just some insight on ebay header - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-13-2012, 02:37 PM   #11
stealthzx3
Enthusiast
stealthzx3's Avatar
Fan#: 94260
What I Drive: 2003 Black ZX3 SVT, 2001 Black ZX3
Points 11,482, Level 70
Points: 11,482, Level: 70 Points: 11,482, Level: 70 Points: 11,482, Level: 70
Level Up 58% Completed
Forum Activity 3%
FF Reputation: 10 stealthzx3 Great Standing Member
Buy-Sell-Trade Rating: (23)
Originally Posted by HAILEYS_CRAZY_DADDY View Post
So if I'm understanding all this right it's best not to buy an ebay header
it's best not to buy anything mechanical or performance related from ebay. their parts are off brand, usually made of junk material, and majority of the time, doesn't fit correctly.
Focus Revolution
2003 EAP SVT #2752
stealthzx3 is offline
Old 09-13-2012, 06:16 PM   #12
sgtsmasher
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
What I Drive: 01 cd silver 3 door ztec
Points 7,665, Level 58
Points: 7,665, Level: 58 Points: 7,665, Level: 58 Points: 7,665, Level: 58
FF Reputation: 2 sgtsmasher Good Standing Member
right, stay away from ebay with performance parts, other parts are maybe questionable, but other are good
Originally Posted by iminhell View Post
Looks primarily like a gasket issue ...
nope it actually just didnt line up at all
Originally Posted by drunkyoda View Post
i feel bad for your car... a lot of rust.
and really for being in maine and having salty dry and wet winters, the car is holding up really good, thanks
Hatch Nation #72
Call Me BRANDO COMMANDO
sgtsmasher is offline
Old 09-13-2012, 06:19 PM   #13
sgtsmasher
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
this is what i have in its place, just have to get the ORP cut with the custom flange they made with 2 o2 bungs and ill be golden
can anyone guess what this is :)
Hatch Nation #72
Old 09-13-2012, 06:58 PM   #14
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,714, Level 94
Points: 23,714, Level: 94 Points: 23,714, Level: 94 Points: 23,714, Level: 94
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 11%
headers leak in general anyway... no surprise to me.
mikebontoft is online now
Old 09-13-2012, 07:06 PM   #15
sgtsmasher
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
can anyone let me know if that header look crooked to them it does to me but it might just be the gasket
Hatch Nation #72
Old 09-13-2012, 08:25 PM   #16
HAILEYS_CRAZY_DADDY
Fan#: 101782
What I Drive: 2002 Mandarin Copper ZX3
FF Reputation: 1 HAILEYS_CRAZY_DADDY Good Standing Member
here's all the TQ for the engine on a zetec. the link don't work because you have to pay for ALLDATA but i got all of the info atschool where we have access to it. it's basically every TQ spec required to assemble a zetec. also i can put up larger pictures next week as well. also i'll save the pictures and rehost them since they're currently being hosted on the ALLDATA server which goes down for maintenance occasionally.
2002 Ford Focus ZX3 L4-2.0L DOHC VIN 3
Vehicle Level Engine, Cooling and Exhaust Engine Specifications Mechanical Specifications Torque Torque
Hose clamps 35 inch lbs.
Intake manifold studs 44 inch lbs.
Intake manifold bolts and nuts 13 ft. lbs.
EGR tube assembly to EGR valve 30 ft. lbs.
EGR pipe to ignition coil bracket 53 inch lbs.
EGR tube assembly to catalyst 30 ft. lbs.
Heat shield to exhaust manifold 89 inch lbs.
Exhaust manifold studs 44 inch lbs.
Exhaust manifold nuts 12 ft. lbs.
Catalytic converter to exhaust manifold 35 ft. lbs.
Catalytic converter to exhaust 35 ft. lbs.
Right-hand driveshaft center bearing 18 ft. lbs.
Generator to bracket 18 ft. lbs.
Generator bracket to upper cylinder block bolts 18 ft. lbs.
Generator bracket to lower cylinder block bolts 48 ft. lbs.
Transmission flange bolts 35 ft. lbs.
Starter motor to transmission 26 ft. lbs.
Oil drain plug, MTX transmission 33 ft. lbs.
Oil control plug, MTX transmission 33 ft. lbs.
Flywheel bolts 83 ft. lbs.
Clutch pressure plate 21 ft. lbs.
Engine roll restrictor to transmission 35 ft. lbs.
Engine roll restrictor to subframe 35 ft. lbs.
Engine rear mount to body 35 ft. lbs.
Engine rear mount (nut on transmission mounting bracket) 98 ft. lbs.
Engine front mount to engine 59 ft. lbs.
Engine front mount to body 35 ft. lbs.
Power steering pump to bracket 18 ft. lbs.
Power steering pump bracket 35 ft. lbs.
Cylinder head bolts
Stage 1: 20 Nm
Stage 2: 40 Nm
Stage 3: 90 degrees
Camshaft bearing cap bolts
Stage 1: 10 Nm
Stage 2: 19 Nm
Cylinder head cover
Stage 1: 2 Nm
Stage 2: 7.8 Nm
Spark plugs 11 ft. lbs.
Timing belt tensioner 18 ft. lbs.
Camshaft timing belt pulleys 50 ft. lbs.
Upper timing belt cover 89 inch lbs.
Ignition coil (El) bracket to cylinder head 15 ft. lbs.
Thermostat housing 15 ft. lbs.
Fuel rail 89 inch lbs.
Engine rear lifting eye 12 ft. lbs.
Engine rear lifting eye studs 53 inch lbs.
Engine front lifting eye 35 ft. lbs.
Engine oil drain plug 18 ft. lbs.
Oil pressure switch 20 ft. lbs.
Cylinder block oil gallery blanking plugs 17 ft. lbs.
Heater pipe bracket to oil pan 89 inch lbs.
Oil pan to lower crankcase
Stage 1: 6 Nm
Stage 2: 10 Nm
Lower crankcase to cylinder block 16 ft. lbs.
Oil pump 8 ft. lbs.
Oil intake pipe to oil pump 89 inch lbs.
Main bearing bolts
Stage 1: 25 Nm
Stage 2: 60 degrees
Connecting rod bearing cap bolts
Stage 1: 35 Nm
Stage 2: 90 degrees
Coolant pump 13 ft. lbs.
Crankshaft rear oil seal carrier 15 ft. lbs.
Drive belt idler pulley 30 ft. lbs.
Crankcase ventilation pipe bracket 17 ft. lbs.
Crankcase ventilation 89 inch lbs.
Coolant pump pulley 18 ft. lbs.
Crankshaft belt pulley 85 ft. lbs.
Crankshaft position sensor bracket 15 ft. lbs.
Crankshaft position sensor to bracket 71 inch lbs.
Idler pulley 17 ft. lbs.
Knock sensor 15 ft. lbs.
ARP specs
HAILEYS_CRAZY_DADDY is offline
Old 09-15-2012, 12:01 AM   #17
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,142, Level 74
Points: 13,142, Level: 74 Points: 13,142, Level: 74 Points: 13,142, Level: 74
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 30%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Looks aligned to me. Glad to see that you saw the light finally and went with an SVT header. I remember you went about last year asking all kinds of questions about headers when you finally decided upon the M2 due to price.
zetecDon is online now
Old 09-18-2012, 07:21 AM   #18
sgtsmasher
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
If i ride around with no o2 senosors how bad is that? i figure itll be a little rough running, but the front o2 wouldnt come off the header and the rear one had frayed broken wires. so i threw out all of them and im regreting that now. A new one is $50+!!! what i was thinkin is once i get the funds for a oil pan (dented and leaking cause of rust) and the o2 sensor i would put everythin in then
Hatch Nation #72
Old 09-18-2012, 07:57 AM   #19
mikebontoft
Aurelius Pardus
Fan#: 58647
Forum Activity 11%
not good... front 02 reads if you're rich or lean and the computer adjust accordingly. the rear just reads if the exhaust is cleaner.
hopefully it will just mean that you don't go out of open loop and it will run on a pre set range of trims.
Old 09-18-2012, 11:08 PM   #20
sgtsmasher
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
ah i see, so i if i did not have one it would not be good for the car, gotcha thanks
Hatch Nation #72
