Oil Leak: Dealer said Ford stated This is NORMAL - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-05-2012, 06:33 PM   #11
WV_TI
WV_TI's Avatar
Fan#: 96205
What I Drive: 2012 St. Gry Met Titanium
FF Reputation: 1 WV_TI Good Standing Member
Originally Posted by BetaDnB View Post
While I agree no new vehicle should have any leaks, if you bought a Harley you'd expect it to leak oil as a normal condition.
I am sorry to burst you bubble, but Harleys do not leak oil, umm, since like the 80's(AMF days). I have one, as well as 3 of my friends ranging from a 2002 up to a 2010, and none of them leak a drop.
But I have to agree on the Focus leaking........it just shouldn't, and is not normal.
WV_TI is offline
Old 09-05-2012, 06:40 PM   #12
scott7278
Fan#: 100021
What I Drive: 2012 Red Candy SEL Hatchback
Points 1,464, Level 21
Points: 1,464, Level: 21 Points: 1,464, Level: 21 Points: 1,464, Level: 21
Level Up 64% Completed
FF Reputation: 5 scott7278 Good Standing Member
I've often wondered if these dealers don't get reimbursed enough by Ford to make it worth their time.
Sent from my Android using FF Mobile.
scott7278 is online now
Old 09-05-2012, 06:43 PM   #13
YesMAN
Fan#: 102901
What I Drive: '12 SEL
FF Reputation: 1 YesMAN Good Standing Member
What else do they do with their time then? I thought the vast majority of their business was warranty work? Most people whose cars are out of warranty don't take them to a dealer for repairs. I can see some shops avoiding certain high-risk jobs though.
YesMAN is offline
Old 09-05-2012, 07:02 PM   #14
scott7278
Fan#: 100021
Maybe certain things aren't worth it?
Old 09-05-2012, 07:15 PM   #15
YesMAN
Fan#: 102901
Wonder if this will start to become more common. Manufacturers getting out of certain warranty jobs by making reimbursements so low no dealer will do them.
YesMAN is offline
Old 09-05-2012, 07:41 PM   #16
dbenney
Fan#: 1195
What I Drive: 2012 Tuxedo Black SEL
Points 928, Level 16
Points: 928, Level: 16 Points: 928, Level: 16 Points: 928, Level: 16
Level Up 28% Completed
FF Reputation: 5 dbenney Good Standing Member
well it really doesnt matter.... a 5 yr 60,000 mile warranty is just that... tell them they will hear from your lawyer and c what happens
dbenney is offline
Old 09-05-2012, 08:41 PM   #17
socalrider66
Fan#: 101022
What I Drive: 2012, Silver SEL
Points 11, Level 1
Points: 11, Level: 1 Points: 11, Level: 1 Points: 11, Level: 1
Level Up 21% Completed
FF Reputation: 1 socalrider66 Good Standing Member
I noticed this same leak on my SEL when peforming the first oil change. I took it to the dealership for them to check and was also told it was excess lubricant seeping out from the assembly of the car. I simply told them okay and that I would keep an eye on it. I did not notice anything seeping out when I did my last oil change, which would be its fourth oil change as I have about 28K miles on my car already.
socalrider66 is offline
Old 09-05-2012, 11:42 PM   #18
Kabigon
Fan#: 88299
Points 4,213, Level 41
Points: 4,213, Level: 41 Points: 4,213, Level: 41 Points: 4,213, Level: 41
Level Up 32% Completed
Forum Activity 22%
Activity: 22% Activity: 22% Activity: 22%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by unfocused1 View Post
Seconded.
Mine does not leak.
Most peoples' cars don't.
Nor should they.
That dealer, or at least it's mechanical department, should feel ashamed, if nothing else more pragmatic. People really should be sick of outright lies being pawned off to paying customers, which is no way to run a business - either successfully or in any other form. Is there no ethics, no justice, no fairness, no anything anymore?
Apparently you haven't read TSB 11-12-13.
Kabigon is offline
Old 09-06-2012, 07:25 AM   #19
pozi240
Fan#: 94835
What I Drive: 2012 Focus 5 door SEL Kona Blue
FF Reputation: 4 pozi240 Good Standing Member
I was aware of that TSB (Automatic Transmission Fluid leak), but, can't find the actual TSB to read it. Please post it up for everyone, especially if you're referencing it in a response, thank you. (I know, your response wasn't directed at me, I'm curious as well is all)
2012 Focus SEL 5 door 303a w/Lux pkg in KonaBlue
2012 Escape Limited w/park assist
2010 F150 Supercrew XTR 5.4 4x4
2008 Kawasaki Concours 14 (street)
2008 Kawasaki ZX10R (track only)
pozi240 is offline
Old 09-06-2012, 07:55 AM   #20
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,264, Level 28
Points: 2,264, Level: 28 Points: 2,264, Level: 28 Points: 2,264, Level: 28
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 6%
FF Reputation: 13 BetaDnB Great Standing Member
I found this info for you from this thread.
Originally Posted by bball40dtw View Post
I just got my Focus back from the dealership. The trans was slipping and the car was shuddering. I've had the TSB reflash of the transmission. Here is the description of the work done:
23001 WARR, CC D8CP 7052 Road test inspect driveline found dual clutch slipping due to leak at bellhousing. Check oasis for tsb's and ssm's found TSB 11-12-13. Remove trans and install new input shaft seals and new dual clutch. Perfrom adaptive learning and reroad test operation 111213A. Time 6.5 HRS
The parts to fix included:
2 seal assemblies
Clutch assembly/dual clutch packs
Various nuts and bearings
So far so good. The car is also getting better MPGs, but its probably to know for sure.
I also discovered this TSB list thread while searching.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is online now
