#61 | ||||
#62 | ||||
-----<M>-----
#63 | ||||
I've never tried, but letting off the brake does the DCT creep forward? I know when the DCT came out for VW one of the complaints was that the 'auto' didn't creep. If Ford tried to make this transmission creep that could cause a lot of the low speed shuttering as its massaging the clutch to creep forward.
#64 | ||||
DayGlow: Yes it creeps. I didn't have this problem before the TSB, which is why there was no shuddering when letting off the break, but now it does so. It almost pulses in the way that it engages/disengages the clutch. Not very smooth, and probably the reason people think it's crap. It's just like holding the clutch at the friction point in a manual car and tapping the gas. It's borderline stalling the car but giving it enough gas to keep going. It's annoying, and would be an easy fix, but there's not much we can do. |
#65 | ||||
-----<M>-----
If you haven't experienced the violent shudder or "jolt" that I and many others have reported, you can't understand how abnormal it is. Many are reporting a shudder / jolt miraculously went away after 12B37, others are reporting it unmiraculously appeared after 12B37. These people are presumably driving pretty much the same before and after 12B37, i.e. not all of a sudden employing tricks or massages to get the shudder to all of a sudden go away or appear. My violent launch shudder appeared with about 500 miles on the clock and gradually disappeared after 5 hard launches at about 1500 miles. The changes had nothing to do with any updates since my first update was 12B37 with over 5,000 miles on the clock. The car drove noticeably worse after 12B37 but has gradually gotten back to the way it was. And my shudder only happened after 20 minutes or so of suburban driving (i.e. after the tranny got hot). I didn't all of a sudden change my driving style 20 minutes into my commute. I have seen several others on here report this same thing. All of this tells me this is a software (i.e. adaptive learning) issue or a hardware (clutch pack) issue. It is NOT a driving style issue in my opinion, as just about everyone who has been lucky enough to not have the shudder / jolting problem insists it must be. |
#66 | ||||
#67 | ||||
-----<M>-----
Also, I rented a Focus last summer, so it was a very early build, and I didn't notice anything wrong with the transmission. IIRC it had several thousand miles on it. Again, IMHO this is a software/hardware flaw that for some reason affects a good number of cars but not the majority. |
#68 | ||||
Well, I just came back from the Ford garage. The guy who looked at the car actually went for a ride with me. Of course it wasn't acting up like it had been previously (nothing ever seems to go wrong like it should when I take any of my vehicles into the dealer), but there were mild cases of what I was describing. The mechanic told me that I can expect the transmission to, at times, perform as I described (being jerky on some shifts, etc..), because it was not going to act like a normal automatic transmission.
I came home, pulled the battery and instantly noticed smoother shifting. As kam327 mentioned above, I do believe it IS a software/hardware flaw....and I can't help but think it's all in this "adaptive learning"....because the battery pull clears that out...and that's when my car starts shifting better....until the adaptive learning "learns" again. I'm still not keeping this car past the 36,000 mile warranty. |
#69 | ||||
-----<M>-----
Personally I won't go as far as to get rid of it at 36k. I'll wait until the tranny hardware warranty runs out which is 60k and then decide whether to get an extended warranty to continue coverage. |
#70 | ||||
My Build is 12/11. Not that the battery pull has anything to do with this as I noticed this before the battery pull but today I dropped my car off for Service because at about 40mph or just under that when the tranny is in 6th. The slightest incline or if you push the gas pedal down just a little to bring the RPM's up it sounds like Im dragging a metal trash can lid under the front of the car. You can hear it over the radio.
Also there is oil seeping from between the area where the Engine meets the Transmission. Its odd though that it still seems to be shifting and holding fine but not as good as the first day I pulled the battery. I suspect the adaptive learning is starting to sneak back in. Really wish there was an Adaptive Learning FUSE we could pull!. :) Anyhow, considering I feel I have the worse Build ever, my rear main seals are probably shot and I'll probably need new clutches at this point. So Far I've had service for: 1. Highway drift TSB 2. Front suspension Clunk TSB 3. 11-10-2 PCM update 4. 12B37 Update 5. MFT update 3.02 6. Rear driver door sticking 7. Bluetooth Mic Excessive ROad noise 8. Touch Handle Door unlock intermittent 9. transmission Oil leak Yeah I doubt I"ll be keeping the car past 36k either. |
| Thread Tools | |
| Display Modes | |
