#1 | ||||
Voice Activation Issue
I'm having an issue with the Voice Activation. When I pull the lever, "Voice Activation" comes up on the screen, but no voice prompting me for a command. I can receive calls, but I can not use voice commands to make them. When I plug my iPod into the USB port and try to direct the system to play the iPod, nothing happens, again no voice prompt for direction.
Anyone else have something similar happen? Is there a way to reset the system somehow? |
Remove Advertisements |
Fan#: 1
#2 | ||||
Try one of these methods and hopefully you should be okay.
2012 SGM SEL Sedan 303a w/o Nav Job 1 built 6/2011 |
#3 | ||||
Sonic MK3 Crew #06
#4 | ||||
Not sure about the delayed reboot but I think I remember reading there is a menu option for a Sync reset.
. .......here's a lockpick. It might come in handy if you, the master of unlocking, take it with you. |
#5 | ||||
If it does, is it possible that your Sync is setup to Advanced in Settings -> Voice control
White Platinum Metallic Tri-Coat 303A, 6-Speed SelectShift Automatic, 17" Aluminum wheels, Luxury Package, Parking Technology, Navigation, Winter Package |
#6 | ||||
Ah, found it. Here it is for non-MFT Sync if you want to give it a try:
1. Press to enter the PHONE MENU. 2. Scroll repeatedly until SYSTEM SETTINGS appears in the radio display. 3. Press OK to enter the SYSTEM SETTINGS menu. 4. Scroll repeatedly until ADVANCED appears in the radio display. Press OK. 5. Scroll repeatedly until MASTER RESET appears in the radio display 6. Press OK. SYNC will ask you to confirm the reset. 7. Press OK to confirm. The radio display will read RESET DONE.
#7 | ||||
Didn't even notice that, my bad. Thanks for the correction. Looks like copernicum found it though, right on!
#8 | ||||
Thanks Man! This worked like a charm. For anyone else interested, there are a couple things I noticed afterwards. I had to clear sync from my phone's blue tooth menue, and re-couple it. Then I also had to upload my phone book from the phone as well. The other point to note; when I tried to use the sync services & voice commands for iPod, I had to wait for it to re-initialize the voice prompts. But, the important thing is, it all works just fine again. |
| Thread Tools | |
| Display Modes | |
