needing some help - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-08-2012, 08:09 PM   #1
1sloho
12 years strong
1sloho's Avatar
Fan#: 111
What I Drive: '02 zx5
Points 14,517, Level 78
Points: 14,517, Level: 78 Points: 14,517, Level: 78 Points: 14,517, Level: 78
Level Up 17% Completed
FF Reputation: 17 1sloho Great Standing Member
needing some help
so a wire came loose from the back of my headunit for my amp, amp is wired into the ignition. pulled the headunit out and fixed the problem. amp was on and everything was working correctly. go to shove the wires back into the dash and put the headunit back in and everything just turned off. checked the fuses and wires again to make sure nothing came loose and everything is fine. ive got power to the headunit but, the display isnt coming on and no buttons are working, except if i were to push the cd eject button, u can hear the motor inside. and if i take the faceplate off, the lil antitheft light blinks. im at a loss.......
1sloho is online now
Old 09-09-2012, 12:16 AM   #2
mix1983
Life Is Good
mix1983's Avatar
Fan#: 61101
What I Drive: 2000 Honda Civic EX 5spd
Points 9,172, Level 64
Points: 9,172, Level: 64 Points: 9,172, Level: 64 Points: 9,172, Level: 64
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 6%
FF Reputation: 5 mix1983 Good Standing Member
My HU has a reset button.. maybe look for that and hold it for a few seconds. That or I guess you could disconnect the battery for a while. Something got jolted and the HU went retarded, but I think it should be an easy fix.
I'm all about sharing the road with other drivers - as long as they use the part that's behind me.
mix1983 is online now
Old 09-09-2012, 01:08 AM   #3
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,720, Level 94
Points: 23,720, Level: 94 Points: 23,720, Level: 94 Points: 23,720, Level: 94
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 13%
check your under dash fuses. or check if the cigarette lighter works. I believe the two are tied together. I had what sounds like the same problem a long time ago. I remember then I couldn't get the thing to work but the eject button would, so I wired the two together. Then one day I found a bad fuse down there and it worked since.
mikebontoft is online now
Old 09-09-2012, 01:41 AM   #4
Now534
Now534's Avatar
Fan#: 76549
What I Drive: 2013 Tuxedo Black ST2
Points 1,791, Level 24
Points: 1,791, Level: 24 Points: 1,791, Level: 24 Points: 1,791, Level: 24
Level Up 91% Completed
FF Reputation: 6 Now534 Good Standing Member
Try to pull plug out from the radio and see if a fuse is there its like that on my pioneer
Now534 is online now
Old 09-09-2012, 09:39 AM   #5
1sloho
12 years strong
1sloho's Avatar
Fan#: 111
tried that, no dice.
ive checked all the fuses and they are all fine. maybe ill just pull all of em and check em. lol
already done it, and it was good.
Old 09-09-2012, 07:56 PM   #6
02Zetechse
02Zetechse's Avatar
Fan#: 65832
What I Drive: 2002 Satin Black SE
FF Reputation: 6 02Zetechse Good Standing Member
sounds to me like either the power or memory wires came undone ... the memory will allow a cd eject but without the main power, the headunit will not power on
Current : 2 15s 149.5@56hz 2k rms Previous Trunk box 1 18 ,146.4@43hz 3500rms,Sony 12s 145.6@63hz
02Zetechse is offline
