Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus
Old 09-12-2012, 05:41 AM   #21
StockTalon
Guest
Fan#: 94771
What I Drive: 2012 Focus Titanium
FF Reputation: 1 StockTalon Good Standing Member
Originally Posted by Kabigon View Post
You couldn't pay me to use "racing oil" in a street car.
When Mobile changed their formulation, it cost me a turbo and a set of lifters. It cost a few others I know motors.
Out side of Brad Penn and Amsoil, VR-1 is the only one Id run. Only because, the other two are readily available around here.
Plus, its blue!
StockTalon is offline
Old 09-12-2012, 09:23 AM   #22
DBxprss
DBxprss's Avatar
Fan#: 102670
What I Drive: 2012 Sterling Gray Metallic SE
FF Reputation: 1 DBxprss Good Standing Member
FWIW, I use the Pennzoil Platinum synthetic oil and Purolator PureOne filters. PL10241 for the Focus.
I haven't felt the need to step up to the Pennzoil Ultra yet. I'm sure it's great oil, but I'm not sure what I would be gaining. I plan to stay with the recommended 5000 mile changes on the Focus, as I did with my 2011 Fiesta.
I also have a 96 Saturn that gets the same treatment (PL20195 filter), but I have been running 7500 mile change intervals on that one, with occasional oil analysis to keep an eye on things. So far there are 134,000 miles on the Saturn with very little oil consumption. A quart or less between changes. That's significant, because Saturns are notorious for being oil burners.
Nels
Manitowoc WI
2010 Focus SE w/Sport package
https://www.fuelly.com/driver/nels/focus
DBxprss is offline
Old 09-12-2012, 09:39 AM   #23
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2013 Race Red ST
FF Reputation: 2 cbdallas Good Standing Member
The last two times I was at WalMart, they had $5 instant coupons attached to all the Penz Ultra bottles, so it actually came out a few bucks cheaper than Platinum. I may go back & get more if it's still going on.
cbdallas is offline
Old 09-12-2012, 09:57 AM   #24
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: 2012 Red Candy Metallic SEL Sedan
FF Reputation: 9 kam327 Good Standing Member
I vote for Motorcraft synth blend and filter. They both are highly regarded on bobistheoilguy.com and you should be able to safely do 8-10k OCI depending on your driving habits. You can get both for around $23 if you DIY. Good luck!
kam327 is offline
Old 09-12-2012, 10:19 AM   #25
TboneZX3
TboneZX3's Avatar
Fan#: 90494
What I Drive: 2012 SE Sport 5Dr, SGM, 5-spd
FF Reputation: 5 TboneZX3 Good Standing Member
FYI... You should be able to run the larger PL20195 filter on your Focus also. The PL20195 is exactly the same as the PL10241 in all dimensions except for length. The PL20195 has a 1.38" longer can than the PL10241. Substituting the PL20195 will gain you a bit more oil capacity.
PL10241 = Motorcraft FL-910-S
PL20195 = Motorcraft FL-400-S - Likewise, this filter can be run on the 2012, as a larger substitute.
FWIW, I'm running Pennzoil Ultra in my 2012. If the Noack numbers are truly as low as what Pennzoil shows on the specs, it is better than Platinum by a large margin. I don't necessarily believe the specs, however.
'12 SE Sport 5Dr |╠╬╝|Sterling Grey Metallic|203a|Moonroof|17" Mach/Paint Whls|K&N Typhoon|FFE RMM|Steeda STB, RSB
TboneZX3 is offline
Old 09-12-2012, 10:41 AM   #26
DBxprss
DBxprss's Avatar
Fan#: 102670
Yes, I did this on the Saturn, which also originally had the shorty filter. I could not put the taller filter in the Fiesta because it rubbed on some hoses in front. I have yet to do my first change on the Focus, and I have not looked to see the clearance available. If I have room, I will definitely buy the taller filter. That way I can use the same filter for both cars and buy them in a larger quantity at a discount.
Nels
Manitowoc WI
DBxprss is offline
Old 09-12-2012, 11:13 AM   #27
foundonroadalive
Fan#: 46468
What I Drive: 2013 fiesta titanium blue candy
FF Reputation: 1 foundonroadalive Good Standing Member
advance auto parts has that same platinum plus deal for 19.95. they did not have my filter, so i got a free top of the line bosch. every month they or auto zone have several good combo deals.
foundonroadalive is offline
Old 09-12-2012, 08:10 PM   #28
dbenney
Fan#: 1195
What I Drive: 2012 Tuxedo Black SEL
FF Reputation: 2 dbenney Good Standing Member
Take this one for what its worth guys...
I have a buddy that use to work in a machine shop. He decided one day to start testing filters on some of their machining equipment. He tested everything from bosch to Fram... he said they ran a filter for a whole week then changed it and cut it apart to look for contaminants, after doing a pressure test. He said from the results he saw, the regular old orange Fram filters filtered out more and smaller particales than anyother brand.
Just some food for thought.
dbenney is offline
Old 09-12-2012, 08:43 PM   #29
Custodian
Custodian's Avatar
Fan#: 79355
What I Drive: 2011 SGM Focus Sedan SE
FF Reputation: 1 Custodian Good Standing Member
I had to make the same decision on our 2011... decided to stick with the Motorcraft syn-blend 5w-20 until the powertrain warranty is up... but dang, thats 60,000 miles... then may change to the Mobil 1 0w-20 Advance Fuel Economy.
Patrick
2011 Focus SE, 2010 Honda SH150i
5w-20 Motorcraft semi-syn until warranty has expired
Hankook Optimo H725 on Drag DR-33
General Altimax Arctic on OEM alloys
Custodian is offline
Old 09-12-2012, 10:29 PM   #30
fofo60
Fan#: 95976
What I Drive: 2012 Ingot Silver Metallic Hatchbac
FF Reputation: 1 fofo60 Good Standing Member
I am using either Motorcraft Synthetic Blend or Penzoil Platinum depending on the price. You might want to look at some of the used oil analysis information at the Bobistheoilguy website. Within the last couple of weeks someone posted a UOA on a 2012 Ford Focus.
fofo60 is offline
