cam gear questions - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-13-2012, 11:10 AM   #11
cfmfocus2
FF Affiliate
Fan#: 22843
What I Drive: Ford focus svt
Points 8,151, Level 61
Points: 8,151, Level: 61 Points: 8,151, Level: 61 Points: 8,151, Level: 61
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
FF Reputation: 9 cfmfocus2 Good Standing Member
Buy-Sell-Trade Rating: (6)
I have seen the cam timing vary a good amount as sleepyboy noted on the zetec engines. It does help a vehicle with stock camshafts if it off a good amount from factory. The article noted by sleepyboy shows a good example of how much cam gears can help by, which is a good amount.
Adjustable cam gears are a most for anyone look into aftermarket camshafts. There any many companies back in the day that used to offer cam gears for these cars. We are one of the few that still do. Link to cam gears
William - Sales Dept.
407.339.9211
Please e-mail or call me for quicker response.
cfmfocus2 is offline
Old 09-13-2012, 06:43 PM   #12
sgtsmasher
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
What I Drive: 01 cd silver 3 door ztec
FF Reputation: 2 sgtsmasher Good Standing Member
im still lost on the whole how to actually tune them though. i mean i know you guys said to get them dyno tuned for best results.
what if i dont have a dyno to adj them correctly?
would i just be screwing myself in the long run if i just took the stocks off and threw these on and tried adj them that way?
with the 5 bolt design do you loosen them up move the gear then tighten them again?
im just such a noob when it comes to the tech stuff, i mean i could throw parts on this car all day and not have any idea how they work or how to use them.
for mods as of right now i have:
svt header
ebay CAI w/ K&N filter
65mm CFM TB
full 3" from ORP back magnaflow exhaust with high flow cat and res
pretty much a race tranny w/ 406 gears-LSD-LW flywheel w/ some stg2 clutch
svt brake kit front and back
toms tune which included egr delete, rev limiter increase, and some others maybe idk
soon to come will be wide band A/F gauge
maybe a short throw shifter
so its not like the car is no stock by any means i just would maybe like a little more out of this thing before i kill it lol, but idk how to do this
Hatch Nation #72
Call Me BRANDO COMMANDO
sgtsmasher is offline
Old 09-13-2012, 08:11 PM   #13
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 135,623, Level 100
Points: 135,623, Level: 100 Points: 135,623, Level: 100 Points: 135,623, Level: 100
Level Up 0% Completed
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (11)
Dyno tuning them means going to a place that has a dyno and running the car to get a base line. Then adj the cam gears a little then make some more pulls. You keep doing this over and over till you find the optimal settings. Should take less than an hour. Most shops charge hourly for dyno time. Cam gears would be a good step in the right direction with all the mods you have now. With my cam gears dialed in on my stock cams I gain power everywhere. My car used to fall on it's face after 5k rpm to rev limiter, after the tuning I could pull all the way. But the over all power band was much broader with tq everywhere. Really made the car a lot more fun to drive.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 09-13-2012, 08:54 PM   #14
sgtsmasher
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
i just wish that i knew of a dyno around my area or in maine that i could get on
Hatch Nation #72
Old 09-13-2012, 11:52 PM   #15
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,399, Level 86
Points: 18,399, Level: 86 Points: 18,399, Level: 86 Points: 18,399, Level: 86
Level Up 10% Completed
Forum Activity 4%
FF Reputation: 48 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
Then it'll be trial/error. If you can data log should help to verify your butt dyno. Watch for increases in load and air flow. Make a few different logs at the same settings and average them. Should reduce the error factor of a single WOT log.
No.
You can run the gears in any location you want with no damage. [b]But it is the best idea to turn the engine clockwise by hand after major adjustments to make sure nothing's binding.
Yes.
Loosen the 5 bolts, use the center bolt to move the cam gear and hold it in place if need be, tighten all 5 lock bolts, then go back over then a second time to make sure you tightened them.
The bolts don't need to be gorilla TQ'd. Nice and snug is all you need, best guess, about 20 ft/lbs.
Over-tightening them will result in stripping the threads. And FWIW, 2 bolts still holds the gear in place,,, ya, I've stripped a few
Don't "think outside the box".
There is no box.
Do it correct, or do it twice.
iminhell is online now
Old 09-17-2012, 01:54 PM   #16
sgtsmasher
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
Thanks for the advise iminhell, that helps me decide weather to keep them or not...i was just worried that if i put these on the car that i would screw something up really bad, i would like to have these set up for the best results, but without a dyno i wont get those results which sucks. I wish there was a how to that gave a better step by step
Hatch Nation #72
