Dreading the "To Do" on the SVT... need pointers... - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-04-2013, 09:15 AM   #21
Missourileo
Captain Retard
Missourileo's Avatar
Fan#: 55980
What I Drive: 2002 Black SVT ZX3,93 SVT Lightning
Points 5,373, Level 47
Points: 5,373, Level: 47 Points: 5,373, Level: 47 Points: 5,373, Level: 47
Level Up 12% Completed
FF Reputation: 20 Missourileo Great Standing Member
Buy-Sell-Trade Rating: (17)
The t-belt is an easy job for the mechanically inclined, not so easy for others. If you do take it to a shop(which I don't recommend), make sure it's one that has done this before, on an SVTF. Reason being, most shops screw this up. I have done 8 of these and know it takes about 3 hours, you should change the water pump as well as the serpentine belt and you DO NEED the timing tools. Forget about the white dot crap. The belt walks 6 teeth per revolution. I have the Ford workshop manual on this that gives you specific step by step pics and instructions, if you're interested. I can email it to you. Also, did you change your valve cover gasket before changing the T-stat housing? If not, that's the reason the O-ring goes bad in the housing. Oil leaks down the head and onto the housing, look for yourself.
"It's the Veteran who salutes the flag, serves beneath the flag, and whose coffin is draped by the flag."
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Missourileo is offline
Old 01-04-2013, 09:19 AM   #22
MustangCRZY302
MustangCRZY302's Avatar
Fan#: 72764
What I Drive: 2004 Sonic Blue SVT 3dr
Points 1,950, Level 26
Points: 1,950, Level: 26 Points: 1,950, Level: 26 Points: 1,950, Level: 26
Level Up 50% Completed
FF Reputation: 8 MustangCRZY302 Good Standing Member
Yea I can see how it would leak down. My Valve Cover gasket is just fine though. Its not even seaping above the Tstat housing. I will be changing that gasket though when I do the timing belt.
SOLD - 2004 Sonic Blue SVT, 1,185 of 1,978, K&N Filter, Steeda Tri-Ax, Steeda Front Strut bar,Eibach Sway Bars, Fog-Light Mod, Yellow Fogs
1990 Mustang LX 5.0L, Project/race car Vortech'd, DSS Forged 331ci Stroker, 10psi
www.ajsracing.net
MustangCRZY302 is offline
Old 01-04-2013, 09:38 AM   #23
loc0gring0
loc0gring0's Avatar
Fan#: 85659
What I Drive: not enough spaces to list all
Points 5,305, Level 46
Points: 5,305, Level: 46 Points: 5,305, Level: 46 Points: 5,305, Level: 46
Level Up 78% Completed
FF Reputation: 1 loc0gring0 Good Standing Member
timing belts are a cake walk.. if you sit and read the ""book way"" it seems scary... you do not need timing tools or even have to take the valve cover off.. just make sure your mark everything correctly and you don't need tools or have to time anything.. ive done about 10 and knock them out in a few hours with a lunch break..
3 focus supercharged
1 turbo
20+ fsvt
04 saleen n2o weekend warrior
loc0gring0 is offline
Old 01-05-2013, 10:20 AM   #24
cmajaa
Fan#: 73417
What I Drive: 2003 ZTW zetec
FF Reputation: 1 cmajaa Good Standing Member
Do it with the alignment tools and exactly the way its explained by ford and you won't have any problems, I've done two cars so far and have never had any codes.
cmajaa is offline
Old 01-12-2013, 04:21 PM   #25
LD5050
LD5050's Avatar
Fan#: 94329
What I Drive: 04 SVTF
FF Reputation: 1 LD5050 Good Standing Member
I had a shop do my timing belt, and I provided them with the cam tool since it's cheap. After researching on here I also had the following preventative maintenance:
timing cover seal
valve cover gasket
VCT solenoid
water pump & gasket
I didn't want to deal with any of these known-issue parts giving me grief down the road, one fell swoop kinda thing.
I should have also done the cam and crank seals.
LD5050 is offline
Old 08-11-2013, 01:37 PM   #26
MustangCRZY302
Fan#: 72764
Just got the timing belt done. about 2.5 hours with a buddy, no issues at all. The horror stories on here make it worse than it sounds.
www.ajsracing.net
Old 08-12-2013, 10:45 AM   #27
MustangCRZY302
Fan#: 72764
Now I need to find the correct CV shaft for the passenger side, as the carrier bearing starting howling... getting really loud too
www.ajsracing.net
Old 08-14-2013, 04:29 AM   #28
SVTFOOCUS
SVTFOOCUS's Avatar
Fan#: 39017
What I Drive: TurboL'd 03 SVT FOCUS ZX5
Points 1,750, Level 24
Points: 1,750, Level: 24 Points: 1,750, Level: 24 Points: 1,750, Level: 24
FF Reputation: 4 SVTFOOCUS Good Standing Member
The timing belt really isn't that big of a pain, except for the first time around maybe. I have changed mine out within a hour I think before. But I've also taken the engine completely apart a couple times. =0) The SVT is very easy to work on (inside and out), part of why I like it so much.
2003 SONIC BLUE SVT ZX5 #0258...
Turbo Charged, RC injectors, Stage 4 Clutch, 3" Exhaust from DP back, throttle body, Torsen Differential, A/F & Boost gauges in dash, Diablo Tune, J&S Safeguard, Custom powder-coated wheels
SVTFOOCUS is offline
Old 08-14-2013, 08:10 PM   #29
Jack The Ripper
Jack The Ripper's Avatar
Fan#: 81179
What I Drive: '04 SVT ZX5 & '10 Mustang V6
FF Reputation: 1 Jack The Ripper Good Standing Member
In what gear(s) do you hear the howling noise? I might be having this issue. I assumed it was the flywheel, but maybe this is the problem? It only happens to me in 5th and 6th. Sounds like I have a high PSI supercharger lol.
SoCal Crew #666
Jack The Ripper is offline
Old 08-14-2013, 08:17 PM   #30
MustangCRZY302
Fan#: 72764
lol nah mine is in every gear. even neutral. lol i jacked the car up and spun the wheels, and 'felt' the noise on the carrier bearing that supports the pass side cv shaft.
www.ajsracing.net
