Mild cam install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-29-2012, 06:48 AM   #1
saosin7938
Fan#: 76698
What I Drive: 2000 pitch black zx3
FF Reputation: 1 saosin7938 Good Standing Member
Mild cam install
Thinking about doing a very mild street cam install. Any info on setbacks or just a quick DIY in parts I'm going to need
saosin7938 is offline
Old 08-29-2012, 07:17 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,444, Level 100
Points: 140,444, Level: 100 Points: 140,444, Level: 100 Points: 140,444, Level: 100
Level Up 0% Completed
Forum Activity 59%
Activity: 59% Activity: 59% Activity: 59%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
I would get the biggest ones you can afford for the most gains. You will need cam shaft seals and I would also upgrade to adj. cam gears (I highly recommend them) at the same time. That way you don't have to redo the timing twice if you decide later on down the road. Also you will need to get them dyno tuned in order to feel the benefits of the cam gears. I had the stock cams dyno tuned and I gain power everywhere. Really livened the motor up. I have yet to get the cams I have now dyno tuned but I imagine I will get the same results. I'm currently running a Ford Racing stg. 2 intake cam and a Crower stg.1 exhaust cam. The only reason why I'm running two different kinds of cams is because I bought one cam at a time used due to financial reasons. They popped up on the BST forum so I scooped them up.
Here is the How to for the cams HERE
Here is the cam gear how to right HERE
I want to say that Comp Cams are the go to cams that one of our tuners highly recommends. They have great drivability and fantastic top end power.
Oh and also if you haven't gotten a tune from a tuner I highly recommend that as well. I gained so much low end power from the tune and not to mention the huge increase in driveability that came with it.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 08-31-2012, 08:12 AM   #3
kmtalko
kmtalko's Avatar
Fan#: 91681
What I Drive: '03 Red ZX5
FF Reputation: 1 kmtalko Good Standing Member
I'm interested in getting my stock motor tuned. If I don't have SCT or a tuner, how do they go about changing the stock ECU?
DD: 2003 Ford Focus ZX5-65mm TB, Intake, Long Tube Header, 2.5" exhaust, UDP, Tom's Tune. Almost 200k miles and still running strong!
kmtalko is offline
Old 08-31-2012, 04:52 PM   #4
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,771, Level 54
Points: 6,771, Level: 54 Points: 6,771, Level: 54 Points: 6,771, Level: 54
Level Up 11% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
The ECU stays the same.
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 08-31-2012, 07:13 PM   #5
kmtalko
kmtalko's Avatar
Fan#: 91681
K cuz the tuning place asked if theres a port for the PCM and I wasnt sure. Then they asked if I was familiar with diablo sport, but I thought that was only for SVT's. I'll have to do some research i suppose. Thanks for the input.
kmtalko is offline
Old 09-28-2012, 06:33 AM   #6
boborc
Fan#: 104318
What I Drive: 2003 ZX3
Points 5, Level 1
Points: 5, Level: 1 Points: 5, Level: 1 Points: 5, Level: 1
Level Up 9% Completed
FF Reputation: 1 boborc Good Standing Member
Hey, new to this forum but I'am doing a cam install on a 2.0 zetec and was looking for some info. Sleepyboy I was lookng at your links and that torque pattern just doesn't seem right,is that correct???you just tighten them in a straight line? am I missing something? It goes against everything that i was shown but i never torqued a cam that was having valve spring pressure on it so maybe there is a different way???Any help or feedback would be great. Thanks
boborc is offline
Old 09-30-2012, 07:05 PM   #7
focusonthefocus19
Fan#: 104272
What I Drive: 2002 yellow focus zx3
FF Reputation: 1 focusonthefocus19 Good Standing Member
How much does it take to buy performance cams, install, and tune?
I always wanted a higher performance came for my 2.0L zetec. It's just a normal 2002 zx3. How much would every thing cost?
focusonthefocus19 is offline
Old 09-30-2012, 11:40 PM   #8
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,580, Level 62
Points: 8,580, Level: 62 Points: 8,580, Level: 62 Points: 8,580, Level: 62
Level Up 44% Completed
Forum Activity 38%
Activity: 38% Activity: 38% Activity: 38%
do it your self?
$30 for TDC & Cam Tool
$200 adjustable CAM gears (New, less if used)
$400 for Cams
$250 for new valve springs
$100 For head work (to grind down possible interference problems with new cams)
$400 NA Tune from Tom ( I think that's what he charges)
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 10-02-2012, 11:54 AM   #9
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 59%
I don't see what your talking about. Your right about making sure there is no spring pressure on the caps your tightening. The instructions look good to me. No one's ever said anything like this before?
Moderator for
Technical Chat
Old 10-02-2012, 12:01 PM   #10
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 59%
Depends on the cams you get. Some can use the stock springs. I believe anything below .381 lift can be used with the stock springs though it is recommended to get better springs if you plan on sustained high rpm as the stock ones will wear out over time. So like Magus posted it could cost this much or as little as just the cams themselves and a little assembly lube. All depends. I'm cammed for less than 300 bucks. Look for deals in the Buy Sell area.
Moderator for
Technical Chat
