A/C problems - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-11-2012, 04:04 PM   #11
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
Originally Posted by suss6052 View Post
If you are sitting there with the car running the engine is cold and not very much air is coming across the a/c condenser as well. It could be that the active grille shutter system is currently working when the car is stationary to try and help warm up the power train if you're not driving it. Just a theory, but if there is no air moving past the condenser it won't cool very quickly if at all.
very true, definitely cools off much faster once you start moving and the air starts flowing.
Sonic Crew #28
feta_mgp is offline
Old 09-11-2012, 04:07 PM   #12
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
I can't imagine how the two service items you had done to the car would have affected your A/C operation.
Hatch Nation #90
TboneZX3 is offline
Old 09-11-2012, 04:33 PM   #13
Timthom62
Timthom62's Avatar
Fan#: 97579
What I Drive: 2012 Red Candy 5-Door SEL 303A
Points 2,809, Level 32
Points: 2,809, Level: 32 Points: 2,809, Level: 32 Points: 2,809, Level: 32
Level Up 40% Completed
FF Reputation: 5 Timthom62 Good Standing Member
The PCM controls air conditioning clutch engagement and the 12B37 update did change the PCM software a bit, but neither our SE with the manual a/c or our SEL with the DATC have exhibited this issue since the update back in May. They both start cooling within a minute or two of start.
My first question would be whether or not the clutch is engaging on start up or not engaging until the car is in gear.
As suss6052 points out, the vapor cycle air conditioning system relies on cooling air flowing across the condensor to cool the refrigerant. Even once the clutch is engaged, it takes time for the system to work up to operating pressure and for the cooling cycle to reach a point where you'd notice the difference at the vents. I know that on both of our cars, it takes considerably longer to feel the difference on a hot day.
Timthom62 is online now
Old 10-25-2012, 06:12 PM   #14
lhcaz
Fan#: 105296
What I Drive: race red
FF Reputation: 0 lhcaz Newbie
I also had the same a/c issues and way more so after 8 months of getting nowhere I took matters into my own hands and did some research.
At issue is the a/c condenser its behind the shutters that cover the radiator and they open when the car engine needs to cool down.aka the thermostat opens the fan turns on the shutters open. There is more to the system but for the most part that’s the science behind how it works. There is some air flow when the shutters are closed but simply not enough for any a/c system to work properly.
The main issue is the fords design, when we had cool temps like 85 to 95 degrees,
the car did not need as much fan time so the a/c condenser gets little or no are flow. Even with the a/c on max the shutters are closed, Thus giving us a cabin temp of 75 to 80 degrees (way to hot).
The a/c temp at the dash (vents) averaged 45 to 60 degrees on max but the temps were up and down as the shutters opened and closed over and over.
We live in the Mohave Desert so it gets hot like 100 to 115 even 125 degrees when it was that hot the car is Needing more fan time so the fan runs more so the a/c seemed to work.
Why?
Because the a/c condenser was getting max air flow.
The flaw is Fords shutter system having the a/c condenser behind the shutters;thus no air flow.
After consulting an attorney I was told I could use the Lemon law because of the few months i owned the car, low miles and a multitude of required documented trips to the dealer for the same a/c issue.
He also told me the focus is selling like hot cakes and ford will never
Admit to a design flaw and or an a/c issue. so no full refund.
A factory Ford rep. also told me there was nothing wrong with the car.
So I traded my new 2012 ford focus in on a new 2012 import.
The a/c blows 29 degrees all the time.
I don't feel its fair to list the brand i now own but there truck line
did pull the space shuttle.
FORD
I have never been so let down in my life with a US made car.
lhcaz is offline
Old 10-25-2012, 06:38 PM   #15
Seriously Focused
Seriously Focused's Avatar
Fan#: 101141
What I Drive: 2012 SGM SE Sport 5 Dr
Points 532, Level 10
Points: 532, Level: 10 Points: 532, Level: 10 Points: 532, Level: 10
Level Up 64% Completed
FF Reputation: 1 Seriously Focused Good Standing Member
Originally Posted by Elizabeth :
Ha ha hah...
Originally Posted by gun slayer View Post
very informative, thanks.
Careful Elizabeth, some of the Focus owners here are VERY serious AND sensitive about their issues................
Seriously Focused is offline
