Install Daytime Running Lights (DRL) Ford Focus 2000 ZX3 DOHC - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-28-2012, 09:21 PM   #1
juansea
Fan#: 103192
What I Drive: 2000, Orange, Focus ZX3
FF Reputation: 1 juansea Good Standing Member
All you need to do is to bypass two wires from the Ignition relay on pins 3 and 5 to pins 2 and 3 in the R6 relay, make sure you disconnect the wires that conect the relay on pins 2 and 3 of R6 relay. All of that has to be done on the fuse box that is besides the engine.
juansea is offline
Old 07-17-2014, 02:09 PM   #2
Tiger-Heli
Fan#: 12379
What I Drive: 2002 French Blue SE Sedan
Points 1,015, Level 17
Points: 1,015, Level: 17 Points: 1,015, Level: 17 Points: 1,015, Level: 17
Level Up 15% Completed
Forum Activity 11%
FF Reputation: 4 Tiger-Heli Good Standing Member
I'm pretty amazed nobody has commented on this.
I like the idea, but I'm too chicken to try it, but ...
R6 is the low beam relay and Pin 3 is the load side of the relay. Essentially, what you are doing is transferring the lights to the ignition relay. Not sure why Pin 2, which is the relay ground is affected.
It works, but it isn't true DRL (there is no resistor so the headlights are full brightness not 60% brightness). And the foglights would also be on if the car is equipped with fog lights.
But it's easier and better than turning on the headlights every time you get in the car b/c you don't also have the taillights and parking lights on.
Question - I don't fully understand it, but wouldn't it be easier just to run a wire and a switch from a fuse that is hot in start or run and splice into Pin 1 - which is the trigger for the low-beam relay?
I think this would do the same thing - with the advantage that you could turn the switch off and the car would work normally without DRL's if you wanted to sell it or if you needed to have the ignition in run for a while without the engine running and didn't want the lights to drain the battery.
I would find a fuse in the battery junction box, but here is a schematic of how my idea would work.
Comments?
Tiger-Heli is online now
Old 07-20-2014, 11:00 AM   #3
hlr270
Fan#: 109658
What I Drive: 1997 Tuarus LX
Points 5, Level 1
Points: 5, Level: 1 Points: 5, Level: 1 Points: 5, Level: 1
Level Up 9% Completed
FF Reputation: 1 hlr270 Good Standing Member
Personally as an avid motorcyclist I HATE daytime running lights. Yes, they do make your car more visible that also makes motorcyclists less distinguishable in traffic forcing us to burn our highbeams. That being said I put my soapbox away and did this to my 17yo daughters ZX3(2000) Thanks for the info
hlr270 is offline
Old 07-21-2014, 07:08 AM   #4
Tiger-Heli
Fan#: 12379
Forum Activity 11%
Did you use my suggestion or Juansea's or something different from either of us?
Old 07-28-2014, 12:01 AM   #5
nanuk
Fan#: 166682
What I Drive: 2000 Black ZX3 Hatchback
FF Reputation: 1 nanuk Good Standing Member
I am a fan of ALL the lights coming on: Low beam AND tail lights/running lights.
I cannot think of a reason to NOT have them on all the time when daytime driving....
nanuk is offline
Old 07-28-2014, 09:15 AM   #6
Tiger-Heli
Fan#: 12379
Forum Activity 11%
Because you want people to see and pay attention to your brake lights and if the taillights are on there is less contrast between the brake on and the brake off.
Old 08-13-2014, 10:48 AM   #7
sleddingguy
Fan#: 118979
What I Drive: '05 ZX5 SE
Points 75, Level 1
Points: 75, Level: 1 Points: 75, Level: 1 Points: 75, Level: 1
Level Up 50% Completed
FF Reputation: 1 sleddingguy Good Standing Member
I have the phillips DRL LED kit installed into the lower front fascia. They are slim and fit nicely. Pretty easy to hook up, one wire to the parking light and then directly to the battery. The lights detect the voltage drop when the parking lights are turned on and DRL turn off.
sleddingguy is offline
Old 08-13-2014, 11:11 AM   #8
glbikefixer
Fan#: 154226
What I Drive: 2003 focus SVT
Points 22, Level 1
Points: 22, Level: 1 Points: 22, Level: 1 Points: 22, Level: 1
Level Up 43% Completed
FF Reputation: 1 glbikefixer Good Standing Member
day lights
any pics?
glbikefixer is offline
Old 08-15-2014, 07:47 AM   #9
focus_wagon05
Fan#: 178953
What I Drive: Focus Wagon 2005
Points 76, Level 1
Points: 76, Level: 1 Points: 76, Level: 1 Points: 76, Level: 1
Level Up 52% Completed
FF Reputation: 1 focus_wagon05 Good Standing Member
North of the border all cars have day time running lights, it is not distracting at all and you can absolutely tell the difference between a running brake light and a braking action light - there is a big difference.
If you gents are interested in getting this mod done properly, look for a wiring diagram from a Canadian Focus and you'll find what Ford did to implement this.
focus_wagon05 is offline
