Brake pedal goes to the floor – sometimes - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-10-2012, 11:31 AM   #1
suznal
Fan#: 102830
What I Drive: 2005 Gray ZXW
Points 390, Level 7
Points: 390, Level: 7 Points: 390, Level: 7 Points: 390, Level: 7
Level Up 80% Completed
FF Reputation: 1 suznal Good Standing Member
The brakes on my ’05 ZXW (with ABS) work just fine until I’m stuck in traffic.
When I’m “crawling” to get into an event, or when there is highway construction (“UGHH!”) my foot rarely leaves the brake pedal. Instead I release pressure just enough to let the car creep until I have to come to a complete stop again. Sometimes when doing this for a while – out of the blue the pedal will go to the floor! I have to completely release the pedal then re-apply pressure and the brakes work fine again.
This is the only circumstance that the brakes fail, like I said, at all other times the brakes are just fine.
What are some things I should look into?
suznal is offline
Old 09-10-2012, 12:24 PM   #2
DerbyDave
DerbyDave's Avatar
Fan#: 103584
What I Drive: 2002 Silver ZX5
FF Reputation: 1 DerbyDave Good Standing Member
It sounds like you have an internal leak in your brake master cylinder. With steady pressure the brake pedal should not move, if it does then it is time for a master cylinder replacement.
2002 Ford Focus ZX5 2.0 Zetec MTX
2003 Ford Escape 3.0 Duratec
DerbyDave is offline
Old 09-10-2012, 01:07 PM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,752, Level 73
Points: 12,752, Level: 73 Points: 12,752, Level: 73 Points: 12,752, Level: 73
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 99%
^^ yep, when you take it apart you may find some brake fluid inside the "dust boot" - that would be extra confirmation of the problem.
"pumping" the brake pedal just to stop ain't fun!
A bit of a PITA to replace it & bleed the whole system, but WELL worth it!
sailor is online now
Old 09-10-2012, 01:19 PM   #4
suznal
Fan#: 102830
Points 390, Level 7
The brake pedal doesn't move under steady pressure, I can hold it for over a minute without movement.
When I experience the problem, pumping does nothing - I have to completely release the pedal and then she's good as new.
That's what has me confused and wondering if (like all these newfangled elctronic gizmos) it had something to do with a sensor or the brain?
suznal is offline
Old 09-10-2012, 02:08 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
as usual, it's hard to tell exactly what's going on from a distance....
Releasing & reapplying pressure to the brake pedal is usually considered "pumping", even if only the one stroke is required - and I think you mentioned it going to the floor.....
Was your steady pressure test done with the car running, or with it shut off??
(Brake vacuum booster &/or ABS can change your feel & how the system reacts....)
For example, you can have a QUITE firm pedal with the car off - but once it's running & the booster is functioning, the pedal might not feel so good....
ABS issues COULD come into play, that's why I mentioned the leakage found at the brake cyl. as a confirmation that you actually have an issue there before pulling it apart completely & replacing the master cyl..
luck!
Old 09-10-2012, 02:16 PM   #6
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2014 Titanium 5-speed
Points 2,446, Level 29
Points: 2,446, Level: 29 Points: 2,446, Level: 29 Points: 2,446, Level: 29
Level Up 98% Completed
FF Reputation: 3 cbdallas Good Standing Member
The master cylinder is bypassing, but not consistently. Get it replaced before it gets worse.
cbdallas is offline
Old 09-10-2012, 02:33 PM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Considering the consequences of driving it with brakes you can't be sure of, diving in and solving the issue is imperative!
And the cost of a replacement master cyl. & the time needed to install it is a small price to pay when you are no longer confident of it's functioning properly!
Some things you just DON'T want to put off until the repair becomes TOO obvious!
Old 09-10-2012, 02:48 PM   #8
suznal
Fan#: 102830
Points 390, Level 7
Steady test both car running and off.
I did bleed the lines thinking there might be air - no air found in the lines.
Guess I'll get the Hanes manual out tonite and get ready to start calling around for price and availability.
Thanks for the help!
suznal is offline
Old 09-10-2012, 10:37 PM   #9
focusgg
Fan#: 96641
What I Drive: 2005 ZX4
Points 42, Level 1
Points: 42, Level: 1 Points: 42, Level: 1 Points: 42, Level: 1
Level Up 84% Completed
FF Reputation: 1 focusgg Good Standing Member
Ditto
I have the exact same problem Suznal is describing, and it occurs under the exact same circumstances.
Suznal - I would be interested in hearing if replacing the master cylinder solves the problem and if you found an other evidence while replacing it that would suggest it was definitely the master cylinder, e.g. visible leaks.
focusgg is offline
Old 09-11-2012, 01:27 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Agreed focusgg, brake fluid above the piston would prove the issue once the master is pulled away from the booster for inspection.
interesting that he can't duplicate the issue in the driveway.....
