Overheating and HI/LO Cooling Fans Not coming on - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-06-2012, 10:05 PM   #1
ZX2003
ZX2003's Avatar
Fan#: 98743
What I Drive: 2003 Pitch Black ZX3
Points 372, Level 7
Points: 372, Level: 7 Points: 372, Level: 7 Points: 372, Level: 7
Level Up 44% Completed
FF Reputation: 1 ZX2003 Good Standing Member
So my '03 zx3 started overheating recently while at stand stills, or constant stop and go traffic as in the city. Neither of my cooling fans come on. I've been reading all about the various cooling system problems related to the fan that the Foci have, but mine seems to be a combination of it all.
First thing I checked was the cooling fan resistor since I read that was the most common problem. So i took it out, and turns out the connector was blown out. I spliced in a new connector and resistor and thought that would solve it. Nope.
So then i started checking everything else. Ppl pointed to the 30a low cooling fan fuse, it was good, but no power going to it. Looked at wiring diagram found out that before that fuse there is the 50a fuse. It was blown. So replaced that. Still not working. I tested the relay, it's fine too.
Now its basically down to the cooling fan motors. I really don't want to replaces the entire thing, but i might have to. I'm just hoping someone has some insight on somethign else that could be causing the problem. I dont want to keep throwing money/and parts at this thing.
Thanks!
ZX2003 is offline
Old 09-07-2012, 12:12 AM   #2
duc450
duc450's Avatar
Fan#: 10651
What I Drive: 2004 Ford Focus SVT CD Silver
FF Reputation: 4 duc450 Good Standing Member
Have you tried running a 12v source directly to the fan to see if it will come on? Also if you spin them by hand are they making any strange noises?
"If you ain't moving fast enough your costing me money and if your costing me money you ain't moving fast enough." -"The Machine"-
duc450 is offline
Old 09-10-2012, 01:35 AM   #3
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,618, Level 31
Points: 2,618, Level: 31 Points: 2,618, Level: 31 Points: 2,618, Level: 31
Level Up 12% Completed
I would check to see if the fan relays are getting a "on" signal, if the power input side to the relay is hot, and bench test the relays.
elsolo is offline
