Oil Leak: Dealer said Ford stated This is NORMAL - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-05-2012, 03:22 PM   #1
Dysan911
Fan#: 95746
I took my car in because there's oil seeping from between the Engine and The Transmission. Also a very metallic rattle when the car is in 6th gear and low RPM's. Like going up an incline at almost 40mph.
I just got a call and they said the tech couldn't reproduce the noise and the Oil leak is normal. Its not oil she said,. its some sort of factory fluid that they use during assembly and quite normal for it to leak.
I have officially HEARD THEM ALL now!. THank you FORD!.
I told her that It never did that before and she said that the Tech has had quite a few cases where they saw that same leak and contacted Ford and was told that was a Normal condition of this vehicle.
Dysan911 is offline
Old 09-05-2012, 03:27 PM   #2
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2014 Titanium 5-speed
Points 2,446, Level 29
Points: 2,446, Level: 29 Points: 2,446, Level: 29 Points: 2,446, Level: 29
Level Up 98% Completed
FF Reputation: 3 cbdallas Good Standing Member
Why would they contact Ford about a leak? This sounds like a big, fat lie to me.
Take it to a different dealer, and when they fix it, call Ford & tell them this story. No car should be leaking ANY kind of fluid, regardless if it was used during assembly (which is B.S.)
cbdallas is offline
Old 09-05-2012, 03:52 PM   #3
scott7278
Fan#: 100021
What I Drive: 2012 Red Candy SEL Hatchback
Points 1,487, Level 21
Points: 1,487, Level: 21 Points: 1,487, Level: 21 Points: 1,487, Level: 21
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
FF Reputation: 5 scott7278 Good Standing Member
^^This.
scott7278 is online now
Old 09-05-2012, 03:58 PM   #4
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: '14 Ruby Ti w/ Handling Pkg
Points 7,361, Level 57
Points: 7,361, Level: 57 Points: 7,361, Level: 57 Points: 7,361, Level: 57
Level Up 6% Completed
Forum Activity 11%
FF Reputation: 13 kam327 Great Standing Member
Agree it sounds fishy. But why would one dealer lie to get out of fixing something under warranty when another will gladly do it? Maybe some dealers don't like taking on higher-risk warranty work?
kam327 is offline
Old 09-05-2012, 04:06 PM   #5
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,305, Level 29
Points: 2,305, Level: 29 Points: 2,305, Level: 29 Points: 2,305, Level: 29
Level Up 4% Completed
Forum Activity 4%
FF Reputation: 13 BetaDnB Great Standing Member
The dealer I was going to wouldn't even do the washer fluid level sensor tsb because my car "isn't equipped". Went to another dealer and guess what...it was fixed.
While I agree no new vehicle should have any leaks, if you bought a Harley you'd expect it to leak oil as a normal condition.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is offline
Old 09-05-2012, 04:14 PM   #6
Kabigon
Fan#: 88299
Points 4,428, Level 42
Points: 4,428, Level: 42 Points: 4,428, Level: 42 Points: 4,428, Level: 42
Level Up 39% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 11 Kabigon Great Standing Member
From TSB 11-12-13:
SERVICE PROCEDURE
1. Inspect the base of the transmission clutch housing for evidence of transmission fluid leak. Transmission fluid will be slick versus sticky. If the fluid leak is sticky and honey colored, it may be mistaken for engine oil or transmission lubricant. This condition may be caused by excessive rust inhibitor applied to the flywheel during manufacturing. Wipe clean the rust inhibitor from the transmission housing with Motorcraft® Metal Brake Parts Cleaner or equivalent.
Are you saying that the TSB is wrong or that you are sure that it wasn't rust inhibitor?
Kabigon is online now
Old 09-05-2012, 04:14 PM   #7
gostinger
Fan#: 44867
What I Drive: 2013 SE Black Pack Loaded 5 Spd MTX
FF Reputation: 1 gostinger Good Standing Member
I have the exact same problem with the oil leakage, and its also around the valve cover as well. Haven't taken it in for them to look at it yet.
gostinger is offline
Old 09-05-2012, 05:43 PM   #8
Dysan911
Fan#: 95746
Originally Posted by Kabigon View Post
From TSB 11-12-13:
SERVICE PROCEDURE
This is precisely the TSB they're basing things off of. I showed up a little while ago to take a test ride with the actual Service Manager and of course you could barely hear the noise. He said that's normal and it's just how a manual transmission would sound if you were lugging along in too low a gear. Well you'd think the programming of the DCT would prevent that and downshift a gear. Ugh.
So we got back to the dealership and he went into research the leak and referenced another TSB that involves replacing some Seals. They told me they would order those and give me a call to bring the car back in when the parts get in. He also said there's a TSB procedure they have to run through to determine if they will proceed with the seal replacements so I'll have to wait and find out what they discover. I guess they have to be certain its truly OIL and not that rust inhibitor stuff.
So at least thats something. I'll know more in a couple weeks I guess.
Dysan911 is offline
Old 09-05-2012, 05:51 PM   #9
unfocused1
Fan#: 95246
What I Drive: 2012 Candy Blue Ford Focus SEL
Points 986, Level 16
Points: 986, Level: 16 Points: 986, Level: 16 Points: 986, Level: 16
Level Up 86% Completed
FF Reputation: 2 unfocused1 Good Standing Member
Originally Posted by scott7278 View Post
^^This.
Seconded.
Mine does not leak.
Most peoples' cars don't.
Nor should they.
That dealer, or at least it's mechanical department, should feel ashamed, if nothing else more pragmatic. People really should be sick of outright lies being pawned off to paying customers, which is no way to run a business - either successfully or in any other form. Is there no ethics, no justice, no fairness, no anything anymore?
A fan of Ford, Freedom, Duncan Yo-Yos (but not Duncan Hines confectionary), and Strattera...
unfocused1 is offline
Old 09-05-2012, 05:53 PM   #10
GoldenHour
GoldenHour's Avatar
Fan#: 103427
What I Drive: 2014 Tuxedo Black ST
Points 1,148, Level 18
Points: 1,148, Level: 18 Points: 1,148, Level: 18 Points: 1,148, Level: 18
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 2%
FF Reputation: 3 GoldenHour Good Standing Member
before the warranty expired on one of my trucks i took it in and told the dealer i wanted all leaks fixed. when i got my truck back i still had a seal leaking. the reason it wasn't replaced was because the dealer felt the reimbursement wasn't high enough. after a bunch of double talk and my persistence the seal was replaced.
GoldenHour is offline
