Zetec Swap Write Up - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 09-05-2012, 07:01 AM   #1
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 35,543, Level 100
Points: 35,543, Level: 100 Points: 35,543, Level: 100 Points: 35,543, Level: 100
Level Up 0% Completed
Forum Activity 7%
Zetec Swap Write Up
Ok I'm gonna make one of these cause I can't seem to find one. If I seach I just find threads started by someone and all the do is say use the search function. Truth be told the tread doesn't exist.
I'm in the prosess of doing this so I'll post up as I go.
This is a 2002 auto SPI going to a 2002 auto zetec.
What you need if the cars are the same year.
For Zetec:
-Complete engine harness (goes back to fuel pump)
-Engine computer
-Exhaust manifold and flex pipe
-Alternator
-Coolant hoses
-fuel rail fuel line
-Intake tube
-Key reprogrammed (reflashed) required after install
-passengerside engine mount and bracket
-ATX harness
-power steering line and pump
-throttle cable and cruise control cable
-Positive and negative cables
-A/C compressor
-Flex plate
What you can reuse from your SPI:
-Driver side engine mount
-A/C lines
-Transmisson (auto trans is the same, but it is geared different)
-radiator
-axles if not switching from auto to five speed or vise versa.
-coolant tank
-MAF sensor
-air box
What I have now.
2.0 SPI SOHC
This is the donor car I'm taking the parts from.
2.0 Zetec.
Zetec wire harness
Zetec ecu that matches transmission
Zetec alternator
It don't hurt to change the timing belt while the engine is out. plus throttle body seal.
Zetec throttle body and throttle cable
Zetec power steering line.
Zetec engine mount and braket.
zetec water pipe.
Lower zetec water line.
Engine is in now for a test fit and to see what needs to be done with the coolant lines, and harness.
TheGlassMaker is online now
Old 09-05-2012, 11:08 PM   #2
wallnerm@asme.org
Fan#: 103516
What I Drive: 2000 Focus SE Wagon -White & Dirty
FF Reputation: 1 wallnerm@asme.org Good Standing Member
Hello, Ranger!
Please keep up with this thread; I have a Focus with a munched valve seat too, and am considering sticking a Zetec in it. I've been trying to figure out what needs replacing and if it's worth it.
Ironically, I bought my car new and looked hard to find the SOHC engine because it gets 1 mpg better mileage than the Zetec. Until the valve seat falls into the cylinder, anyway. I haven't driven it enough to check the mileage since then, though I was considering adjusting the valves on that cylinder to never open, and pulling the plug wire to see what kind of mileage I'd get on three cylinders...
Thanks for putting in the time and trouble to keep us informed on your project.
wallnerm@asme.org is offline
Old 09-05-2012, 11:19 PM   #3
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
Forum Activity 7%
No problem. I myself have seen how aggravating it is to look all this up. I will keep updateing the first post as I go, feel free to discuss and add things to the thread. When it comes to price just do your research and don't be afraid to ask around your local yards. I got a hell of a deal on the zetec and parts cause I told them I was needing a engine swap and asked if they could give me a package deal. So far I'm only in the hole $500.
Old 09-06-2012, 11:00 AM   #4
Focus_Happy
Focus_Happy's Avatar
Fan#: 62197
What I Drive: 2 SVTs & 1 Electric
Points 298, Level 5
Points: 298, Level: 5 Points: 298, Level: 5 Points: 298, Level: 5
Level Up 96% Completed
FF Reputation: 2 Focus_Happy Good Standing Member
Buy-Sell-Trade Rating: (4)
From this thread, you will also need:
Pass. side motor mount & black support bracket
ATX wiring harness (connectors are different for alternator & rear O2 sensor).
Throttle cable (different connector to TB).
Cruise control cable (different length).
Fuel inertia shut off switch (possibly)
Power steering line from pump to steering rack.
Let me know if you have any other questions.... had to do this to my 2000 wagon.
What's that orange car parked outside of Buckingham? Oh yeah that's right, it's a Focus.
Focus_Happy is offline
Old 09-06-2012, 01:17 PM   #5
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
Forum Activity 7%
I forgot to mention the mount and throttle cables. I already a have mount, harness. I need throttle cable and powersteering line. I don't have cruise control. OP updated.
Old 10-03-2012, 05:54 AM   #6
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
Forum Activity 7%
OP Updated!!
Old 10-08-2012, 12:46 AM   #7
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
Forum Activity 7%
More UPDATES.
Old 10-11-2012, 11:57 PM   #8
Ferox
Fan#: 104757
What I Drive: 2002 Black Focus Se
FF Reputation: 1 Ferox Good Standing Member
Im About to attempt the same swap but Auto SPI to MTX Zetec. Any Tips on swapping from Auto to MTX?
Ferox is offline
Old 10-11-2012, 11:59 PM   #9
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
Forum Activity 7%
I know you'll need the axles from the Mtx. I don't know a lot about that swap i'll do some research and see what I can find.
Old 10-31-2012, 12:07 PM   #10
Kirii
Kirii's Avatar
Fan#: 83633
What I Drive: 2003 CD silver Focus SE
FF Reputation: 1 Kirii Good Standing Member
Too bad my car is a manual. I don't believe the transmission will line up right so I'd have to replace that too.
Kirii is offline
