replacement 50,000 mile engine now ticks... - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus First Generation > DURATEC Performance (2003-2007)
Old 09-11-2012, 07:07 PM   #1
Wiplash2000V6
Fan#: 27480
What I Drive: silver ST
FF Reputation: 1 Wiplash2000V6 Good Standing Member
So I finally got my engine installed after 3 months of searching for one .I found one on Automotix.com with 50,000 miles on it for $1500. So I go pick my car up the shop says everything was fine so I pay them the install fee. I drive not even half a mile and I hear a slight tick...I call them and they say it wasnt doint that when they tested it the whole .5 miles they drove it. they said its probably a stuck lifter most likely from the engine sitting so long at a junkyard. it has now gotten louder .I will take it back to the shop in the morning but would like some imput on what it could be. thanks
Wiplash2000V6 is offline
Old 09-11-2012, 07:34 PM   #2
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
What I Drive: '12 Fusion SE V6
FF Reputation: 24 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
Was fresh oil and filter installed as well?
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
'07 ST ; formally bewst'd - R.I.P
D23 Crew: #07
Jgrove998 is offline
Old 09-11-2012, 08:37 PM   #3
felixthecat
felixthecat's Avatar
Fan#: 80663
Points 9,453, Level 65
Points: 9,453, Level: 65 Points: 9,453, Level: 65 Points: 9,453, Level: 65
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
Forum Activity 68%
Activity: 68% Activity: 68% Activity: 68%
FF Reputation: 56 felixthecat Excellent Standing Member
By the way these motors have solid lifters. I guess you checked the oil level & whether it is new oil. When its running can you hear where its ticking= above or under neath the car? I'd also check to see what kind of warranty there is. Like a 90 day or whatever & if they cover swapping out the motor cost's. I'd help if you were closer = Seattle area. Checkout the n/w section 4/22 I helped Bertst change out his motor= g2g motor swap day. What was wrong w/ the original motor? Low oil level perhaps?
Introduce Mr. Torsen to the mix D23 crew- D-Tech- Sedan Revolution= #131
felixthecat is offline
Old 09-12-2012, 05:05 AM   #4
jinxster
jinxster's Avatar
Fan#: 53021
What I Drive: 2007 Pitch Black ZX4 ST SAP1
Points 367, Level 7
Points: 367, Level: 7 Points: 367, Level: 7 Points: 367, Level: 7
Level Up 34% Completed
FF Reputation: 1 jinxster Good Standing Member
I had a similar issue and sound on my replacement engine--right after it was put in--inmy case--the ticking was most noticeable only on first start/cold--so I had to keep the car overnight with them for them to diagnose-- the ford dealer then also told me it was lifters sticking--people here at the time seemed to disagree since they are solid as felix mentioned. Possibly a valve guide?
In any case--the dealer at the time put in some sort of additive to prevent valve/lifter sticking. I was sceptical that it would work--but it cured the problem--and 50K miles on--no issues or recurrence yet...
D23 Crew #29
jinxster is offline
Old 09-12-2012, 05:53 AM   #5
Wiplash2000V6
Fan#: 27480
yes fresh oil and filter was replaced. yes the old motor was low on oil and spun a bearing.
Old 09-12-2012, 09:25 AM   #6
Wiplash2000V6
Fan#: 27480
the shop told me its fron the lower end ...
Old 09-12-2012, 12:24 PM   #7
VEGAS
VEGAS's Avatar
Fan#: 75680
What I Drive: 2007 Focus
FF Reputation: 4 VEGAS Good Standing Member
I went thru this with LKQ, a 2.3L, it ticked from day one, I then bought a reman engine, died in 3 weeks, under warrenty they replaced it and now I am 3K miles and 1 month into a new motor and no issues.. cost about double your $1500 and then some but I am happy now, however I was told from LKQ that the warrenty was void if i accept a 2.3L motor since my car came with a 2.0L and will not replace it again if it went out. so if you get one, avoid LKQ
VEGAS is offline
Old 09-12-2012, 03:55 PM   #8
felixthecat
Fan#: 80663
Forum Activity 68%
Thats a bummer. Sorry to here that. Its Critical that you keep your oil level up= only holds 4.5qtrs. Thats what I see often when a motor goes= low oil level.
Old 09-12-2012, 04:08 PM   #9
felixthecat
Fan#: 80663
Forum Activity 68%
On 23's a great upgrade is to remove the balance shafts & install a plug in the oil feed hole to the balancer's. It removes 'bout 18-19lbs & 12-14lbs of rotating weight & on top of that you will found your motor now holds 6qtrs of oil. I just used a plug= freeze plug style & staked it into the feed hole & add a windage tray. Don't nick the pan or block w/ the razor blade when scraping off the rtv from the pan & block= take your time on that. You don't want come backs do you= In your case you don't want to redo your work do you? I don't think so. Enjoy the mod too.
Old 09-12-2012, 04:51 PM   #10
Wiplash2000V6
Fan#: 27480
I think i saw a LKQ sticker on the valve cover.. Ive been searching for awhile and found a website called www.automotix.net and got it from there. I was planning on removing the balance shaft but wasnt sure if that would have voided my warrenty.
where did you order your reman engine from?
