Does anyone know? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-10-2012, 01:51 AM   #1
Hondaracer8
Fan#: 102671
What I Drive: 07 Focus Dtech 2.0 Automatic sedan
Points 348, Level 6
Points: 348, Level: 6 Points: 348, Level: 6 Points: 348, Level: 6
Level Up 96% Completed
FF Reputation: 1 Hondaracer8 Good Standing Member
Does anyone know?
Is it possible to wire up another amp into the pre existing amp to run aftermarket subs. Came out of my old car and this Sony system just isn't cutting it. I only ask because the current amp, which I'm sure of your answering this you know, is hooked up with wire harnesses, which means I cannot remove it. Maybe there some way to splice into the power going to it?
Hondaracer8 is offline
Old 09-10-2012, 09:33 AM   #2
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
Points 7,836, Level 59
Points: 7,836, Level: 59 Points: 7,836, Level: 59 Points: 7,836, Level: 59
Level Up 44% Completed
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
If you get a distribution block and your power wire is big enough from the battery to it you can do several amps in a system.
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
FocusedSlayer is online now
Old 09-10-2012, 10:40 AM   #3
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
yes it is possible. as stated above you will need to run a power wire from the battery. you can get audio signal from the factory amp (i don't know if it's high or low level) and you might be able to get a turn on from it as well as long as it's a 12 volt turn on and not digital. if it's digital then you will need to run it from the ignition.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 09-10-2012, 02:04 PM   #4
Hondaracer8
Fan#: 102671
Points 348, Level 6
But no matter what I need to strip the car down to run a power and ground?
Old 09-10-2012, 03:11 PM   #5
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,606, Level 53
Points: 6,606, Level: 53 Points: 6,606, Level: 53 Points: 6,606, Level: 53
Level Up 28% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
You do not have to take everything out to do the power wire.. Pull the drivers seat, The kick panel trim, the long piece of trim next to where the seat goes, the bottom seatbelt bracket pull back the carpet and start pulling wire.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
