#21 | ||||
I did coast in N from time to time when I was driving MT, but never with an AT. I always thought that the AT are not made for D to N and N to D switch endlesly.
White Platinum Metallic Tri-Coat 303A, 6-Speed SelectShift Automatic, 17" Aluminum wheels, Luxury Package, Parking Technology, Navigation, Winter Package |
| Sponsored Links | |||
Advertisement | |||
#22 | ||||
-----<M>-----
Oh yeah, I wouldn't go from N back into D while at speed. This is just for when you know you're going to have to stop well in advance. I wouldn't do it before light which could turn green before you come to a complete stop.
#23 | ||||
Interesting analysis. I'll probably still gun it all the time though.
![]() That's counterintuitive about the coasting in neutral vs in gear. Not sure how practical coasting in neutral will be where I drive, but good to have the info rattling around in the back of the noggin nonetheless. |
#24 | ||||
#25 | ||||
You will always get better avg mpg coasting in N vs D or S... this is due to RPM. Coasting in N is like putting the clutch in on a manual trans. As soon as you put it into N your RPM drops to idle, where as if you leave it in D or S your RPM is matched per gear and vehicle speed programming. as you slow down the auto will downshift raising the RPM... the higher the RPM the lower the MPG and vice versa.
#26 | ||||
#27 | ||||
Maybe when decelerating in gear, the vacuum generated by the piston downstroke sucks in blowby gasses back into the cylinder/combustion chamber, and then sends them out through the exhaust during the upstroke. So, maybe the Scanguage just "thinks" more fuel is being burned at this time, but it isn't? ... |
#28 | ||||
I think you have yourself the answer, our F150 (With the "gas guzzling" 5.4) has this technology (as opposed to the multi cylinder displacement crap that GM and Dodge use) and it works. When deacelerating in gear in our truck, it effectively "shuts off" fuel to engine and uses road speed (and the transmission) to continue to propel the vehicle forward while coasting (as long as possible anyway). To keep the engine "running" without new fuel, it uses compression and EGR system. We do notice a difference by "coasting" in gear to stop signs etc... I bet the Scanguage is not configured with those parameters and is merely measuring the amount of vacuum in the intake.
2012 Focus SEL 5 door 303a w/Lux pkg in KonaBlue 2012 Escape Limited w/park assist 2010 F150 Supercrew XTR 5.4 4x4 2008 Kawasaki Concours 14 (street) 2008 Kawasaki ZX10R (track only) |
#29 | ||||
-----<M>-----
The Focus burns say roughly 0.3 gal/hr at idle, and roughly 1.3 gal/hr at 45 mph (I'd have to confirm these numbers but rough order of magnitude they're pretty good). In the coast in neutral scenario, you're burning 0.3 gal/hr for the full 60 seconds to the stop for a total burn of 0.005 gal. In the coast in gear scenario, you're burning 1.3 gal/hr for say the first 20 seconds and then 0 gal/hr for the next 40 seconds for a total burn of 0.0072 gal, a 44% increase over the coast in neutral scenario. Quote:
#30 | ||||
Sonic MK3 Crew #06
| Thread Tools | |
| Display Modes | |
