2010 ford focus gas pedal vibration - Focus Fanatics
Old 09-09-2012, 06:17 AM   #1
ghostrider_14
Fan#: 60668
What I Drive: 2013 corolla s/2005 black zxw
FF Reputation: 1 ghostrider_14 Good Standing Member
Hey guys my 10 ses has a horrible vibration in the gas pedal when I'm on the gas but nothing when I'm in cruise control. The tires are cupped and the car needs an alignment is this what is causing the pedal vibration oh and it fells like my brakes are skipping when I go to stop
ghostrider_14 is offline
Old 09-09-2012, 07:30 PM   #2
coldbear
Fan#: 78292
What I Drive: 2001 Burgandy ZXT
FF Reputation: 1 coldbear Good Standing Member
I'd start with a right motor mount. Takes about 20 minutes to change with MM sockets. That's your vib.
coldbear is offline
Old 09-09-2012, 07:32 PM   #3
RAF_S197
RAF_S197's Avatar
Fan#: 91991
What I Drive: 2014 Oxford white Sport Black Pack
FF Reputation: 21 RAF_S197 Great Standing Member
If its a motor mount it should be under warranty
2014 Oxford white Focus SE Sport Black pack
Instagram: 5_POINTOH
RAF_S197 is offline
Old 09-10-2012, 06:01 AM   #4
coldbear
Fan#: 78292
Sorry I didn't hear your mileage on the unit.? It might be plug wires, as one lost cylinder on a 4 banger causes lots of shakes.I buy my wires at NAPA [lifetime gaurentee] and change em' out with new plugs every 24-30 K miles.NAPA never questions the exchange of wires.
coldbear is offline
Old 09-10-2012, 11:11 AM   #5
RAF_S197
RAF_S197's Avatar
Fan#: 91991
K
No plugs on our cars and the coils should more than likely be ok.
Any check engine light? You can pull a plus out and have a look at it to see if they need replacing.
Still doesn't explain that you'r gas pedal is vibrating. How's the motor running?
RAF_S197 is offline
Old 09-10-2012, 01:23 PM   #6
sailor
"Elder"
sailor's Avatar
Fan#: 57268
FF Reputation: 60 sailor Excellent Standing Member
Yup, and a "2010" should be "fly by wire" so the pedal vibration could only be a harmonic vibration caused by something else.....
The "cupped tires" certainly COULD be the actual issue, as they are likely to vibrate quite a bit!
When the alignment gets done, suspension joints, wheel bearings & brakes should be checked at the same time. Anything worn & loose could contribute to the problem - without knowing the mileage it's impossible to guess how likely that would be, but such a check for loose components is normal before wasting time trying to align something too loose to accurately align!
Luck!
sailor is offline
