Go Back   Focus Fanatics > Ford Focus Tech Discussions > ZETEC Performance (2000-2004)
Old 09-10-2012, 07:32 PM   #41
steeda423
Fan#: 58410
What I Drive: 2002 Yellow STEEDA Zx3
FF Reputation: 1 steeda423 Good Standing Member
It's gonna take some work to get to 200hp
2.0 Litre ZETEC
  • Block - .085 over
  • Custom Wiseco Pistons 86mm IIRC
  • Crower Rods
  • Hardened Oil Pump Gear
  • ARP Head / Main / Flywheel bolts
  • Compression - 13.5:1
  • Race Fuel - 110 Octane
Head:
  • Massive Ultimate Head
  • Crower Stage 2 Cams
Intake:
  • Jenvey Individual Throttle Bodies from UK
  • Custom Air box
  • Cold Air Intake - Piped from Driver Headlight
Bolt Ons:
  • Underdrive Pulleys
  • Focus Central Adjustable Cam Gears
  • VCF Motor Mounts
  • SCT Xcal 2 Tuning Module
  • SunPro Digital Tach w/Shift Light
Motor by Massive Speed Systems, Spring Grove, IL
Tuning by Kurgan Motorsport
189hp 166 ft.lbs torque in 105 degree air temperature
Red Line - 8500 rpm
Ignition:
  • MSD DIS Dual Ignition Box
  • MSD Tach Adapter
  • MSD Coil
  • Massive 10mm wires
Exhaust:
  • JBA full Race Header
  • MSRB Exhaust
'02 Yellow Steeda 2002-023 - SCCA Chicago - Salt Creek Sports Car Club #423 EP
steeda423 is offline
Old 09-11-2012, 07:01 AM   #42
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
FF Reputation: 42 sleepyboy Great Standing Member
Buy-Sell-Trade Rating: (10)
^Badass ITB's and custom intake box to use the MAF fuel injection!
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 09-11-2012, 10:08 AM   #43
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT , Turbocharged
FF Reputation: 146 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
You should be much higher power then that I would think , On the Caterham guys I do the engines and tuning for at 10.8 to 11.2 compression with ITB , stg2 cams were making mid 182-186 HP
The ones ITB with 12.5 are at the 195 to 200 mark , why are you at 190 with 13.5 ?
Customer Support
AIM: hpdyno
Email: tom@focus-power.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 09-11-2012, 06:01 PM   #44
steeda423
Fan#: 58410
The power is restricted due to the air box, it's not big enough to hold all the air the engine needs. She will rev beyond 8500rpm but that's where she runs out of air.
My options are to cut the firewall and make a bigger airbox if I want to keep the MAF, or convert to speed density, remove the airbox, put some horns on the throttle bodies and let them suck air! My dyno tuner said that would give me another 35hp easy.
Your catterham guys probably don't have the throttle bodies in a box.
Nevertheless I'm quite happy with the power and it does it's job at the track very well. Autocross is more than just power, you need suspension, brakes, traction and the most important thing a driver!
Idling in grid it kinda sounds like a helicopter. Intimidating to say the least.
Old 09-11-2012, 06:09 PM   #45
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 33 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
There's plenty room down and under the TB's to make a bigger airbox ...
iminhell is offline
Old 09-11-2012, 06:28 PM   #46
Black&Tan
Black&Tan's Avatar
Fan#: 9971
What I Drive: '06 Liquid Grey SES hatch
FF Reputation: 8 Black&Tan Good Standing Member
Buy-Sell-Trade Rating: (9)
Yeah I'm sure the judges in the four cylinder class won't notice that at all. :/
HN #171
Black&Tan is online now
Old 09-14-2012, 09:56 PM   #47
King785
King785's Avatar
Fan#: 102339
What I Drive: 2001 focus race car zx3
FF Reputation: 1 King785 Good Standing Member
Yea that would be seen for sure.it would be nice to have all that power if i could get away with it.dont anyone go to heads up motorsports in spartanburg. They will rip u off and laugh about it.
King785 is offline
Old 03-27-2013, 09:46 AM   #48
ChnCDaFieD
Fan#: 112152
What I Drive: 2000 green lx
FF Reputation: 1 ChnCDaFieD Good Standing Member
Displacement increase could get you there. Almost impossible to tell without taking motor apart.
ChnCDaFieD is offline
Old 04-01-2013, 12:43 PM   #49
joser831
Fan#: 107975
What I Drive: 2000 Red zx3
FF Reputation: 1 joser831 Good Standing Member
All are greAt but i would try cold air intake,bigger throttle body ,port intake manifold port and polish, port exaust manifold dont lose the cat you need back pressure unless you are turbocharged or superchared other wise it wl runch shitty. Look in to changing you ignition to
Kming and cam timing advance it as you see progress if you deck the head and increase compression higher octane fuel to prevent preigniton a nice tuner would be great to adding hp. Look into wide band o2 sensors for tunning. You could get the svt variable intake manifold that has short and long runners for better low and high torque so youll have powerthrough all rpm. The only thing is that i believe that they are electroniccly controlled and you need the svt pcm :/ wich you can swap.mmm i hope it was some help oh and port the plenum and anywhere where there is air Nd exaust moving and a throttle body spacer..
joser831 is offline
Old 04-01-2013, 12:48 PM   #50
joser831
Fan#: 107975
Oh and bore your motor and look into heads that can help you out with the bore size.
joser831 is offline
