Transmission took a dump - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-10-2012, 05:29 PM   #11
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
FF Reputation: 5 DarderSauce Good Standing Member
I would shop around, I have seen transmissions with fewer miles cheaper than that.....
But then again you're not really paying for the transmission you are paying for labor.
If you can't wear it out, burn it off
DarderSauce is offline
Old 09-10-2012, 07:39 PM   #12
patatoe
Fan#: 102891
What I Drive: 2008 Grey SE
FF Reputation: 1 patatoe Good Standing Member
Well i brought it into ammco today. The guy said he thought it could be the computer or a solenoid. He said he needed to get a wiring diagram before he new if it was or not. Any info based off that?
patatoe is offline
Old 09-11-2012, 12:18 PM   #13
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
Points 1,735, Level 24
Points: 1,735, Level: 24 Points: 1,735, Level: 24 Points: 1,735, Level: 24
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 5 Miller88 Good Standing Member
Solenoids have always been a problem in these transmissions
2011 Focus SE 5 Speed 36k - Blue Flame Metallic - Added Rear Swaybar
2000 Jeep Cherokee Sport 115k - Lifted with mud tires.
Miller88 is offline
Old 09-11-2012, 04:00 PM   #14
patatoe
Fan#: 102891
I think that's what I'm hoping for at this point. Replacing a solenoid shouldn't be to expensive, especially compared to rebuilding the transmission right? Would a bad solenoid cause the banging/clunking from P-R and R-N-D?
patatoe is offline
Old 09-11-2012, 04:01 PM   #15
patatoe
Fan#: 102891
patatoe is offline
Old 09-11-2012, 04:53 PM   #16
Miller88
Fan#: 73790
Harsh shifting from Neutral/Park to drive/reverse is usually bad accumulators.
What are the problems you are having with the transmissions.
Miller88 is offline
Old 09-12-2012, 09:34 AM   #17
patatoe
Fan#: 102891
Well its been "slamming" into reverse and in between N and R+D same thing. Eagle transmission also said that it over revs between 2nd and 3rd gears. Bit the bullet and dropped it off at Ford this morning, hopefully by late afternoon I'll have a diagnosis.
patatoe is offline
Old 09-12-2012, 10:54 AM   #18
Miller88
Fan#: 73790
The banging from N/P to drive or reverse could be bad accumulators or it could be an improperly installed motor mount.
The over revving, if it's a shift flare, could very well be caused by bad solenoids in the transmission.
Miller88 is offline
Old 09-12-2012, 11:45 AM   #19
patatoe
Fan#: 102891
Thanks for the replies Miller.
I had two of the motor mounts replaced last week, but the problem is still there. Possibly due to them being installed incorrectly, but I'd hope they had that done correctly. Hopefully it ends up being solenoids, that seems to be the cheapest repair that I'll be faced with.
I'll be sure to update once I get the diagnosis from Ford.
patatoe is offline
Old 09-12-2012, 01:18 PM   #20
patatoe
Fan#: 102891
UPDATE: So, Aamco called me back this afternoon. He said that after looking at the diagrams and whatnot, he is confident it is not an internal problem. He suspects that it is either the computer or valve body. It will cost $275 to have Aamco test for which it is.
patatoe is offline
