Stereo Installation in SEL? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-10-2012, 08:21 PM   #1
Mithan
Fan#: 103619
What I Drive: Toyota Echo
FF Reputation: 1 Mithan Good Standing Member
Hello guys.
Lets say I wanted to install a after market stereo and remove the 8" MFT system and replace it with a Pioneer or Kenwood or something, will I run into any issues with the touch screen climate controls and such all being disabled through the MFT? Or will it work fine?
Also, will after market steering wheel control converters work fine with Focus?
Thanks!
Mithan is offline
Old 09-10-2012, 09:44 PM   #2
ohnoy2k
ohnoy2k's Avatar
Fan#: 97037
What I Drive: 2012 Platinum White SEL Hatch w/DCT
Points 356, Level 7
Points: 356, Level: 7 Points: 356, Level: 7 Points: 356, Level: 7
Level Up 12% Completed
FF Reputation: 1 ohnoy2k Good Standing Member
Yes you will run into problems and no the steering wheel buttons won't work
Sent from my MB860 using FF Mobile
ohnoy2k is offline
Old 09-10-2012, 10:10 PM   #3
Wildsailor
Fan#: 102694
What I Drive: 12 SE Sport Sedan - Sterling Gray
Points 427, Level 8
Points: 427, Level: 8 Points: 427, Level: 8 Points: 427, Level: 8
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
Forum Activity 7%
FF Reputation: 3 Wildsailor Good Standing Member
Crutchfield shows no compatible audio systems for the 2012 Focus. Whatever you would do would have to be a hack job with unforeseen results.
Wildsailor is offline
Old 09-11-2012, 11:57 AM   #4
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 993, Level 16
Points: 993, Level: 16 Points: 993, Level: 16 Points: 993, Level: 16
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 6%
FF Reputation: 4 Tiger-Heli Good Standing Member
Actually, it is probably possible.
(Expensive, but possible.)
Metra offers this kit and a wiring harness for the non-MFT system.
YouTube Video
http://www.metraonline.com/files/pro...-5827B_web.pdf
I e-mailed Metra and asked whether that kit would work on an MFT and they said they hadn't tested it and couldn't verify that it would work.
What I would recommend doing is removing the trim and unplugging the MFT connectors and driving the car and seeing what happens.
You have redundant manual controls for the HVAC, so I think you will be fine, unless Ford sends a trouble code somewhere if the radio is disconnected.
If you don't see any issues with the radio removed, installing the new radio should be no problem, other than the Metra dash kit and wire harness kit are somewhat pricy, and the Metra kit has a cutout for the 4.3-inch display that you don't have, so you would want to block that off.
I'd buy from somewhere with a liberal return policy if you attempt it, though.
Tiger-Heli is offline
Old 09-11-2012, 12:00 PM   #5
Tiger-Heli
Fan#: 12379
Forum Activity 6%
If you KNOW you want to install a Kenwood or Pioneer, you would be better off NOT getting the MFT system as that is designed to work - unless you are looking at a Titanium which has it standard.
As far as I know, steering wheel controls should work fine with the correct harness adapter.
Old 09-11-2012, 12:07 PM   #6
Wildsailor
Fan#: 102694
Points 427, Level 8
Forum Activity 7%
* Snip
* Snip
Yes, it will log trouble codes and it may significantly alter the resistance of the CAN circuits such that it may disturb the operation of the CAN. It will be a missing module on the CAN bus so that trouble code would be there for sure, and some of the information displayed in the Cluster is transmitted to/through the Sync system. The vehicle should continue to operate but the interior systems will have eratic operation.
Old 09-11-2012, 05:21 PM   #7
Tiger-Heli
Fan#: 12379
Forum Activity 6%
I didn't think about the climate info probably going across the data lines.
If you REALLY wanted to do it, you should be able to leave the data lines connected to the Sony HU, mount that behind the dash (???), and route the power and speaker wires to the new Kenwood/Pioneer.
Not sure how Metra's harness adapter would tie into this, but it should be workable.
(Metra's harness supplies an accessory power connection when the non-MFT radio is replaced, but I'm not sure how it handles the data nodes/modules - i.e. if you had the Metra adapter, I don't know if it could be used with the MFT or not ...)
Old 09-11-2012, 05:42 PM   #8
Tiger-Heli
Fan#: 12379
Forum Activity 6%
To simplify what I posted above:
The new radio only needs constant power, switched power, ground, and speaker connections (and maybe a parking brake or vehicle speed sensor input) to work and a secure way of mounting it.
You have both of those (well, accessory power is complicated), so the new radio can work fine.
The question is what to do with the MFT radio unit and whether it can be disconnected or not.
