Those not happy with the 12b37 update - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-30-2012, 03:28 PM   #1
Dysan911
Fan#: 95746
For what it's worth. After I had mine done there seemed like some minor occasions where the shifting was fine but for the most part my biggest gripe was the inconsistent behavior of where it seemed way too eager to shift to the highest gear possible all the time and wanted to lug/bog the motor.
Even while I'm accelerating from a light it would suddenly shift down to 6th way way too early and fall flat on it's face and would rarely drop a gear when trying to speed up a tad. Just more lugging.
Well I know there's been a lot of threads on the topic of the 12b37 update and I happened to catch where one person said something about having disconnected the positive battery cable for 10 mins and forced the car back into the adaptive learning mode. I didn't like the idea of having to lose all my settings and just never really put much weight into thinking that would ever work anyway.
Well about a week ago I was tinkering under the hood and decided what the hell and disconnected my battery. I purposely waited this long to make sure this wasn't a fluke but ever since doing that the DCT has been acting WAY different. It holds the gears longer when I want it to (while accelerating normally) and doesn't seem to try and immediately lug the motor. Also a little pedal action is all it seems to take now for it to drop a gear and help with slight passing, etc. Whereas before it would just Bog until a point that you've pushed the pedal down so far that it violently downshifts. Ugh.
It's still not a 100% though because every once in a while the perfect traffic situation will pop up where it may confuse the DCT with what I'm wanting to do and the 90 degree turns still doesn't seem to figure out what gear it should be in (2nd.. ITS 2nd!!! put it in 2nd Gear!!!) but overall a remarkably drastic improvement for me. It even seems to pull harder which is probably the a result of not shifting short of peak torque.
Just wanted to pass it along and see if anyone else notices an improvement. I just hope it doesn't revert back to it's old habits.
The only theory I can come up with is maybe there's some adaptive learning data from before that was still there and would take a lot of driving to work out or the dealer didn't take the time to wipe the memory, etc. who knows.
Oh and by the way. All your radio Presets, BT Phone, etc do not get erased. the MFT must have it's own battery backup.
Dysan911 is offline
Old 08-30-2012, 04:21 PM   #2
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
I may give this a shot, thanks for sharing!
Sonic Crew #28
feta_mgp is offline
Old 08-30-2012, 04:27 PM   #3
Kaaru
Kaaru's Avatar
Fan#: 96763
What I Drive: '12 Oxford Wh. SEL Sedan 28/07/2011
FF Reputation: 1 Kaaru Good Standing Member
humm, ...I may try this aswell too...before I drop a K&N filter in. Thanks for sharing.
2012 Oxford White SEL Sedan
303A + winter package + Moonroof + 16'' OEM
Kaaru is offline
Old 08-30-2012, 05:56 PM   #4
AZfocus2012
AZfocus2012's Avatar
Fan#: 92484
What I Drive: 2012 White Platinum SEL 303A Focus
FF Reputation: 2 AZfocus2012 Good Standing Member
I may have to try this. I did the series of hard accelerations in both "D" and "S" and it made a dramatic improvement in the parking lot speed functionality and some improvements in general shifting, but I still like versions 2.0 and 3.0 better.
AZfocus2012 is offline
Old 08-30-2012, 06:39 PM   #5
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,077, Level 34
Points: 3,077, Level: 34 Points: 3,077, Level: 34 Points: 3,077, Level: 34
Level Up 18% Completed
Forum Activity 3%
FF Reputation: 12 dan50 Great Standing Member
Interesting. Did you perform the Ford "drive cycle" after reconnecting the battery or just drive normally?
dan50 is offline
Old 08-30-2012, 06:39 PM   #6
Charlize
Fan#: 99352
What I Drive: 12 focus white sel
FF Reputation: 1 Charlize Good Standing Member
I hate this update for a slightly different reason... I CAN'T STAND THE BRAKE PEDAL FEEL WITH SLIGHT MODULATION IN TRAFFIC!
Charlize is offline
Old 08-30-2012, 08:20 PM   #7
Dysan911
Fan#: 95746
Actually I did do a WOT blast down the road once but for the most part I just drive it normally.
Dysan911 is offline
Old 08-31-2012, 02:33 AM   #8
AZfocus2012
Fan#: 92484
What is the Ford "Drive Cycle"?
Old 08-31-2012, 08:37 AM   #9
Nelson12
Nelson12's Avatar
Fan#: 95451
What I Drive: 2012 Ford Focus SE Sport MT SGM
Points 713, Level 14
Points: 713, Level: 14 Points: 713, Level: 14 Points: 713, Level: 14
Level Up 13% Completed
FF Reputation: 2 Nelson12 Good Standing Member
Why not drive a manual? It shifts when you want it to
Nelson12 is offline
Old 08-31-2012, 09:52 AM   #10
Dysan911
Fan#: 95746
Not sure if your referring to the DCT's Manual mode or that I should have bought a 5 speed.
@AZFocus - The drive cycle is some crazy convuluted procedure that I guess Ford came up with to throughly set the DCT for optimal shifting. I guess exposing it to every situation but you'd almost need a closed test track to do it. It has you doing 0 to 20, hard braking, slow take offs, hard takes offs, Putting the car in park to drive a dozen times. Its just insane if you ask me. Im sure you can find the procedure on this site somewhere. Aside from doing one Wide Open Throttle beat down after I did the 10min Battery disconnect. Ive been driving normally.
Its still doing great!. I've been watching my shift points lately and a moderate (not wide open) acceleration my shifts are occurring just over 4k RPM, where as before they were around 2500 to 3k.
Its feeling a lot like the Programming prior to 12B37 IMHO.
Dysan911 is offline
