, Hi flo cat, dremled throttle body/intake manifold, k&n cold air intake, eibach 1.5" springs with Ford Racing gas strutsand Toms tune with PZEV delete and 91 octane
grayzx35speed is offline
Old 09-12-2012, 04:57 PM   #4
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 163, Level 3
Points: 163, Level: 3 Points: 163, Level: 3 Points: 163, Level: 3
Level Up 26% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
Also check your coil. I have seen a coil, that was going bad, cause this problem. The coil's internal insulation was starting to break down and when it reach operating temperature would cause the car to shut off, after it cooled down, the engine would fire right up.
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
Old 09-13-2012, 12:59 AM   #5
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
a couple of other things to check since it's an early-model Focus:
  • collapsed PCV hose
  • dirty/faulty IAC valve
  • fuel pump failure
Regarding the last item, was your fuel pump ever replaced under the Ford recall? I experienced the textbook symptoms - stall without warning when driving with less than a 1/4-tank of gas (especially when turning).
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 09-14-2012, 10:00 AM   #6
krank
Fan#: 103747
Thanks for the replies. Things have gotten worse. I took a chance on a very local errand yesterday, and got there ok. On the way back the engine stopped while driving. Someone gave me a boost, but it conked out again after a few blocks. I called my emergency service this morning, and with a boost was able to get it from a meter on the corner to my house. Did I mention that when the motor stops the clock and instrument panel turns off, and don't go on again when you turn the key until the motor catches, even though the starter turns over. Possible electrical, possible short, or maybe as suggested the coil? Any other suggestions?
krank is offline
Old 09-14-2012, 07:32 PM   #7
MEJY1988
Fan#: 101883
Points 163, Level 3
Check all your battery connections, at both ends, positive and negatives/grounds, for corrosion and to make sure they are connected tight. Make sure battery is fully charged, then do a voltage check at the battery, first with engine off, should read around 12.5 Volts. Next check voltage at battery, with engine running, should be around 13.5 Volts.
MEJY1988 is offline
Old 09-15-2012, 04:42 PM   #8
grayzx35speed
Fan#: 94839
Definitely hinting at an electrical issue, like everyone elsw suggests check your coonections and your voltages.
