Old 09-13-2012, 05:49 PM   #11
sgtsmasher
sgtsmasher's Avatar
Fan#: 65000
What I Drive: is a money pit
FF Reputation: 2 sgtsmasher Good Standing Member
yea thats what it appears like in the pictures and parts list...dammit, and the guy i bought the kit off of isnt returning my texts...
Hatch Nation #72
Call Me BRANDO or SGT BRANDO
sgtsmasher is offline
Old 09-13-2012, 09:36 PM   #12
Autoxing_se
Fan#: 57950
What I Drive: 2001 Focus Powerworks SE
FF Reputation: 2 Autoxing_se Good Standing Member
If it is the correct ones there is a loop on the back side that slipped over a portion of the caliper. Unhook this then, try to thread to e-brake after this attach it back to the caliper.
Instructions from ford racing on how to put on the brakes.
http://www.fordracingparts.com/downl...m-2300-zx3.pdf
Autoxing_se is offline
Old 09-17-2012, 01:00 PM   #13
sgtsmasher
sgtsmasher's Avatar
Fan#: 65000
No thats still not the case, you need the ebrake handle cable, the length on the stock zx3 is to short to work with the rest of the ebrake setup from the svt
Hatch Nation #72
Old 09-17-2012, 10:16 PM   #14
Autoxing_se
Fan#: 57950
The brake lines for the advance track and svt are the same. I went from advanced track rear disc to svt disc with no problems. Can you get a picture of how you have them run.
Old 09-19-2012, 01:18 PM   #15
sgtsmasher
sgtsmasher's Avatar
Fan#: 65000
i ran the cable in the exact same place as the stock zx3
Hatch Nation #72
Old 11-21-2012, 05:59 PM   #16
ilarson007
ilarson007's Avatar
Fan#: 82763
What I Drive: 2002 Bright Atlantic Blue(?) ZX3
FF Reputation: 1 ilarson007 Good Standing Member
Originally Posted by sgtsmasher View Post
the metal piece that hook the ebrake handle cable and cables
How did you get this picture? Did you have to take the exhaust heat shield off?
I have to replace my e-brake cables from the splitter back. One side clamps well, the other side not at all. I figure I should just replace both since both show signs of wear on that outer tube.
ilarson007 is offline
Old 11-23-2012, 06:59 AM   #17
sgtsmasher
sgtsmasher's Avatar
Fan#: 65000
you know i did finally get everything so work with the cables and the rear svt brake calipers...what a good friend figured out is that the ebrake cable hooks are bolted on the caliper...and when you take them off they have splines like on the end of an axle. so what they did was took it off, put all the cables on so they matched length while the handle was all the way down. put the hook in the eyelet, put it in the hole put some tension on it bolted it back in...blam i had ebrakes again. i never know that the ebrake hooks had splines on the insideof it...if i had known that i would have had the my friend at his shop do it...
Hatch Nation #72
Old 01-08-2013, 07:55 AM   #18
ilarson007
ilarson007's Avatar
Fan#: 82763
Also, for everyone's information, you do have to take off the heat shield for your exhaust to change the rear sections of e-brake cable.
