Cooling fan relays are high and low the same - Focus Fanatics
Old 09-04-2012, 06:10 PM   #1
focus_wagon
Fan#: 103404
What I Drive: 2002 wagon
FF Reputation: 1 focus_wagon Good Standing Member
I think I need to replace the low fan relay on 2002 with a/c zetec 2.0 engine. just wondering if the high speed and low speed relays are the same want to be sure I get the correct one. I do not have car its my daughters and would like to have parts here when she comes to my house.
Is the fan resistor a part I can get at the NAPA .
Anyone have NAPA #'s for the low speed relay and the resistor.
I have already replaced the CHT sensor
Thanks
focus_wagon is offline
Old 09-04-2012, 08:28 PM   #2
elsolo
elsolo's Avatar
Fan#: 96835
The drawing shows that the low speed relay has 5 wires, the high speed has 4 wires connected. That doesn't mean they are different, but I would suspect they are.
elsolo is offline
Old 09-04-2012, 08:53 PM   #3
Loeffler
Fan#: 103255
What I Drive: 2010 Focus
FF Reputation: 1 Loeffler Good Standing Member
Cannot help you with the exact number but you should be able to find here
napaonline.com/FindLocation/find-a-location.aspx
Hope that helps :)
Loeffler is offline
Old 09-05-2012, 03:56 AM   #4
amc49
Fan#: 96610
FF Reputation: 19 amc49 Great Standing Member
Yes, 5 leads, one I believe has to do with a diode so PCM can tell what's going on? High speed relay (4 leads) does not have the diode. Just went through this like a week ago.
Careful, I think they can both go in alternate holes.
amc49 is offline
Old 09-05-2012, 06:49 AM   #5
focus_wagon
Fan#: 103404
Thanks all good information I get the low speed relay and see if that fixes it. Its a intermittent problem sometimes it works so going for the relay will try the resistor next. New cars are a PIA life was so much simpiler before computer controlled cars I guess I'm getting old but when a old car overheated you either broke a hose, a belt or had a bad water pump.
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
