2005 ZX3 wont turn over - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-11-2012, 02:16 AM   #1
John2139
Fan#: 45636
What I Drive: 2005, Orange Crush, ZX3
FF Reputation: 1 John2139 Good Standing Member
Hey guys need some help I have an 05 zx3 5speed will not turn over most of the time. I'm stuck been looking around on some of the forums. So things I have a check or replaced.
battery fully charged
new alternator
new starter
checked the clutch pedal switch and was good
lights do not dim when I try to start
I do hear a click under the dash
no security system issue
It will sometimes just turn over and start right up. So for right now I am push starting it to get to and from work and runs fine no
Any help would be great
Thanks
John2139 is offline
Old 09-11-2012, 10:11 AM   #2
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
Points 7,881, Level 59
Points: 7,881, Level: 59 Points: 7,881, Level: 59 Points: 7,881, Level: 59
Level Up 66% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
Problem could be in the ignition cyclinder.
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
FocusedSlayer is online now
Old 09-11-2012, 10:15 AM   #3
John2139
Fan#: 45636
I forgot to mention that I have a push button starter mounted in the dash that is run in parallel with the ignition cylinder. Its spliced into the wire loom. Using that it will not start ether. I test both and bothhave and are sending power.
John2139 is offline
Old 09-11-2012, 12:06 PM   #4
John2139
Fan#: 45636
So an update would not turn over was able to push start it now the battery light was on for the whole trip to work unless I was over 3k rpm then should turn off after a Minute at tat rpm. any suggestions ?
Thanks
John2139 is offline
Old 09-11-2012, 12:50 PM   #5
FocusedSlayer
has a screw loose
Fan#: 59042
Forum Activity 17%
If the battery light was on , maybe you can get it to a parts store and have them check for codes other than that it could be a loose or chaffed wire in your charging system . I would check everything from the battery to alternator and starter.
Old 09-11-2012, 01:12 PM   #6
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
Forum Activity 2%
That makes me think the ign switch and interlocks are not the problem, the click is the starter relay under the dash.
For some reason that relay is not activating the solenoid built into the starter, or the power circuit for the starter motor does not have continuity.
Battery cables, grounds, the fuseable link.
The signal is being sent, the starter is not responding.
elsolo is offline
Old 09-11-2012, 10:30 PM   #7
John2139
Fan#: 45636
how can i test the fuseable link. Looked around the forums did not see anything specific.
thanks
john
John2139 is offline
Old 09-11-2012, 10:52 PM   #8
Fattie
Fan#: 46016
What I Drive: 6 Duratec Focus
Points 8,431, Level 61
Points: 8,431, Level: 61 Points: 8,431, Level: 61 Points: 8,431, Level: 61
Level Up 94% Completed
FF Reputation: 5 Fattie Good Standing Member
Buy-Sell-Trade Rating: (6)
my guess would be ground.
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
Old 09-12-2012, 03:23 PM   #9
John2139
Fan#: 45636
well drove home last night after push starting it at work and drove it right into the local shop. There gonna take a look at it and call me with what is wrong hopefully. I will post what happens
John2139 is offline
Old 09-12-2012, 11:16 PM   #10
John2139
Fan#: 45636
Mechanic told me starter was bad. The new I just put on took it off and bench tested it it was fine. gonna take back and have them take another look at it.
John2139 is offline
