2003 ZTS - horrible gas mileage - 16.3mpg - HELP - Page 2 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 09-28-2012, 11:55 AM   #11
PWGuy
Fan#: 91777
What I Drive: 2003 Pitch Black ZTS Sedan
Points 2,103, Level 27
Points: 2,103, Level: 27 Points: 2,103, Level: 27 Points: 2,103, Level: 27
Level Up 69% Completed
FF Reputation: 1 PWGuy Good Standing Member
Update .. unhooked the battery and reset the ECU .. everything went according to described with the PCM resetting. I also re-cleaned the MAF with electronics spray cleaner (again - did this fall 2011). A few days later, one of the calipers "stuck" and I had both front calipers, rotors, and pads replaced. I then filled it up to the top with gas to test MPG after some mileage. My wife drives 2.9 miles to work each way, every day. Gas is currently at 1/2 tank (110 miles on odo) and the capacity for my car is 13.2 gallons. That works out to 16.6mpg :( :(. I thought FOR SURE the caliper grabbing the rotor caused this since it didn't "just" happen - it just started smoking 3 weeks ago! lol
I haven't cleaned the IAC yet (it's never been cleaned).
So yet to do:
* Clean IAC (never been done)
* Flush tranny fluid and replace filter (never been done)
* Replace rear/lower O2 sensor (never replaced)
Any other ideas? This MPG is disgusting! It makes me want to get rid of the car besides the rust issues..
PWGuy is offline
Old 09-28-2012, 12:15 PM   #12
Wagone
Fan#: 100532
What I Drive: 2003 Wagon SE MTX
Points 430, Level 8
Points: 430, Level: 8 Points: 430, Level: 8 Points: 430, Level: 8
Level Up 60% Completed
FF Reputation: 1 Wagone Good Standing Member
Pull an O2 sensor and look at back pressure
WaGone
2003 2.3 MTX Wagon
Wagone is offline
Old 09-28-2012, 12:17 PM   #13
PWGuy
Fan#: 91777
Sorry, I'm not following the second half of what you suggested - "look at back pressure". What does that mean and how do I do that?
PWGuy is offline
Old 09-29-2012, 11:20 AM   #14
Crankworm
Fan#: 98694
What I Drive: 2002 Gold ZTW
FF Reputation: 1 Crankworm Good Standing Member
I think this is your culprit. Short drives don't allow the car warm up. My wife drives a Freestar 1.2 miles to work, she averages 13 mpg
Crankworm is offline
Old 09-29-2012, 11:39 AM   #15
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,030, Level 27
Points: 2,030, Level: 27 Points: 2,030, Level: 27 Points: 2,030, Level: 27
Level Up 20% Completed
Forum Activity 4%
FF Reputation: 86 BC_ZX3 Excellent Standing Member
I then filled it up to the top with gas to test MPG after some mileage. My wife drives 2.9 miles to work each way, every day. Gas is currently at 1/2 tank (110 miles on odo) and the capacity for my car is 13.2 gallons. That works out to 16.6mpg :( :(..
Or you could learn how to measure your fuel usage properly...
Your fuel tank capacity is irrelevant. Your fuel needle gauge is inaccurate for estimating the fuel remaining.
Fill the tank with gas until the pump clicks off.
Reset trip odometer to zero.
Drive (and consume at least half a tank.)
Fill tank again until pump clicks off. Record the amount used.
Record the trip odometer reading.
Trip odometer reading / fuel used = economy.
2.9 miles? Your car's not even going to reach operating temperature. You're going to get crappy mileage.
BC_ZX3 is offline
Old 09-29-2012, 12:46 PM   #16
PWGuy
Fan#: 91777
Ok, I will try warming up the car 5 minutes before my wife leaves to see if the mileage improves.
Thanks for all the suggestions
PWGuy is offline
Old 09-29-2012, 12:47 PM   #17
PWGuy
Fan#: 91777
Thanks
PWGuy is offline
Old 09-29-2012, 01:47 PM   #18
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,104, Level 85
Points: 18,104, Level: 85 Points: 18,104, Level: 85 Points: 18,104, Level: 85
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
Forum Activity 29%
Activity: 29% Activity: 29% Activity: 29%
FF Reputation: 48 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
So by my math you're filling the car around once a month?
If so, there is the possibility of the fuel separating slightly, lowering Octane.
The Evaporative Emissions could be leaking slightly, fuel is escaping.
If you're going to try and let the car warm up for better MPG, don't let the car run. Buy a engine block heater. Kw/hr if far cheaper.
Don't "think outside the box".
There is no box.
Do it correct, or do it twice.
iminhell is offline
Old 09-29-2012, 02:44 PM   #19
Chris_HT
Chris_HT's Avatar
Fan#: 86229
What I Drive: Blue SVT 2002
Points 1,526, Level 22
Points: 1,526, Level: 22 Points: 1,526, Level: 22 Points: 1,526, Level: 22
Level Up 26% Completed
FF Reputation: 4 Chris_HT Good Standing Member
cracked exhaust manifold?
Blue SVT 2002
Our Lady of blessed acceleration
Originally Posted by Black&Tan View Post
But.... why read facts and investigate a claim when it supports your ideology?
...that should be written as 'The First Law of Internet Forums'
Chris_HT is offline
Old 09-29-2012, 06:33 PM   #20
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
Points 27,169, Level 97
Points: 27,169, Level: 97 Points: 27,169, Level: 97 Points: 27,169, Level: 97
Level Up 82% Completed
Forum Activity 7%
It seems like you have the best advice so far. As long as the engine is running smoothly, there should be no other problems.
1) Correct your mileage calculation- use the method BCZX3 suggested.
2) The ECU reset shouldn't be done without doing the A/F reset at the same time. This requires you to idle the engine in P or N for 5 minutes after it is dropped out of high idle mode. When the test is finished, the idle will drop slightly. With her short driving- it might not have reset the A/F yet. I'd go out and start the car and let it idle for 7 mins exactly- TIMED. You can use the electronic odometer trick to see if the idle drops slightly after 6 mins or so. That will indicate it's done. I'd expect idle to be around 1100 for a car that has not passed this test, and 800 (IIRC) for an AT in N. It might be lower, but that is not bad unless the idle is extremely low in gear- like 500.
3) I didn't see mileage, or engine. We've gathered it's an AT, but we need to know the engine. Mileage is important also because if you're approaching 130k+ or so, and the timing belt has not been replaced, that would explain some of the issues.
Honestly, with a 2.9 mile drive, I'd only expect about 21-23 mpg, and yes, as Iminhell suggested, you might be experiencing fuel degradation. If nothing else, I'd give some Sta-Bil a shot- make sure you get the gas type not diesel. Finally- your fuel filter is due for a change. Yes I know, way under the 20k mark, but I do recommend that as 20-30k or 1 year. I change the wife's yearly, she puts about 10k per year on the van. It will be dirty.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
